CAD drawing for DG instrument panel...
Old April 6th 06, 07:14 PM posted to rec.aviation.soaring
Default CAD drawing for DG instrument panel...
Before I draw up my own, I'm wondering if anyone out there has a CAD
drawing for a DG instrument panel (non-motorglider, 300, 600, 800S, and
possibly 100/200 panels should all be usable). I want to use an NC
machine to cut a new panel face for my DG-600. If anyone has a drawing
for any panel with correct standard instrument holes (altimeter, in
particular), that would also be helpful...
Thanks,
Marc
Note: remove REMOVE from email address...
Old April 6th 06, 09:34 PM posted to rec.aviation.soaring
Try this one, Marc:
http://www.dg-flugzeugbau.de/Data/instrument-panel.zip
Old April 7th 06, 12:05 AM posted to rec.aviation.soaring
That was easy...........any tips on where to dind a CAD drawinf of a
panel for Ventus C (lift up) ?
Cheers
Mark
Old April 7th 06, 12:14 AM posted to rec.aviation.soaring
Here is a link to M&H and V2C panel.
http://www.mandhsoaring.com/Panels/Panel_2b.pdf
Bob
Old April 7th 06, 12:19 AM posted to rec.aviation.soaring
JS wrote:
Try this one, Marc:
Thanks, I did have that, but I was hoping someone had something that
they had verified was dimensionally accurate...
Marc
Old April 7th 06, 08:12 AM posted to rec.aviation.soaring
Thanks,
Marc
Marc,
I've got a DG-600 non motor and a buddy of mine & I (more him than me)
cut a panel on his CNC mill last season. We used I think .090
aluminum . We used the old fiberglass panel for a templett, cut the
outline, used a hand brake to bend the lower mounting flange, the upper
and side flanges to secure the pod cover. If there is enough interest
he's willing to cut more of these panels and can cut to your specs. I
had him cut 3 large holes, 80mm in the top row and 2 rows of 57mm
below plus 4 circuit breaker holes and 1 master switch hole .
you can contact me at r.barry at sbcglobal dot net.
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 03:41 AM
Instrument panel labelling options John Galban Home Built 12 November 18th 04 11:42 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 06:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
