#161
On Fri, 17 Mar 2006 03:53:25 GMT, Tank Fixer
wrote: In article , on Thu, 16 Mar 2006 08:13:33 GMT, TRUTH attempted to say ..... What is there to discuss? It is already admitted. Jones' is a physicist with a PhD. That is nice that he has a PHD in physics. That was not my point since he is neither an engineer nor materials scientist. Two separate and only marginally related fields. Although I have agreed in several posts of my own with Tank Fixer and other posters who have objected to Truth's argument that because Jones holds a Ph. D. in physics his hypothesis cannot be questioned, I did want to address the question below, which is similar to those I've seen from other posters. Since he has this PHD in physics is he qualified to say discuss oceanography ? My answer would have to be yes. At best, a Ph.D. is a degree that teaches you how to do scholarly research. There are many Ph.D.'s who have made important contributions in fields outside the one in which they were initially educated. As an example using the two fields about which Tank Fixer asked, D. James Baker holds a Ph. D. in experimental physics and was Administrator of the National Oceanic and Atmospheric Administration during the Clinton Administration. For my money, the real issue is a bit more nuanced. A Ph.D. in one field also gives one an intimate knowledge of the questions one should ask in that field and the tools available to seek the answers. The real risk for Ph.D.'s as they go out of their initial disciplines is that they will miss key questions or be ignorant of key tools. Some Ph.D.'s exercise an appropriate degree of caution as they venture outside their fields, others don't. A major beef that structural engineers have with Jones is his reliance on a single equation for movement due to gravitational acceleration in a vacuum, apparently ignoring tools that the engineers have developed to analyze the complexities of failure in a large structure. Much of Jones' argument boils down to "it fell too fast" without any consideration of "how fast would it be expected to fall?" I have stated before that Jones' arguments should be evaluated on their merits. His credentials do not entitle those arguments to any special deference, but neither do they disqualify those arguments because his discipline is less relevant to the issue than some other disciplines. Regards, George ************************************************** ******************** Dr. George O. Bizzigotti Telephone: (703) 610-2115 Mitretek Systems, Inc. Fax: (703) 610-1558 3150 Fairview Park Drive South E-Mail: Falls Church, Virginia, 22042-4519 ************************************************** ******************** *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
#162
"Dr. George O. Bizzigotti" wrote in message
news ![]() On Fri, 17 Mar 2006 03:53:25 GMT, Tank Fixer wrote: In article , on Thu, 16 Mar 2006 08:13:33 GMT, TRUTH attempted to say ..... What is there to discuss? It is already admitted. Jones' is a physicist with a PhD. That is nice that he has a PHD in physics. That was not my point since he is neither an engineer nor materials scientist. Two separate and only marginally related fields. Although I have agreed in several posts of my own with Tank Fixer and other posters who have objected to Truth's argument that because Jones holds a Ph. D. in physics his hypothesis cannot be questioned, I did want to address the question below, which is similar to those I've seen from other posters. Since he has this PHD in physics is he qualified to say discuss oceanography ? My answer would have to be yes. At best, a Ph.D. is a degree that teaches you how to do scholarly research. There are many Ph.D.'s who have made important contributions in fields outside the one in which they were initially educated. As an example using the two fields about which Tank Fixer asked, D. James Baker holds a Ph. D. in experimental physics and was Administrator of the National Oceanic and Atmospheric Administration during the Clinton Administration. I'm sorry to have to disagree with you, George. As you said, *at best* a Ph.D. is a degree that teaches you *how* to do scholarly research - it does not demonstrates that you actually havedone scholarly research. So unless Jones has actually done the research on oceanography he is no more qualified discuss it than any non-Ph.D. As I've seen in the past there are those who have Ph.D's who seem to believe their word should be taken at face value merely on the strength of them having a Ph.D. This seems to be what Prof. Jones is doing, or, at the very least, what his "supporters" are trying to do for him. Others, such as yourself, at least offer explanation and supporting text whether your conclusion is ultimately right or wrong. I dare say your version of Prof. Jones's paper would be very different even if your ultimate conclusion was the same. For my money, the real issue is a bit more nuanced. A Ph.D. in one field also gives one an intimate knowledge of the questions one should ask in that field and the tools available to seek the answers. The real risk for Ph.D.'s as they go out of their initial disciplines is that they will miss key questions or be ignorant of key tools. Some Ph.D.'s exercise an appropriate degree of caution as they venture outside their fields, others don't. A major beef that structural engineers