Physics Professor's Peer Reviewed Paper on WTC CONTROLLED DEMOLITIONS on 9/11
Old February 23rd 06, 02:45 PM posted to rec.travel.air,alt.disasters.aviation,rec.aviation.piloting,rec.aviation.military
Default Physics Professor's Peer Reviewed Paper on WTC CONTROLLED DEMOLITIONS on 9/11
Mike wrote in
On Thu, 23 Feb 2006 03:48:20 GMT, TRUTH wrote:
His arguments are based on scientific principles. They do not have to
be convincing, since scientific laws cannot be changed, such as the
Law of Increasing Entropy. Are you an engineer or physicist?
Yes, I am a structural engineer and registered PE.
How do explain THREE collapses at near free fall speed? First time in
history from fire!
It is called progressive collapse. This is when a smaller less
significant failure causes an overall greater failure.
Where did the energy come from to pulvarize concrete and office
furniture into particles of fine powder?
The concrete and other materials had a large amounts of potential
energy stored when they were raised to a higher elevation in the
building. BTW, you don't need to be an engineer to know this, you
need to have not slept through 6th grade science class.
Where did the force come to *evaporate* steel?
Steel doesn't evaporate. ASCE (an independent non-government
organization) determined from analysis that "The thinning of the steel
occurred by a high temperature corrosion due to a combination of
oxidation and sulfidation.
Why was there moltel metal and yellow-hot metal under the Towers (AND
BUILDING 7) weeks after 9/11? (Those colors are consistant with
thermite explosives.)
Fire. BTW it can be consistant with many things.
Also, why did the government hall away and destroy the evidence before
it could be properly analyzed?
See above about ASCE analyzing the steel.
Mike, you are a registered PE structural engineer?
Sir, in your professional, expert, experienced opinion, what caused this 47
story steel framed building to collapse?
http://911research.wtc7.net/talks/wtc/videos.html
Also, note these "squibs" from the SW corner
http://st12.startlogic.com/
~xenonpup/Flashes/squibs_along_southwest_corner.htm
  #32
Old February 23rd 06, 03:12 PM posted to rec.travel.air,alt.disasters.aviation,rec.aviation.piloting,rec.aviation.military
Default Physics Professor's Peer Reviewed Paper on WTC CONTROLLED DEMOLITIONSon 9/11
TRUTH wrote:
Dan wrote in newslgLf.22321$Ug4.11952@dukeread12:
be convincing,
Then forgive us for not being convinced.
since scientific laws cannot be changed, such as the Law of
Increasing Entropy.
Entropy applies here how?
No. Are you?
Evasion noted.
history from fire!
There weren't any collapses at near free fall speed. They were
considerably slower.
Wrong. Towers collapsed in 10 seconds maximum. Building 7 was about 7
seconds.
Do the math, the formula is D = 16T^2
The mass of the floors above. The formula is F = MA. Look it up.
Absurd and illogical. You cannot simply take a formula and plug the
information in and expect an accurate answer.
That's precisely what formulae are for. I assume you took some math
and science in school. What do you think they were trying to teach you?
Actually using simple formulae is exactly how it's done. It's done
repeatedly or plugged into another formula or both. Calculus simplifies
this, computers make it even easier. No matter how big the equation is
it is made up of smaller parts that can be worked into or out of the
picture. You have repeatedly told us you have no science background so
don't tell us who do how it is done. What is "absurd and illogical" is
your insisting you know better when you also say you don't.
Did you know Ke (kinetic energy)= 1/2mv^2 is an application of F = ma?
Buildings NEVER collapsed in that manner before, EXCEPT from controlled
demolitions.
The 21 story Mexico City building did. No matter how many times you
try to ignore it it did collapse that way. I haven't looked at every
single building collapse in history, neither have you, so I can't say
there are other examples or not.
Heat alone can do that. Metal DOES boil and become a gas at high
enough temperatures.
