sizing solar panel
Old February 16th 06, 12:38 AM posted to rec.aviation.soaring
Default sizing solar panel
If I want to maintain a 12 volt 7amp/h Battery with a solar cell panel
what rating would I need during flight, if after 4 hrs I wanted
to have a usable, not full, charge in my 12 Volt battery.
Right now, my as good as new battery is useless after 4 hours.
and what size would the panel be?
Udo
Old February 16th 06, 01:51 AM posted to rec.aviation.soaring
just did a search and I think I got it covered, still if some with
experience would like to comment please do.
Udo
"Udo Rumpf" wrote in message
Udo
Old February 16th 06, 04:55 AM posted to rec.aviation.soaring
what rating would I need during flight, if after 4 hrs I wanted to have
This suggests you are drawing about 1.5 amps from your battery, which is
very high, even for a glider with a transponder. Is that right? Can you
reduce the drain safely by turning something off?
It would have be about a 1 amp maximum output panel just to be sure of
getting 0.5 amps on average, which would leave ~2 amphours to the battery
after a 4 hour flight. About 1+ hours of use would remain at your 1.5 amp
drain. That's a rather large solar panel to mount on glider, or a rather
expensive one.
If you are really drawing 1.5 amps and can't reduce it, I'd suggest first
putting in another (or bigger) battery. Cheaper and easier, I think.
Eric,
As per manuals I draw about 1.1 amps without talking on the radio
I can fly for about 4 hours and I drop to 12 volts from fully charged
7 amp/h battery. Add an other 1.4 amps for transmit.
Regards
Udo
Old February 16th 06, 05:28 AM posted to rec.aviation.soaring
is very high, even for a glider with a transponder. Is that right? Can
you reduce the drain safely by turning something off?
battery after a 4 hour flight. About 1+ hours of use would remain at
your 1.5 amp drain. That's a rather large solar panel to mount on
glider, or a rather expensive one.
first putting in another (or bigger) battery. Cheaper and easier, I
think.
Eric,
I seem to recall your radio stopped working properly at 12 volts, even
though the battery still has half it's capacity left at that point. The
easiest thing might be to go to a 14 volt system by adding a 2 volt
battery instead of a solar panel. That assumes the radio is working
correctly and it is incapable of working below 12 volts.
Before putting a lot of money into a 1 amp or so solar panel, I'd
consider getting a new radio, which will draw less current, and work
until the battery is exhausted (not to mention the other advantages).
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old February 16th 06, 06:42 AM posted to rec.aviation.soaring
www.batteryweb.com/powersonic12vsla.cfm Look for a PSH-12100, ITS
12v AND 10.5 AMPS. Its the same size as a 7 amp and a 8.5 amp, just
slightly taller. # 711.
Old February 16th 06, 01:38 PM posted to rec.aviation.soaring
Udo,
When our Club's Orion arrived it apparently chewed through batteries at
a high rate. After some time, we found that the spec sheet for the
diode installed to protect against reverse polarity had a huge 1.2V drop
across it.
As a result, the charger wasn't charging to anywhere near full capacity
because the battery only saw 12.6V when the charger saw 13.8V.
Accordingly, it appeared as though the instruments were drawing much
more current than they were. It took quite a while to find the real
problem.
Does this fit your case?
In the course of troubleshooting, we also found the interesting fact
that the cheap $20 SLA chargers (usually a sealed black plastic box from
China) have target voltages which varied from 13.3V to 15.8V for the
sample we tested. 3 out of 5 were around 15V.
My DG has a factory fitted diode in the system with a 0.3V drop. The
manual specifies that a charger charging to 14.1V is needed to charge
the batteries completely. I suspect that a number of the debates on
batteries on this forum are related to diode voltage drops. My
electronic guru pointed out that ALL diodes had a forward voltage drop
and some are quite large.
Graeme Cant
Udo
Old February 16th 06, 01:42 PM posted to rec.aviation.soaring
Operation"
If you measure your actual current draw, and it really is 1.5 amps, consider
testing for a "partially" shorted wire somewhere!
A few strands could make a difference.
Hartley Falbaum
Georgia USA
Old February 16th 06, 02:36 PM posted to rec.aviation.soaring
To reduce voltage drop from a charger, when a diode is inserted, the diode
should be a shottky type diode. If 3 amps maximum current is sufficient, a
1N5822 will work fine. Those diodes are available at Radio Shack. Voltage
drop is about .3 volts.
In many cases, a "protection" diode is not needed when charging a system.
They simply prevent current from going the wrong direction when the charger
is not connected.
Solar panels may or may not require them. Many circuits show a diode in
series with a solar charging panel. The theory is that it prevents current
from reversing direction during darkness. In many cases, the diode is not
necessary and the instruction books are guilty of simply copying a circuit
without understanding it. The reason diodes are often not necessary in
solar panel charging systems is that the panel itself is a diode. I always
check with a ma meter, just to make sure.
I installed a 100 ma (.1 amp) panel on a friend's motorglider (no electrical
charging system or starter) and it has charged the battery for over a year
with no problem. He is an occasional user and not a contester, nor does he
fly many hours at a time.
If you consider a 12 volt storage battery as being fully charged at about
14.2 volts and unusable for your purposes at 12 volts, you can consider the
stored power available pretty much as a straight line with 14.2 as 100% and
12 as 0 %. That means that when the voltage is 13.1 volts, you have 50%
power available. Batteries, both rechargeable and non-rechargeable may
expect the voltage to go below 12 volts to achieve the rated amp hours, so
if 12 is your minimum, you may need to de-rate your battery. The
manufacturer should have a graph showing the actual capacity
available with the maximum and minimum voltage you have in your electrical
system.
Colin
Old February 16th 06, 02:43 PM posted to rec.aviation.soaring
is not connected.
Not connected to the AC power that is. When the charger is not connected to
the battery, current would not flow because there is no completed circuit.
Still early.
Colin
Old February 16th 06, 03:45 PM posted to rec.aviation.soaring
Udo
Udo,
Most battery manufacturers consider their battery to be depleted at
around 10-10.5 volts. I usually switch to my secondary battery when the
primary depletes to around 11.2 - 11.5V. I also agree with other
posters here that unless you have a transponder or something you should
not be drawing anywhere near 1.1 amps typically. In situ measurements
may be called for.
Larry
Solar Powered Round The World Flight Planned For 2009 Larry Dighera Piloting 7 March 14th 05 08:36 AM
Solar Powered Round The World Flight Planned For 2009 Larry Dighera Soaring 7 March 14th 05 08:36 AM
Why not a hinged panel? Jay Honeck Owning 22 March 8th 05 12:15 AM
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) Heiko Brandstaedter Simulators 0 October 7th 04 03:42 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 04:52 PM
