Propellers
Old March 29th 06, 12:41 AM posted to rec.aviation.homebuilt
Default Propellers
I want to run my engine (ford v-6) this summer for various tests and I
want some sort of prop. What do most people use for props when testing
at this stage? I was thinking of glueing together 2 or 3 fir 2x6's or
using a laminate beam (leftovers from a remodeling project) and carving
some airfoil shape. Seems like it should work if it is balanced. Of
course I don't want to sling a blade down the taxiway or through my
neighbors hangar door. Anybody offer some suggestions? Thanks.
David Woolery
Old March 29th 06, 09:13 AM posted to rec.aviation.homebuilt
Default Propellers
"Philippe Vessaire" wrote
A square wood beam,
aera= a*a
diam=15*a
You find the power with this formula:
P=0.0532 * (diam/450)^5 * (rpm/1000)^3
with diam in mm
rpm in revolution / mn
or
diam=((P/0.0532) * 10^9 * 450^5 / rpm^3 ))^0.2
a=diam/15
I you want check 180hp @ 3800rpm
diam = 1026mm a = 68.4mm
Is the area in the formula the cross sectional area, side of the beam area,
surface area, or what? More information is needed, please.
Jim in NC
Old March 29th 06, 02:23 PM posted to rec.aviation.homebuilt
Default Propellers
where do you enter the size of the thickness of the square?
"Philippe Vessaire" wrote in message
A square wood beam,
aera= a*a
diam=15*a
with diam in mm
or
a=diam/15
If you want check 180hp @ 3800rpm
area, surface area, or what? More information is needed, please.
the beam is diam*a*a.
for the exemple, a square 68 x 68 length 1026.
Pub: http://www.slowfood.fr/france
Philippe Vessaire Ò¿Ó¬
Old March 29th 06, 11:00 PM posted to rec.aviation.homebuilt
Default Propellers
("Philippe Vessaire" wrote)
from Michel colomban (cricri, MC100, MCR01 designer)
"We're not worthy. We're not worthy."
Montblack :-)
Old March 30th 06, 02:41 PM posted to rec.aviation.homebuilt
Default Propellers
On 28 Mar 2006 14:41:50 -0800, "
David Woolery
When I was ready to test my Ford V6, I bit the bullet and bought an
IVO Magnum prop. It's ground adjustable and all three blades adjust
simultaneously by cranking a large threaded cylinder in the hub. That
way you can flatten out the pitch so that the engine revs up to it's
maximum rpm while not moving.
I was unable to get the engine to rev past about 3,100 rpm without
repitching from the initial setting. I was reluctant to hold that
power setting for very long anyway as I was basically blowing things
off the walls behind me in the car port, and the prop was sucking sand
off the driveway and pitting the prop tips.
Corky Scott
Counter rotating propellers Raoul Military Aviation 24 September 21st 04 06:59 AM
New Company selling Airplane Propellers for Experimental, Display and Air Plane Pieces Inc Owning 8 September 18th 04 06:02 PM
Aero Composites Propellers Badwater Bill Home Built 26 June 18th 04 06:30 AM
Missing propellers Benny Simulators 1 March 18th 04 08:18 PM
