T? or F? Acetone In Fuel Said to Increase Mileage
Old April 16th 06, 01:58 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default T? or F? Acetone In Fuel Said to Increase Mileage
Montblack wrote:
Has this one been around the block a few times?
It was an interesting read.
http://www.pureenergysystems.com/new...00069_Acetone/
"Readily-available chemical added to gas tank in small proportion
improves the fuel's ability to vaporize completely by reducing the
surface tension that inhibits vaporization of some fuel droplets."
http://toyotaownersclub.com/forums/i...howtopic=44575
Chat room chat about acetone - mostly diesel cars.
This is for diesels mostly ...and mogas WITHOUT alcohol in it. A few
ounces/10 gallons is all you use.
Montblack
go ahead try it. see how long your seals last. Acetone is in the same
family as Methyl Ethyl Ketone (MEK).
Michelle
Old April 16th 06, 03:11 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Michelle
So Michelle, are you out west, yet?
We want to hear Michelle's Montanna Maule Mountain Flying Reports!
Old April 16th 06, 03:19 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Capt. Geoffrey Thorpe wrote:
"Montblack" wrote in message
"Readily-available chemical added to gas tank in small proportion improves
the fuel's ability to vaporize completely by reducing the surface tension
In gasoline engines, unburned Hydrocarbons amount to about 1% of the total
fuel, and most of those come from crevices such as the gap around the piston
above the top ring, and around the spark plug - the compression and pressure
rise pushes the mixture into these spots where the flame front is quenched.
The next largest source is a thin layer that is quenched at the cylinder
walls from the heat loss to the metal.
I don't have the numbers handy for diesels, but I'm reasonably confidant
that the percentage isn't a lot different even if the sources are different
(over rich areas in the fuel spray generate soot due to inadequate air and
some of the mixture around the fringe of the spray is too lean to burn).
The fact of the matter is that the moon landings are fake, the alien
autopsies are real, and the thousands of engineers that work for all the
auto companies all around the world (that look at fuel sprays and
combustions with lasers, high speed cameras, optically transparent engines
of all types, computer modeling, etc.) are completely unaware of potential
fuel consumption improvements like this one.
Geoff
It does work or at least helps. I tried to use it after adding
magnets, the little carburetor mini turbos, water injection etc. but
when I found that every time I drove the car, the gas tank was
overflowing I had to quit.
Harry K
Old April 16th 06, 02:44 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Michelle
John,
I am on my way west right now.
I officially started west Thursday. I am making several stops in Ohio.
Including the factory that built my travel trailer.
Next stop after that will be Jay and Mary's. Looks like that will be
Wednesday night or more.
Next planned stop Mount Rushmore. Maybe Devil's tower and then into Montana.
Then onto Missoula.
My airplane is at my old boss getting an annual. It will probably be
done in mid to late may....
Michelle
Old April 17th 06, 02:50 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
If you are near Columbus, OH, email me privately.
The BARNSTORMER is closed, perhaps we can sit down for coffee or
something.
eroodATrrohio.com
make the necessary substitution
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
"Tanks on both" checklist item Koopas Ly Piloting 46 December 12th 03 03:42 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
