![]() RAM wrote: "Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message ... "RAM" wrote in message news:wWV0g.930487$xm3.207853@attbi_s21... It appears then that the rocket is the link in the "system" that is most likely to degrade with time. Given a choice (and assuming I needed it), I'd rather have a system with a questionable rocket than none at all!! There are other names for a questionable rocket. One that comes to mind is bomb. That's a valid point, although I've never heard of a solid fuel rocket in a ballisticaly deployed parachute "exploding". I believe that it the event of an instantaneous and total ignition of the charge (which you alude to) the container would fail long before an explosive pressure could be generated. I think the issue of rockets that are "old" is the previously mentioned oxide which forms resulting in a misfire. A cow-orker and his brother used to build and launch model rockets in Williams Bay, Winsconsin. Two of them, using off-the-shelf solid propellant motors blew up on the launch pad. Both incidents occurred in the dead of Winter. He thinks the manufacturer of the solid motors recommends against use below some critical temperature. One supposes that the BRS makers have taken such effects into consideration. But it is not an unreasonable concern. Besides, if you use the bang chute and it fails the particulars of the failure mode are probably of little consequence. Don't most manufacturers repack the chute and replace the rocket for a fee? -- FF |
The very early chutes were deployed with what amounts to a shotgun shell,
with a big rifled slug. I don't know how well that worked or didn't. They must have had a reason to start using rockets. Anyway, I have a whole box of WW2 vintage 30-06 ammunition that still works fine. I find myself wondering if any of those first chutes are still around... |
ups.com... ... A cow-orker and his brother used to build and launch model rockets in Williams Bay, Winsconsin. Two of them, using off-the-shelf solid propellant motors blew up on the launch pad. Both incidents occurred in the dead of Winter. He thinks the manufacturer of the solid motors recommends against use below some critical temperature. One supposes that the BRS makers have taken such effects into consideration. That's a common failure mode for black powder rocket motors (e.g. Estes motors). IIRC, the grain shrinks away from the case and you have too much surface exposed which causes it to burn faster and generate more pressure than the case can withstand. If I were to guess, I would say that the rockets used in the balistic 'chutes is more likely an Ammonium Percloric (spelling? ain't got a clue) based propellent with a rubber binder. They seem lest susceptable to this particular problem. You could ask over on rec.models.rockets... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
NASA and Diversity | DILLIGAF | Piloting | 12 | February 18th 06 05:41 PM |
IF I HAD A ROCKET LAUNCHER | X98 | Military Aviation | 7 | August 13th 04 09:17 PM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Ballistic chute saves 4 souls | Bob Babcock | Home Built | 28 | April 27th 04 09:29 PM |
Rocket Launching of Gliders | Jim Culp | Soaring | 0 | September 7th 03 06:52 PM |