Desiel fuel burns no where near hot enough to melt steel. So, I repeat:
Jet fuel is NOT diesel. It is closer to kerosene. What keeps jet
engines from melting is selection of materials and bypass air. Jet fuel
CAN burn steel given enough oxygen and that's what happened. It is more
than apparent you don't know what "force" means since you don't use it
correctly here.
Wrong again, I have used thermite and it burns white hot and not
for
weeks. Thermite burns at too slow a rate to be used for demolition of
tall buildings. There were fires from broken gas lines. Yellow hot
steel is no where near "molten."
Forgive me, I gave the wrong color. (Jones paper gives the right
information though.) Perhaps you can explain where the energy came from
to cause steel (or iron) to get that hot.
I will say it again: there were fires from broken gas lines. Remember
how NYFD had to put them out before major excavation could begin?
before it could be properly analyzed?
I assume you mean "haul," now prove they did.
Dan, U.S. Air Force, retired
Oh, thank you for correcting my poor spelling.
Here's your proof:
BILL MANNING
EDITOR-IN-CHIEF, FIRE ENGINEERING MAGAZINE:
"$elling Out The Investigation" article quotes: "Such destruction of
evidence shows the astounding ignorance of government officials to the
value of a thorough, scientific investigation of the largest fire-induced
collapse in world history."
"Based on the incident's magnitude alone, a full-throttle, fully
resourced, forensic investigation is imperative"
"The federal government must scrap the current setup and commission a
fully resourced blue ribbon panel to conduct a clean and thorough
investigation of the fire and collapse, leaving no stones unturned."
full article: http://tinyurl.com/3h5mk
The article you cite is flat out wrong as is your suggestion the
salvage was deliberately destroyed before being properly analyzed. The
salvage was taken to Fresh Kills where each piece was forensically
examined before a decision was made to release or not. There is not
enough space nor requirement to keep every piece so that which has no
probative value was sold off.
  #33
Old February 23rd 06, 03:26 PM posted to rec.travel.air,alt.disasters.aviation,rec.aviation.piloting,rec.aviation.military
Dan wrote in news:IpjLf.23563$Ug4.13024@dukeread12:
to be convincing,
Increasing Entropy.
No. Are you?
Evasion noted.
in history from fire!
seconds.
you?
simplifies this, computers make it even easier. No matter how big the
equation is it is made up of smaller parts that can be worked into or
out of the picture. You have repeatedly told us you have no science
background so don't tell us who do how it is done. What is "absurd and
illogical" is your insisting you know better when you also say you
don't.
Actually, no it's not. When there are unknowns, they must also be taken
into acount. In you believe otherwise, then your education is faulty.
controlled demolitions.
That building was no more than 3 stories tall. Anyone with eyes can see
that. That tiny building did NOT pulvarise to dust.
NO STEEL FRAMED HI RISE BUILDING HAS EVER COLLAPES FROM FIRE PERIOD!
YOU are the one ignoring the evidence. So stop projecting it onto me.
repeat: Where did the force come to *evaporate* steel?
fuel CAN burn steel given enough oxygen and that's what happened. It
is more than apparent you don't know what "force" means since you
don't use it correctly here.
Instead of childishly insulting me, how about admitting that burning jet
fuel does not get hot enough to melt steel?
(AND BUILDING 7) weeks after 9/11? (Those colors are consistant
with thermite explosives.)
for
of tall buildings. There were fires from broken gas lines. Yellow
hot steel is no where near "molten."
from to cause steel (or iron) to get that hot.
Remember
Okay, if that case, show me some information proving that gas fires can
get hot enough to melt steel.
Also, explain how the gas fires got hot enough to cause 47 steel columns
to simultaniously sever.
Here's your proof:
BILL MANNING
the value of a thorough, scientific investigation of the largest
fire-induced collapse in world history."
Oh really. Show me just one article from a reputable source verifying
that.
