The Impossibility of Flying Heavy Aircraft Without Training
Old March 6th 06, 10:10 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Default lift, wings, and Bernuolli
In article c2OOf.597091$084.130237@attbi_s22,
Stella Starr wrote:
So in Larry Niven's Ringworld, when people swim through the ring of
atmosphere to the next Integral Tree, do they set it rotating ever so
slightly in the opposite direction?
Yes. If they were to keep swimming in the same direction.
(Livin' in a fantasy world since nineteen-sixty-mumblemumble....)
Alan Baker wrote:
No. It is balanced by the downflow eventually transferring its momentum
back to the earth.
Alan Baker
Vancouver, British Columbia
"If you raise the ceiling 4 feet, move the fireplace from that wall
to that wall, you'll still only get the full stereophonic effect
if you sit in the bottom of that cupboard."
  #302
Old March 6th 06, 11:23 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
This has all been very interesting, but there is a basic assumption
that seems to be glossed over.
I was thinking, that to really get anything out of all this,
shut the engine off!
Everybody has been _assumin'_ straight and level flight.
I suppose that's ok for academic discussion, but for learnin'
aerodynamics, let's just assume the engine quit and take it
from there.
L / D
Just a thought...
Richard
  #303
Old March 7th 06, 12:22 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
In article . net,
from there.
L / D
Just a thought...
Richard
It doesn't really make any difference.
In a constant glide, the aircraft now does have momentum with respect to
the earth, but it is *still* incurring the same forces.
Alan Baker
  #304
Old March 7th 06, 12:31 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Alan Baker wrote:
In article . net,
from there.
L / D
Just a thought...
Richard
Right.
But now we might actually get something from the discussion.
Like how much power is actually required for S&L?
Effects of speed on glide angle?
And, what happens when you get a wee bit too slow?
Or, if that's too boring...
What happens to the boundary layer?
Is it ticklish?
And what about those long and short bubbles?
  #305
Old March 7th 06, 12:51 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
wrote
Because the wing is not of infinite weight. The upper atmosphere in
fact =is= deprived of air while the airplane is in flight... that air is
squeezed down below the wing, increasing the pressure on the surface of
the earth, in an amount exactly equal to the weight of the airplane
(divided by the area of the earth).
I think that the downflow dispaces other air which flows up to
replace it--conserving momentum and mass.
I think I will create a new award. I'm not sure what the prize or trophy
will be yet.
I'm calling it "Rec.Aviation Geek of the Decade", or perhaps of "The
Century."
I am in total awe and amazement, that you and Jose have tied for this award,
based on how long you two have kept this amazingly boring subject alive. I
just CAN'T believe it !!!
Now, continue on, or not.
Please, use your restraint, and common sense. Use the "or not." g
Jim in NC
(mostly, using his right to use the "ignore thread" button! g
  #306
Old March 7th 06, 01:00 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
from there.
L / D
What is L? What is D?
That's the fundamental question being discussed. The engine (or the
earth's gravity) merely supplies the force. But once you introduce the
idea of gliding, you also need to address the things that gliders
address - ridge lift, thermals, messy stuff like that, which are all
ways of getting free energy from the sun.
Calm air, flat ambient earth, no engine, the airplane will descend.
Now explain to me how autogyros work.
Jose
Money: what you need when you run out of brains.
  #307
Well I'm really hoping that Jose tries the card thumbtack soda straw
thing.
FF
  #308
Old March 7th 06, 01:02 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Great discoveries are often made in the seventh decimal place.
Jose
  #309
Old March 7th 06, 01:06 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
thing.
Actually, I did try it and it didn't "work" (that is, the card didn't
float, which is what I think you expect to happen). I'm probably doing
it wrong so I'll keep at it. When I get it to work, I'll report what
happened and why (in newtonian terms) I think it did.
Jose
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 07:23 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Sport Pilot pilots not insurable? Blueskies Piloting 14 July 12th 05 06:45 AM
