Hi Peter,
Looking at the kfc225 computer unit schematic, there is just one CPU (68hc16) and no watchdog.... No watchdog? Ouch. How did they ever get this certified? Today I've discovered that once the kfc-225 is in level flight and holding altitude, it doesn't use the gray code data from the encoding altimeter - it uses its own internal encoding air pressure sensor. This rules out the altimeter problem, and narrows it down to the computer unit, or very few other things like the input from the altimeter subscale pot (which it still uses). Maybe that airpressure sensor has a problem. Either EMI or maybe the mounting location isn't as good as for the regular altimeter. Can the KFC-225 altitude annunciator be used to see if the unit's altimeter goes on the fritz? The problem is that the ability of any ground based engineers to diagnose the product is very limited, due to the really dumb firmware. Well, they could blast it with RF in a screened room. It is standard procedure for any med, AV or other critical gear before type cert. I have found pretty much any EMI problem in the screen room provided I could have the room for at least a day. But they have to test to more than the usual 10V/m field strength. And I still think Socata should do a courtesy fix on that oil pressure gauge and take care of the paperwork. Regards, Joerg http://www.analogconsultants.com |
Hi Peter,
I agree; DC servo brushes do last a very long time; generally years of continuous operation. There was nothing wrong with the brushes in that roll servo; it was the power amp which went up in smoke... Looks like a "suboptimal" power amp design. Electronics should not blow just because of excessive actuation. I guess with all the regs you aren't allowed to replace the busted part yourself but have to let the service folks sell you a refurb or new version plus labor. BTW, the clamp ferrite cores I mentioned the other day might still be pretty useful to diagnose an EMI problem. You can't leave them in there during flight but they are really handy to try out things on the ground, running the engine, keying the mike and so on. Regards, Joerg http://www.analogconsultants.com |
Hi Peter,
No watchdog? Ouch. How did they ever get this certified? Easy, general aviation autopilots are permitted to fail at any time, without a warning, in any way whatsoever. Wow. They'd never let us get away with that in medical electronics. Even after a defibrillator hit many systems must come back to normal operation within a prescribed time frame. The servo clutches are supposed to be always possible to overpower, and the pitch *trim* subsystem is supposed to warn the pilot if the trim has been running out of control (because an excessively out of trim condition might require more yoke force to overpower than a pilot can physically manage). But I think those are the only certification requirements for TSO. I knew about the servo clutches, without override the airplane would probably become uncontrollable if the AP fails to disengage for some reason. But I still can't believe that the amplifiers blow. Regards, Joerg http://www.analogconsultants.com |
"Dan Luke" wrote in message
... "Joerg" wrote: Wouldn't the pilot feel if the auto pilot issued lots of servo repositionings? I am not a pilot but I could imagine that would make for a pretty uncomfortable flight. At least for the passengers. Hmm, good question. Still, it might be possible that rapid, very small repositions could be imperceptible. I was just taking a wild shot at this one. -- I read somewhere that the F-16 is so unstable that a human can't fly it without the computer control. I'd think that means it makes corrections faster than a human can, but it's making corrections to a known airframe, I guess. I'd think they'd want the response time of an autopilot to be fairly slow so it doesn't do abrupt stuff - but then it really wouldn't be able to handle weather. Cheers! Rich |
Rich Grise wrote:
"Dan Luke" wrote in message ... "Joerg" wrote: Wouldn't the pilot feel if the auto pilot issued lots of servo repositionings? I am not a pilot but I could imagine that would make for a pretty uncomfortable flight. At least for the passengers. Hmm, good question. Still, it might be possible that rapid, very small repositions could be imperceptible. I was just taking a wild shot at this one. -- I read somewhere that the F-16 is so unstable that a human can't fly it without the computer control. I'd think that means it makes corrections faster than a human can, but it's making corrections to a known airframe, I guess. I'd think they'd want the response time of an autopilot to be fairly slow so it doesn't do abrupt stuff - but then it really wouldn't be able to handle weather. Cheers! Rich Yes, this is true of all modern fighters. If you watch movies of a takeoff or landing, you will notice the ailerons and horizontal stabilizers fluttering all over the place in what is pretty much straight flight. |
Hi Peter,
Looks like a "suboptimal" power amp design. Electronics should not blow just because of excessive actuation. I guess with all the regs you aren't allowed to replace the busted part yourself but have to let the service folks sell you a refurb or new version plus labor. That's correct; also I have not been able to find the schematic of the KFC225 servos anywhere. I have found out that there is no service manual as such. One could design an exact functional replica easily enough but frankly I have more pressing things to do ![]() Would be a nice biz opportunity though if the legal side is properly covered. If this problem is widespread people would be willing to pay a premium for a servo that doesn't give up. You don't have to design it yourself. I remember a muffler maker in Europe who created an exhaust set for a popular car that wouldn't corrode out in just a few years. It cost a lot more but still the muffler replacement sales of the car manufacturer then dropped substantially. BTW, the clamp ferrite cores I mentioned the other day might still be pretty useful to diagnose an EMI problem. You can't leave them in there during flight but they are really handy to try out things on the ground, running the engine, keying the mike and so on. Yes, I could try placing some on the wires close to the oil pressure gauge amplifier; that would not require any paperwork. The clamp-on versions (just for ground tests) are often available at Radio Shack. But usually only the large ones that still have the toolbox type metal drawer shelves. Then when it works you could use real cores but this often means re-doing at least one connector unless you select a very large core (they come up to two inches O.D.). Regards, Joerg http://www.analogconsultants.com |
Julie wrote:
Rich Grise wrote: "Dan Luke" wrote in message ... "Joerg" wrote: Wouldn't the pilot feel if the auto pilot issued lots of servo repositionings? I am not a pilot but I could imagine that would make for a pretty uncomfortable flight. At least for the passengers. Hmm, good question. Still, it might be possible that rapid, very small repositions could be imperceptible. I was just taking a wild shot at this one. -- I read somewhere that the F-16 is so unstable that a human can't fly it without the computer control. I'd think that means it makes corrections faster than a human can, but it's making corrections to a known airframe, I guess. I'd think they'd want the response time of an autopilot to be fairly slow so it doesn't do abrupt stuff - but then it really wouldn't be able to handle weather. Cheers! Rich Yes, this is true of all modern fighters. If you watch movies of a takeoff or landing, you will notice the ailerons and horizontal stabilizers fluttering all over the place in what is pretty much straight flight. But it is only straight and level flight because of all of the control surface "fluttering!" Matt |
"Peter" wrote in message
... In the two years from new I have had perhaps a dozen failures. It's not someone leavnig their phone on in flight is it? That's been attributed to APs going a bit funny on more than one occasion. Paul |
| IMC without an autopilot | Jon Kraus | Instrument Flight Rules | 101 | April 18th 04 08:17 PM |
| KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 03:01 AM |
| ALTRAK pitch system flight report | optics student | Home Built | 2 | September 22nd 03 12:49 AM |
| Looking for a home for C130 autopilot amplifier... | tongaloa | Home Built | 0 | August 18th 03 07:44 PM |
| Kinda OT but... Trying to flog a Sperry SP 20 autopilot servo ampfor C130... | tongaloa | Home Built | 0 | August 8th 03 08:45 PM |
