#21
Pack a small amount of paper into the knob's shaft hole so that the knob
can't slide onto the shaft too far. Some DG knobs, if allowed to slide all the way onto the shaft, will hit the panel when you try to adjust the card. If there isn't enough "throw" before the knob hits the panel, it won't allow you to adjust the card. The set screw should hold it, but the paper trick makes it fool proof and relieves the pressure from the set screw. Jim "Dave" wrote in message ... Ummm.. make sure the Knob is not loose and turning freely. We had the same symptoms, loose knob slipped "in" on the shaft hard against the panel, so could not push the shaft in to uncage the gyro, so it coud not be "set". Slid knob back out to proper position on shaft, toghten set screw, fixed.. Maybe? Dave On Mon, 20 Feb 2006 22:33:53 -0600, "mbremer216" wrote: Well, it looks like my directional gyro just went belly up. When I went for a ride today, the setting knob was very sticky, and then suddenly not sticky at all as it now rotates freely and doesn't feel like it is engaging anything. The gyro card does not rotate with the knob. I have a Cherokee with a heading tracking Autocontrol III autopilot. What are opinions regarding having it rebuilt as opposed to replaced? Thanks Mike |
Thought about that one. The shaft turns with the knob and also goes in and
out. I was, at first hoping it was the knob. I have recently started some instrument training and when doind timed turns noticed quite a bit of discrepancy between the clock and the resulting turn (over 20 degrees). While I may not have been spot on in maintaining the turn rate via the needle & ball, there's no way I was that sloppy, particularly since the error was similar with turns in both directions. I'm just going to change it rather than fix it. Now the challenge is to find a replacement that won't break the bank. Thanks Mike "Dave" wrote in message ... Ummm.. make sure the Knob is not loose and turning freely. We had the same symptoms, loose knob slipped "in" on the shaft hard against the panel, so could not push the shaft in to uncage the gyro, so it coud not be "set". Slid knob back out to proper position on shaft, toghten set screw, fixed.. Maybe? Dave On Mon, 20 Feb 2006 22:33:53 -0600, "mbremer216" wrote: Well, it looks like my directional gyro just went belly up. When I went for a ride today, the setting knob was very sticky, and then suddenly not sticky at all as it now rotates freely and doesn't feel like it is engaging anything. The gyro card does not rotate with the knob. I have a Cherokee with a heading tracking Autocontrol III autopilot. What are opinions regarding having it rebuilt as opposed to replaced? Thanks Mike |
mbremer216 wrote:
I have recently started some instrument training and when doind timed turns noticed quite a bit of discrepancy between the clock and the resulting turn (over 20 degrees). While I may not have been spot on in maintaining the turn rate via the needle & ball, there's no way I was that sloppy, particularly since the error was similar with turns in both directions. I'm just going to change it rather than fix it. Now the challenge is to find a replacement that won't break the bank. Rmmmm? Maybe I'm just confused or you were unclear. This reads as if your timed turns aren't coming out on the right heading, so you're replacing your heading indicator. I hope I'm wrong. Dave |
I'm replacing the DG because the setting knob will no longer engage the
compass card. The DG is also behind the turns (turned at a rate slower than the mag compass). Also, it's pretty old and is probably past it's service life. Mike "Dave Butler" wrote in message news:1140790596.591398@sj-nntpcache-3... mbremer216 wrote: I have recently started some instrument training and when doind timed turns noticed quite a bit of discrepancy between the clock and the resulting turn (over 20 degrees). While I may not have been spot on in maintaining the turn rate via the needle & ball, there's no way I was that sloppy, particularly since the error was similar with turns in both directions. I'm just going to change it rather than fix it. Now the challenge is to find a replacement that won't break the bank. Rmmmm? Maybe I'm just confused or you were unclear. This reads as if your timed turns aren't coming out on the right heading, so you're replacing your heading indicator. I hope I'm wrong. Dave |
On Sat, 25 Feb 2006 09:18:22 -0600, "mbremer216"