have with Jones is his reliance on a single equation for movement due to gravitational acceleration in a vacuum, apparently ignoring tools that the engineers have developed to analyze the complexities of failure in a large structure. Much of Jones' argument boils down to "it fell too fast" without any consideration of "how fast would it be expected to fall?" Prof. Jones has not demonstrated knowledge even within his discipline - for a Physics Ph.D to content himself arguing "it fell too fast" is more than sufficient proof that something is amiss. I have stated before that Jones' arguments should be evaluated on their merits. His credentials do not entitle those arguments to any special deference, but neither do they disqualify those arguments because his discipline is less relevant to the issue than some other disciplines. In my opinion, his credentials most certainly do disqualify those arguments if all he offers as qualification are his credentials and nothing more. Unfortunately, he's really not doing anything different than many other "scientists", as I discovered a long time ago. Had he chosen a different argument, one more in vogue and with stronger political backing, he'd certainly have more than a few dozen supporters around the world. At the very least, had he offered some evidence for his current argument, distasteful as it is, he might be seen as possibly contributing to our understanding of what happened. As it is, he's just another bozo wasting a Ph.D. Paul Nixon |
#163
On Fri, 17 Mar 2006 07:42:47 GMT, mrtravel wrote:
Johnny Bravo wrote: On Fri, 17 Mar 2006 03:53:39 GMT, Tank Fixer wrote: So you are approaching this from a predetermined point of view. Just the very same thing you accuse anyone who disagrees with you of. I would say you have the common sense of a house fly, to be charitable. Not very charitable to house flies. Doesn't it feel weird when you think they are watching you? Flies are an interesting topic for r.t.a, since their eyes are wired to their wings and they are very good fliers. I'm posting from r.a.m where they haven't come up with a really good miltiary use for flies yet. Maybe if they ever create a small enough anti-matter warhead. ![]() |
#164
Johnny Bravo wrote:
On Fri, 17 Mar 2006 07:42:47 GMT, mrtravel wrote: Johnny Bravo wrote: On Fri, 17 Mar 2006 03:53:39 GMT, Tank Fixer wrote: So you are approaching this from a predetermined point of view. Just the very same thing you accuse anyone who disagrees with you of. I would say you have the common sense of a house fly, to be charitable. Not very charitable to house flies. Doesn't it feel weird when you think they are watching you? Flies are an interesting topic for r.t.a, since their eyes are wired to their wings and they are very good fliers. I'm posting from r.a.m where they haven't come up with a really good miltiary use for flies yet. Maybe if they ever create a small enough anti-matter warhead. ![]() Flies can be used to bug enemy facilities. Dan, U.S. Air Force, retired |
#165
Johnny Bravo wrote: On Wed, 15 Mar 2006 04:08:30 GMT, "Wake Up!" wrote: WTC burned for more than 7 hours while being fed about 6,000 gallons of diesel. Tell me about the 6,000 gallons of diesel! Was it in a storage tank? Was it in the airplane? Were was the diesel fuel? |
#166
by Tank Fixer Mar 16, 2006 at 04:34 AM
This brings to mind a line from a famous Katherine Hepburn movie, " The Loons, the Loons......" What is the title of the movie? It sounds good. |
#167
On 17 Mar 2006 11:28:46 -0800, lynn wrote:
Johnny Bravo wrote: On Wed, 15 Mar 2006 04:08:30 GMT, "Wake Up!" wrote: WTC burned for more than 7 hours while being fed about 6,000 gallons of diesel. Tell me about the 6,000 gallons of diesel! Was it in a storage tank? Was it in the airplane? Were was the diesel fuel? In storage tanks in WTC 7, there to power generators for the New York City Office of Emergency Management command center which was located on the 23rd floor of the building. At least one source says there were two tanks, each with a capacity of 11,690 gallons, so there would have been quite a bit more than 6,000 gallons of diesel fuel in the building unless the tanks were only between a quarter and a third full. ljd |
#168
lynn wrote:
Johnny Bravo wrote: On Wed, 15 Mar 2006 04:08:30 GMT, "Wake Up!" wrote: WTC burned for more than 7 hours while being fed about 6,000 gallons of diesel. Tell me about the 6,000 gallons of diesel! Was it in a storage tank? Was it in the airplane? Were was the diesel fuel? It was in a storage tank at WTC7 How many jets do you know that use diesel to fly? |
#170
on Fri, 17 Mar 2006 07:02:18 GMT, Johnny Bravo attempted to say ..... On Fri, 17 Mar 2006 03:53:39 GMT, Tank Fixer wrote: So you are approaching this from a predetermined point of view. Just the very same thing you accuse anyone who disagrees with you of. I would say you have the common sense of a house fly, to be charitable. Not very charitable to house flies. No ****.. -- When dealing with propaganda terminology one sometimes always speaks in variable absolutes. This is not to be mistaken for an unbiased slant. |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 11:46 PM |
| Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 10:45 PM |
| ~ 5-MINUTE VIDEO OF BUSH THE MORNING OF 9/11 ~ | B2431 | Military Aviation | 0 | March 27th 04 05:46 AM |
