A couple of questions about IPC
Old February 9th 06, 05:56 PM posted to rec.aviation.ifr
Default A couple of questions about IPC
Paul Tomblin wrote:
I've only done one approach in the last 6 months. I've let my
currency lapse, so as I read the regs I now have to do an IPC,
right?
No. If you're less than 6 months out of currency, you can go get
yourself current again by flying 6 approachs and a hold with a safety
pilot. If you let things go beyond 6 months (from the date you ran
out of IFR currency), *then* you need to do an IPC. You can elect to
do an IPC anyway.
What does an IPC consist of? Just 6 approaches and a hold, or is
there more to it? Can it be fewer than 6 approaches?
The IFR PTS lays out the details. To a reasonable approximation, it's
a repeat of your instrument checkride. In practice, what I want to
see is that you can fly a partial-panel ILS, a full-procedure GPS
approach, a hold, and still remember how to navigate without a GPS
(i.e. a VOR or LOC approach flown with just the nav radios).
Old February 9th 06, 06:02 PM posted to rec.aviation.ifr
On 2/9/2006 10:52 AM, Mark Hansen wrote the following:
Wait a tick ;-) Are you saying that if you're beyond the 6-month
currency, that you can fly in actual IMC and all you need is an IR-
current safety pilot - not a CFII?
Sure. The IFR-current pilot would be PIC and could legally let a
monkey handle the controls if he chose to, so why not an IA rated pilot?
Old February 9th 06, 06:23 PM posted to rec.aviation.ifr
Yes, but I didn't think this 'monkey' was allowed to use the time toward
IR currency.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old February 9th 06, 07:43 PM posted to rec.aviation.ifr
The IPC now is listed as a procedure in the PTS for the
instrument rating, it is no longer just a "pick your own"
flight.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Robert Chambers" wrote in
message
om...
| The IPC can consist of whatever you want to make yourself
current. 6
| approaches, tracking VOR's and holding, which you can do
with a safety
| pilot. However since you have the CFII in the plane with
you, it could
| be something else you'd like to work on such as timed
turns or partial
| panel, along with a couple of approaches and a hold or so.
| The CFII is going to assess whether you are safe and
competant to fly
| IFR and signs the log book to that effect. I do an IPC
with my CFI
| whenever I haven't flown in the gauges for a while and
want to make sure
| that I haven't picked up any bad habits.
| Technically you don't need to do the IPC until 1 year
after you lose IFR
| currency but you don't have to do just the minimum
required to get by.
| Robert
let my currency
right? What does an
there more to it?
Old February 9th 06, 08:07 PM posted to rec.aviation.ifr
On Thu, 09 Feb 2006 09:23:33 -0800, Mark Hansen
IR currency.
If you review 61.57 regarding instrument currency, you will see that the
requirements are for logging flight under actual or simulated instrument
conditions.
The requirements for logging are merely that you be sole manipulator of the
controls.
So yes, the non-current pilot can manipulate the controls and log PIC in
IMC, while the IR pilot acts as PIC, but cannot log PIC while in IMC.
Old February 9th 06, 09:13 PM posted to rec.aviation.ifr
I meant to say you don't have to do 6 approaches, holds and VOR tracking
which is the requirement for currency. You do have to fly to standards
with the CFI or he/she would be remiss in signing off the IPC.
Robert M. Gary wrote:
The IPC can consist of whatever you want to make yourself current.
The IPC tasks are very strictly defined by the instrument PTS task
table.
-Robert
Old February 9th 06, 09:15 PM posted to rec.aviation.ifr
Mark Hansen wrote:
Actually, the IPC is required 6 months after you lose currency.
Duh, how about a year AFTER the last thing you did that kept you current
either though the (6 apps, hold, vor track) or the last IPC you did.
I mean a year after your "lack of currency" clock started ticking which
of course is 6 months before your considered no longer current to fly IFR.
Old February 9th 06, 09:20 PM posted to rec.aviation.ifr
IR currency.
conditions.
controls.
Yes, I see that. I think I just had the wrong impression based on something
my instructor told me - and didn't question.
I won't bother with the details, as I'm convinced now that he was
wrong.
Thanks!
Sacramento, CA
Old February 9th 06, 11:20 PM posted to rec.aviation.ifr
That's true. In fact an IPC can often take less time than doing the 6
in 6 with a safety pilot. In fact, the entire instrument PTS is very
thin compared to the other PTSs. The items on the instrument PTS are
not numerous, just challenging.
-Robert, CFI
Old February 9th 06, 11:25 PM posted to rec.aviation.ifr
More of an FYI than a response to any particular post, but doing a
quick google on +ipc +pts, took me to some CFI's home page, with a nice
little layout of the IPC
Here's the link, if anyone is interested...
http://www.geocities.com/cfidarren/fr-ipc.htm
Best Regards,
Todd
OK, I'm off... Simon Robbins Rotorcraft 15 March 14th 05 01:44 AM
Does FAA respond to FAQ questions? Robert M. Gary Piloting 0 July 6th 04 11:22 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Accelerated spin questions John Harper Aerobatics 7 August 15th 03 08:08 PM