wrote: I'm replacing the DG because the setting knob will no longer engage the Valid reason. compass card. The DG is also behind the turns (turned at a rate slower than Which could be quite normal. Mine, and most others, will at times even turn the opposite direction. Just a fact of life and physics. the mag compass). Also, it's pretty old and is probably past it's service life. If it still works it's not past a service life as I don't think they have one. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Mike "Dave Butler" wrote in message news:1140790596.591398@sj-nntpcache-3... mbremer216 wrote: I have recently started some instrument training and when doind timed turns noticed quite a bit of discrepancy between the clock and the resulting turn (over 20 degrees). While I may not have been spot on in maintaining the turn rate via the needle & ball, there's no way I was that sloppy, particularly since the error was similar with turns in both directions. I'm just going to change it rather than fix it. Now the challenge is to find a replacement that won't break the bank. Rmmmm? Maybe I'm just confused or you were unclear. This reads as if your timed turns aren't coming out on the right heading, so you're replacing your heading indicator. I hope I'm wrong. Dave |
Roger wrote: On Tue, 21 Feb 2006 11:41:55 -0700, Newps wrote: Denny wrote: Well, let me take you into IMC and fail everything but your altimeter, speedo, T&B and compass and I'll have you kissing that compass when you are back down... A DG is nice but it's nothing that will kill you if it goes bad in hard IMC... Who will ever look at the compass? The GPS runs on batteries. Just fly a ground track instead of a heading. GPS? You rely on a battery powered GPS? Only after ships power stops working, then yes. |
On 22 Feb 2006 07:55:53 -0800, "Denny" wrote:
You're fighting a losing battle my friend. *********************************************** * Yah, I'm a bit slow but I'm catching on.... The problem is that relying on all that new stuff can get you killed as can relying on any specific piece of technology, old or new. Over-the-years I've had just about any thing on the panel that can fail, do do. The only thing I've not had to have fixed has been the old compass and oil pressure gage. Mine happens to be a vertical card compass. I use GPS, but I maintain those "old" reliable skills. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com denny |
#28
On Tue, 21 Feb 2006 14:17:42 -0600, "Jim Burns"
wrote: After it was inspected and repaired, then reinstalled I should have junked it or went the rebuilt route (which we ulimately did) rather than pulling it for another inspection/repair. I have close to a 1000 hours on a rebuilt AI. The DG was rebuilt before I purchased the plane so I'd have to check the books to figure out how much time is on it. Still I lost it on one flight due to the filter. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I wasn't satisfied that the DG only lasted 16 months after a overhaul before it's problems started. That should have been my first clue. Then I had it inspected and informed that it was "just out of balance" and "everything else looked good". I should have only reinstalled it after convincing myself that if anything happens, the unit is history. Well, "anything" happened and instead of junking it, we stuck more $$ into it, only to be told that "everything looks good, doesn't tumble on our vibration table, I'd stick it back in". Round 1: $400 Round 2: $300 Round 3: Overhauled Exchange $663 Jim "Mark Hansen" wrote in message ... On 02/21/06 08:18, Jim Burns wrote: EdoAire Autopilot DG Overhauled Aug. 2004 Tits up Dec. 2005 (out of warranty) IRANed Dec. 2005 Operated properly for 7 hours then started spinning, wouldn't erect IRANed Dec. 2005 2nd time No problems found Re installed, worked fine on the ground, failed during initial takeoff Replaced with overhauled unit after talking to Century Instruments For the price of what we paid for removals, reinstalls, and IRAN's, THEN for an overhauled unit, we could have bought a new unit and had it installed then sold our core to a rebuilder. Lesson learned. First of all, I'm very sorry for your bad experience. It sounds like a nightmare. However, what lesson? That 'overhauled' will always cost you more in the long run? I don't see how that results in a lesson being learned, unless of course, I'm missing something (which is probably the case... ;-) ) It seems to me you had an atypical experience. The same could happen with a new component, couldn't it? Even if it's not as likely with new, the chance in either case of serious problems like this must still be pretty low. Might some argue that the reconditioned equipment is a safer bet, because the non-wearing parts have already been tested by in-service use, etc.? Jim -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
| Thread Tools | |
| Display Modes | |
| American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 11:46 PM |
| Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 10:45 PM |
| Dead Reckoning, with the 'a' | David Megginson | Piloting | 8 | August 11th 04 03:22 PM |
| Should Memorial Day and America's War Dead be commercialized? | Otis Willie | Naval Aviation | 0 | May 24th 04 03:29 AM |
| Should Memorial Day and America's War Dead be commercialized? | Otis Willie | Military Aviation | 0 | May 24th 04 03:29 AM |
