Thrust Needed For Self Launching...
Old March 12th 06, 11:02 PM posted to rec.aviation.soaring
Default Thrust Needed For Self Launching...
Does anyone know (not a guess) how much thrust in pounds from a jet engine
would be needed to self launch a 1000 lb sailplane to 2500 AGL?
Or perhaps know a link whereby I can find the information or formula
needed so I can determine the answer myself.
I've looked ..googled..etc...can't find a thing.
I did read some where online that 3,600,000 joules would be needed.....but
can't find a conversion formula.
Thanks
Tom
Old March 13th 06, 01:27 AM posted to rec.aviation.soaring
1000 lbs at 25/1 Lift to drag needs 40 pounds of thrust to remain in
level flight. Any thrust above that number would result in either
climb or a faster level speed. So in theory, using those numbers,
40.0000001 pounds of thrust would get the job done - eventually. 100
pounds of thrust (2 large model turbines) would probably give a
reasonable rate of climb for a self-launch.
Rather than do all the math just download a demo version of X-plane,
add a jet to the glider and see what happens. www.X-plane.com
Just remember that the simulation is no better than the data fed into
it............................
Leon McAtee
Old March 13th 06, 08:48 AM posted to rec.aviation.soaring
In article
outaviation.com,
I've done calculations for rocket engines before, but jets are
essentially the same.
http://groups.google.com/groups?selm=an_595515430
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
Old March 13th 06, 09:27 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
[quote=tinman2006]Does anyone know (not a guess) how much thrust in pounds from a jet engine
Hi Tin person, remember-
Close data is always time consuming so, the jet would only be TOO BIG if:
1- it doesnt fit
2- its too heavy
otherwise its TOO SMALL!
like fuel, you have only got too much when your on fire
Bagmaker :-)
Old March 13th 06, 11:33 AM posted to rec.aviation.soaring
The Calif A21SJ with a max t/o mass of roughly 1700 pounds has 200 pounds of
thrust.
A DG800 with approx 1000 pounds also has 200 pounds of thrust.
That gives decent climb rates, but in the first place it allows to
accelerate to max climb speed on grass before you hit the fence on the far
side.
"Tony Verhulst" wrote in message
The above 25/1 occurs at only one airspeed - faster or slower will require
more power. To self launch, you need, minimally, to accelerate to that
speed. Oh yeah, ya wanna launch from grass too? So, how much power do you
need? I dunno, but suspect that it will be a lot more than 40.0000001
pounds of thrust.
Tony V.
Old March 13th 06, 05:45 PM posted to rec.aviation.soaring
Bob Carlton converted a Silent to jet power (and it is anything but
silent!):
http://www.silentwingsairshows.com/jet.html
He uses two 45 lb thrust model a/c jets. The engines are small and
light, but it burns about 18 gallons per hour. For a 1000 lb glider you
will need 4 of these puppies, pushing fuel burn to 36 gal/hr (my DG-400
burns 5 gal/hr). Going with less than 4 means a longer takeoff run (a
LOT longer!). How long? Try F = M*A, or A = F/M, where F is the USEABLE
accelerating thrust, M is the mass of the glider and A is acceleration.
Remember that for useable acceleration you need to subtract off the
rolling resistance from engine thrust (pull your glider with a rope and
a BIG fish scale to measure this). Four engines also increases the risk
of engine failure by a factor of 4. Of course, you could still climb
with only 3, just slower.
Also, the 25:1 glider ratio doesn't apply because you have the
additional drag of the engines and pylon. Jets help here because of
their small size, but 4 of them will probably knock your glide angle to
under 20:1.
Tom Seim
Richland, WA
Old March 13th 06, 11:18 PM posted to rec.aviation.soaring
Also keep in mind that these model engines have a TBO of 25 hours.
Mike Schumann
silent!):
under 20:1.
Tom Seim
Richland, WA
Old March 14th 06, 01:38 AM posted to rec.aviation.soaring
On Sun, 12 Mar 2006 17:02:46 -0500, "tinman2006"
Thanks
Tom
I have a nice spreadsheet to do these calculations but I'm not yet
prepared to release it to the world.
Try Googling "aircraft performance" and you will get some references
which let you do the calculations. Prof Ilan Kroo at Stanford's aero
engineering course outline has some useful stuff. It really is just
high school physics.
My conclusions are that a thrust/weight ratio of 0.1 is the minimum
you want for self launch off smooth hard surfaces. This means for a
500Kg(1100lb) glider you need a total of 50Kg or110lbs of thrust.
If you go to about 0.14 you will be able to handle short dry
grass.(two 35Kg - 77lb thrust engines)
Even the 50Kg thrust on two engines will give a positive rate of climb
on one engineat 500Kg. This is for a Ventus C but the results are not
that sensitive to glider type as long as we are talking about modern
composite gliders at the same weight
The surprising thing until you understand what is going on is that the
best rate of climb speed is around 100KIAS. Faster for the larger
engines and the curve is quite flat. It doesn't matter much whether
you climb at 85 or 130 knots.
SE best rate is at around 75 to 90 knots depending on engine thrust.
Fuel for a 2000 foot launch is estimated at less than 4Kg(5 liters) of
Jet A1/jet oil mix (at SFC of 1.4)
Retrieve is on one engine at about 50% thrust at 90 to 100KIAS and we
should get at least 150 nm range in this mode if we start with 50
liters(40Kg) of fuel.
These numbers are preliminary and will depend on engine test results.
Hopefully coming soon.
The Ventus currently has a TOP module. I have the thrust/airspeed
curve for that.. Static thust is 750 Newtons(about 73.5Kg) rapidly
reducing to about 56KG at just over 20 knots so with two 35Kg engines
we will have more thrust during almost the entire takeoff run. With
the TOP the aircraft flys at 400Kg (no water)and at sea level is
reasonably lively and takes off easily on grass.
I also have about 20 hours in the Jet Caproni for comparison and
having seen Bob Carleton's films and a log of takeoff (thanks Bob) I'm
convinced this concept is a winner.
I expect the takeoff to be a little slower at first but the jet thrust
drops off much slower with airspeed (only about 10% at 100Knots) so
the latter stages of takeoff (where the distance is being used up)will
be much better. I project being able to make JAR 22 takeoff
performance at 500Kg at sea level on hard surface(15m at 1.3Vs 500m
from start of roll).
Mike Borgelt
The Impossibility of Flying Heavy Aircraft Without Training Immanuel Goldstein Piloting 365 March 16th 06 02:15 AM
The Impossibility of Flying Heavy Aircraft Without Training Immanuel Goldstein Home Built 331 March 10th 06 02:07 AM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 09:04 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 08:03 AM
how many pounds thrust needed ? cdubya Soaring 10 September 14th 03 05:28 AM