NOTE: Fire Engineering is not a "newsstand" magazine. It is a
professional trade journal, for fire houses. I could assure you, the
article is 100% correct.
  #34
Old February 23rd 06, 04:06 PM posted to rec.travel.air,alt.disasters.aviation,rec.aviation.piloting,rec.aviation.military
TRUTH wrote:
Mike wrote in
history from fire!
No squibs or other explosive devices are shown.
  #35
Old February 23rd 06, 04:09 PM posted to rec.travel.air,alt.disasters.aviation,rec.aviation.piloting,rec.aviation.military
Dan wrote in news:RbkLf.23571$Ug4.14981@dukeread12:
TRUTH wrote:
Mike wrote in
to be convincing, since scientific laws cannot be changed, such as
the Law of Increasing Entropy. Are you an engineer or physicist?
steel occurred by a high temperature corrosion due to a combination
of oxidation and sulfidation.
this 47 story steel framed building to collapse?
Go visit an eye doctor
  #36
Old February 23rd 06, 04:10 PM posted to rec.travel.air,alt.disasters.aviation,rec.aviation.piloting,rec.aviation.military
TRUTH wrote:
Mike wrote in
The links above were not meant for you. I pasted your linked in the other
post where you asked me to do you the favor of doing so
  #37
TRUTH wrote:
Chad Irby wrote in news:cirby-8CA32E.22050922022006
@news-server1.tampabay.rr.com:
Meanwhile, actual building demolition experts say people like this are
full of ****.
Show me one piece of evidence where a demolition expert, or structural
engineer, demonstrates Jones' to be false
I gotta agree there.
I doubt they even know, or care, who he is.
  #38
Old February 23rd 06, 04:35 PM posted to rec.travel.air,alt.disasters.aviation,rec.aviation.piloting,rec.aviation.military
to be convincing,
Increasing Entropy.
No. Are you?
Evasion noted.
seconds.
you?
don't.
What do you think equations are for? Of course they are to solve for
unknowns. I never said otherwise. Apparently you are as weak on
communication as you are on science and math.
It was 21 stories before collapse.
Neither did WTC.
Prove it.
No, you are altering the test here. You never specified collapse due
to fire until now.
I might have had it been true. Besides, I have seen jet fuel/oxygen
burn through steel. It's all a mater of how it's burned. Let me try an
analogy you might be able to understand: a Coleman™ stove. If you pour
the fuel on the ground and light it you get a relatively cool flame. Now
run it through your stove. The gas generator is heated by the burner.
The gas generator turns the liquid fuel into a gas. The gas form burns
much hotter than the liquid form. The same was true at WTC, initially
the fire was relatively cool until it started sucking air in from
outside at a high rate, imagine a chimney effect, giving the fire a
higher oxygen burn rate. This is essentially a variation of how a jet
engine works. The exhaust gas temperatures are much higher than simple
burning liquid jet fuel. Now imagine another analogy: a kerosene lamp.
When you light the wick you get a low, dim flame. Put the chimney back
and the air around the flame heats up. This sucks in more air at a
higher rate than before which makes the flame burn hotter and brighter.
Now the same jet fuel that can burn hot enough to melt steel can also
burn cool enough to use in a cigarette lighter. Now you know where I
used to get free lighter fluid many moons ago when I smoked.
for
Remember
See above. Besides have you ever heard of oxygen/acetylene welding?
It melts steel. Acetylene is a hydrocarbon fairly close to natural gas
in energy. Know what the difference between an oxygen/acetylene welding
torch and an oxygen/acetylene cutting torch is? Without going into
detail the cutting torch burns more efficiently generating a higher
temperature which cuts the steel by vapourising it.
I never said it did. You asked about the hot steel AFTER the
collapse, remember? See above.
Here's your proof:
BILL MANNING
that.
Just as soon as you start citing reputable sources for your claims.
Then your assurance would be wrong. You also assured us Jones' paper
was peer reviewed so your assurances mean nothing to me. I used to be a
gunsmith and I found errors in trade journals.
