Airborne DF
Old February 6th 06, 12:28 AM posted to rec.aviation.homebuilt
Default Airborne DF
Hi All,
I am fitting my homebuilt with instruments and radios, and wanted to add a
Direction Finder. I wanted a doppler type, but with small antennas in a 4
point aray with a small dimension or distance between the antennas. Am I
really far out of reason, or is this an achievable goal?
Charlie
Old February 6th 06, 01:10 AM posted to rec.aviation.homebuilt
Default Airborne DF
ccwillwerth wrote:
Hi All,
Charlie
Hi Charlie
There are many kits out there that will do this. Here is one.
http://www.ramseyelectronics.com/cgi...ction&key=DDF1
Of note is most require an FM receiver and aviation uses AM signals.
Although the transmitted signal doesn't need to be FM it can be SSB CW AM
or FM but it might be hard to get a receiver that will receive using FM on
the aviation band. Although if you can get schematics of your receiver you
should be able to modify it for FM reception (add a coax connection to one
of the many FM demodulators kits (I think this Ramsey company has one) just
make sure they both use the same IF) I wouldn't try this with your active
aircraft receiver.
John
Old February 6th 06, 02:33 AM posted to rec.aviation.homebuilt
Default Airborne DF
Thanks John, but the ramsey units require huge antennas and to great a
spread between them. I have looked at them on several occassion, but can't
see how I could make them work.
Charlie
"UltraJohn" wrote in message
ink.net...
ccwillwerth wrote:
Hi All,
a
4
Charlie
Hi Charlie
just
aircraft receiver.
John
Old February 6th 06, 04:15 AM posted to rec.aviation.homebuilt
Default Airborne DF
can't see how I could make them work.
Charlie
Actually Charlie you can use an electrically shortened antenna and the
spacing for them is only 1 1/2 to 2 feet so it should not be a huge
problem. The below link is another site with a df kit the link actually
goes to the antenna page which is quite interesting.
John
http://www.silcom.com/~pelican2/MINI_INTRO.html
Old February 6th 06, 06:37 AM posted to rec.aviation.homebuilt
Default Airborne DF
Doppler sometimes does not work well if there are reflections - but the
aircraft has an advantage over ground vehicles so it could have a better
success rate. Because the signal is line of sight, you can reduce the
length of the antenna and still have an adequate signal, although you will
have a reduced range. Rubber ducks can be used, although flexing can affect
directivity.
Another option is to install a number of directional antennas and switch
between them. The aircraft has an advantage in that it can be rotated
fairly easily. With a good signal indicator, you could home in on the
hunted signal. I have one of the Ramsay Dopplers and normally use it on the
ground for Search and Rescue. We search in rugged terrain and I have not
found it as useful as a directional antenna.
Years ago a friend of mine built a Doppler to use in a hidden transmitter
hunt. Soon after the start, he realized it was not working, but he had left
all of his other direction finding gear at home. He got his handy talkie
with rubber duck out and drove around finding the strongest signal. He
would drive behind buildings to determine directivity - since the building
would make the signal weakest if it was directly in the path. He was first
to arrive at the hidden transmitter, proving that it is the operator rather
than the equipment that is key in direction finding.
Colin
Old February 7th 06, 07:37 PM posted to rec.aviation.homebuilt
Default Airborne DF
Thanks Colin,
I like the Picco Doppler Mini Antenna of the system John sent info on. I
could bury it in the wooden wing with dual band rubber duck antennas. The
problem is that once it is in, access would be difficult to accomplish. I
will be covering the wing during the summer. I gusee I could try it out
before then. Thanks for the input.
Charlie
"COLIN LAMB" wrote in message
nk.net...
affect directivity.
the ground for Search and Rescue. We search in rugged terrain and I have
not found it as useful as a directional antenna.
left all of his other direction finding gear at home. He got his handy
talkie with rubber duck out and drove around finding the strongest signal.
He would drive behind buildings to determine directivity - since the
building would make the signal weakest if it was directly in the path. He
was first to arrive at the hidden transmitter, proving that it is the
operator rather than the equipment that is key in direction finding.
Colin
Old February 7th 06, 11:40 PM posted to rec.aviation.homebuilt
Default Airborne DF
A few extra access panels could make things much better, no?
Jim in NC
Old February 8th 06, 05:06 PM posted to rec.aviation.homebuilt
Default Airborne DF
Hi Jim, Yes, I will have the panels, but when you try to pull a 9" diameter
object through a 4" hole, something groans. I want to build the device, and
make the electronic antenna rotor in a box small enough to get through the
hole. If the antennas are mounted to the groundplane via BNC or something,
I will be able to try different versions, but the groundplane will have to
be permanent.
Charlie
"Morgans" wrote in message
The problem is that once it is in, access would be difficult to
accomplish. I will be covering the wing during the summer. I gusee I
could try it out before then. Thanks for the input.
Jim in NC
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
"New helicopters join fleet of airborne Border Patrol" Mike Rotorcraft 1 August 16th 04 10:37 PM
Boeing $241.8 million contract ballistic missile-hunting Airborne Laser Larry Dighera Military Aviation 1 May 29th 04 01:05 PM
Coalition casualties for October Michael Petukhov Military Aviation 16 November 5th 03 12:14 AM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 02:31 AM
