1984 Mooney M20K 231 for sale
Old February 15th 06, 11:36 PM posted to rec.aviation.marketplace,rec.aviation.owning,rec.aviation
Default 1984 Mooney M20K 231 for sale
I have a 1984 Mooney M20K 231 for sale. 2483 TTSN, 1415 SFRM. Dual Garmin
430s.
Please see http://www.madness.net/n57568 for specifications and tons of
pictures, and email me directly with any questions. Thanks for looking!
Vince
Old February 16th 06, 07:01 AM posted to rec.aviation.owning
("Vince" wrote)
430s.
How long have you owned it?
What are some specs on a 1984 Mooney M20K?
Speed in cruise, Fuel burn, Useful load, etc. Curious.
Any more 'insider' info would be fun. Thanks.
BTW, what you asking for it? :-)
Montblack
Old February 16th 06, 07:40 AM posted to rec.aviation.marketplace,rec.aviation.owning
Vince,
How did you find the 3 bladed prop to perform. Many in the Mooney
community seem to believe the 3 blade prop reduces cruise speed by
about 5 knots.
Old February 16th 06, 07:41 AM posted to rec.aviation.owning
Montblack,
The reason its called a 231 is because it is suppose to cruise at
231mph (I believe that is wide open throttle though).
-Robert Mooney owner
Old February 16th 06, 03:58 PM posted to rec.aviation.owning
On 15 Feb 2006 22:41:57 -0800, "Robert M. Gary"
Montblack,
The late model Mooneys (201, 231, 252) are definitely named by their
top speed in mph.
Here is a link to the performance section of the 231 POH.
http://lists.aviating.com/mooney/per...erAltitude.pdf
It appears that 231mph is achievable at approx 40" & 2700RPM, which
the turbo'd engine can achieve at 16k through 20k pressure altitude.
I doubt anyone would be willing to run the engine that hard as it is
very close to 100% power.
75% @ 20k ~= 220mph
75% @ 24k ~= 229mph
Old February 16th 06, 05:42 PM posted to rec.aviation.owning
"Nathan Young" wrote in message
Montblack,
top speed in mph.
75% @ 20k ~= 220mph
75% @ 24k ~= 229mph
Let's see: % of HP = GPH * 14.9, so figure what the power level.
It doesn't so much matter where the throttle is set (WOT works best), it's
the RPM (seondary) and the fuel flow (mixture) which is primary.
For example, in a 310HP engine, burning 14.5gph, you would be at 70% power.
Matt B.
Old February 16th 06, 07:09 PM posted to rec.aviation.marketplace,rec.aviation.owning
Supposedly a myth.
Maybe. However, before I became a Mooney owner my bird was an Arrow
with a 3 blade prop. In that configuration, it absolutely did slow it
down quite a bit. I know that Top Gun Aviation (a Mooney Service
Center) just purchased one of the "new designed" 3 blades for their
shop Mooney. They want to determine what the cost in speed may be. The
manufactor claims that the new designs aren't slower, but we'll see.
-Robert
Old February 17th 06, 03:48 PM posted to rec.aviation.marketplace,rec.aviation.owning
about 5 knots.
Supposedly a myth.
Members of Cardinal Flyers have reported cruise speed losses after conversion
to 3-blades. Some have reported ROC improvements and less noise. The
consensus runs against the conversion being worth it.
Dan
C-172RG at BFM
Old February 17th 06, 04:36 PM posted to rec.aviation.owning
Is this correct?
"Matt Barrow" wrote in message
power.
Matt B.
Old February 17th 06, 05:53 PM posted to rec.aviation.marketplace,rec.aviation.owning
"Dan Luke" wrote in message
about 5 knots.
Supposedly a myth.
conversion to 3-blades. Some have reported ROC improvements and less
noise. The consensus runs against the conversion being worth it.
Not only (far) less noise, but significantly decreased vibration due to
different airflow pulses
against the airframe.
It is also suggested that the miniscule speed loss (1-2%) can be adjusted
out by running higher RPM's that a two blade prop would turn into noise and
vibration.
Landing a Mooney Jon Kraus Owning 42 November 16th 04 08:00 PM
Landing a Mooney Jon Kraus Piloting 42 November 9th 04 08:53 PM
Landing a Mooney iain_hutchison Piloting 0 November 4th 04 03:38 PM
Mooney M20 K on Grass ? Andrew Boyd Owning 0 August 13th 04 04:00 PM
Loading luggage in other than Mooney Robert M. Gary Piloting 21 June 28th 04 07:23 PM