  #39
Old February 23rd 06, 04:56 PM posted to rec.travel.air,alt.disasters.aviation,rec.aviation.piloting,rec.aviation.military
Dan wrote in news:6DkLf.23572$Ug4.8179@dukeread12:
have to be convincing,
Increasing Entropy.
No. Are you?
Evasion noted.
time in history from fire!
7 seconds.
up.
math
you?
done
the equation is it is made up of smaller parts that can be worked
into or out of the picture. You have repeatedly told us you have no
science background so don't tell us who do how it is done. What is
"absurd and illogical" is your insisting you know better when you
also say you don't.
taken into acount. In you believe otherwise, then your education is
faulty.
for
You call me weak? You're the one using not looking at all the data
ma?
you
say there are other examples or not.
Neither did WTC.
Prove it.
When I find the link, I will provide it. (Despite the fact that you
haven't provided ANY evidence of your own, other than the Mexico Ciy
collapse that was not caused by fire.)
due
to fire until now.
Take a look at the "FACTS" post that I posted a number of times. Fire has
NEVER caused a steel framed building to completely collapse. And
definitely not straight down, at near free fall speed, with accompanying
squibs and all!
high
jet fuel does not get hot enough to melt steel?
Now run it through your stove. The gas generator is heated by the
burner. The gas generator turns the liquid fuel into a gas. The gas
form burns much hotter than the liquid form. The same was true at WTC,
initially the fire was relatively cool until it started sucking air in
from outside at a high rate, imagine a chimney effect, giving the fire
a higher oxygen burn rate. This is essentially a variation of how a
jet engine works. The exhaust gas temperatures are much higher than
simple burning liquid jet fuel. Now imagine another analogy: a
kerosene lamp. When you light the wick you get a low, dim flame. Put
the chimney back and the air around the flame heats up. This sucks in
more air at a higher rate than before which makes the flame burn
also
Please provide a link where all that information can be verified by a
physicist, or similar expert. You might know about NORAD, but your USAF
background does not cover steel melting fires. Sorry.
not for
Remember
can get hot enough to melt steel.
welding torch and an oxygen/acetylene cutting torch is? Without going
into detail the cutting torch burns more efficiently generating a
higher temperature which cuts the steel by vapourising it.
How exactly does all this apply to the WTC?
columns to simultaniously sever.
I asked you numerous times how the 47 massive steel columns got severed.
In addition, how they got severed simultaneuosly, in both towers. I am
still waiting for that answer.
Here's your proof:
BILL MANNING
of evidence shows the astounding ignorance of government officials
to the value of a thorough, scientific investigation of the largest
a fully resourced blue ribbon panel to conduct a clean and thorough
unturned."
The salvage was taken to Fresh Kills where each piece was
forensically examined before a decision was made to release or not.
There is not enough space nor requirement to keep every piece so
that which has no probative value was sold off.
that.
If you don't consider Fire Engineering a reputable source, then your
thinking is not clear and there's nothing more I can do for you. Sorry
paper
a gunsmith and I found errors in trade journals.
  #40
Old February 23rd 06, 04:59 PM posted to rec.travel.air,alt.disasters.aviation,rec.aviation.piloting,rec.aviation.military
TRUTH wrote:
Mike wrote in
I suggest the same for you. What is shown is horizontal puffs of
smoke below the falling floors. They are puffs of smoke, not squibs.
Squibs and explosive devices are solid devices that explode when
triggered not puffs of smoke.
Physics Professor's Peer Reviewed Paper on WTC CONTROLLED DEMOLITIONS on 9/11 Darkwing Piloting 15 March 8th 06 02:38 AM
Physics Professor's Peer Reviewed Paper on WTC CONTROLLED DEMOLITIONS on 9/11 TRUTH Piloting 0 February 23rd 06 02:06 AM
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 11:46 PM
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 10:45 PM
