#21
"M" wrote in message oups.com... That's one way to to do it. Bonanza are a lot more fuel efficient than a 182. I just had a trip last weekend in my 75 AA5. 420nm buring 27.58gal of autogas, about 15.2 nmpg. That's very good for a production 4-seater. TN B36 (IO-550): 418nm (Montrose-Lincoln, NE), 185kts, 19kt tailwind, 12,500 feet, 32.5 gallons 100LL, 60 LOP; TT 2hrs 19min. |
"Matt Barrow" wrote in message ... "M" wrote in message oups.com... That's one way to to do it. Bonanza are a lot more fuel efficient than a 182. I just had a trip last weekend in my 75 AA5. 420nm buring 27.58gal of autogas, about 15.2 nmpg. That's very good for a production 4-seater. TN B36 (IO-550): 418nm (Montrose-Lincoln, NE), 185kts, 19kt tailwind, 12,500 feet, 32.5 gallons 100LL, 60 LOP; TT 2hrs 19min. Ugh: Kearney, not Lincoln. |
That depends on whether there's an airport selling mogas near your home base. For example there're quite a few in midwest, right in the corn country: http://www.chouby.com/apps/autogas.html B A R R Y wrote: M wrote: The best "mod" you can get to make fuel cost more bearable is the autogas STC, if you're lucky enough to own a model that can get the STC, and you can get ethanol free autogas. How great is that mod when you need to get 30-40 gallons into the plane? Do you land at a gas station? G Even 20 is a lot to carry around in portable containers. |
Yes a TCM 200 hp IO-360-A3B6D with no GAMI's. I usually cruise 5-6k 24
squared and 20-30 LOP. Matt Barrow wrote: "Jon Kraus" wrote in message .. . Third I am now learning and practicing everything I can about Lean of Peak (LOP) operations in order to save money on fuel. http://www.advancedpilot.com/index.html - expensive ($1000), but worth every penny Save gas, but more importantly, your engine. (see below) I have found that in cruise I can save many gallons-per-hour by twisting the red knob until the EGT's peak and then get to 10-20 degrees on the other side of peak temperatures. I know that this will not work for everyone but for my IO-360 it gives me a cool, smooth running engine that is only drinking 9.5 GPH. At what MP? Throttle setting? Altitude? http://www.avweb.com/news/columns/182045-1.html Yes, cool and smooth...but possibly with excessive internal pressure. Red Box = No Fly Zone At and below about 60% power, there is no red box. At about 65% power, 100ºF ROP to Peak. At about 70%, 125ºF ROP to 25ºF LOP. At about 75%, 180ºF ROP to 40ºF LOP. At about 80%, 200ºF ROP to 60ºF LOP http://www.avweb.com/news/columns/182084-1.html Have higher fuel prices forced you to adjust your operations? Fuel here is $4.15, up from $3.45 so it translates to about $11 more an hour. Considering our hourly DOC & Reserve is around $135 an hour, $11 is minor. We did cancel a optional trip to the "Big City" for shopping. I'm sure that over the years when fuel prices have peaked, folks have made changes, but since I am a new owner (working on our second year) it is my first experience at spiking prices. So what say you? LOP is your best bet. IIRC, the Mooney is running a TCM? If so, GAMIjectors. |
M wrote:
That depends on whether there's an airport selling mogas near your home base. This is probably why many of us don't see the advantage. G |
How do you get 30.5" at 12.5K w/o a turbo?
I have a 180hp (C/S prop) C-172F with the lyc O-360 and I burn and plan
on 9 gph. Why are you at 11? I run 2300 rpm and 22". I believe that give me 9 gph. Ross Doug Vetter wrote: Newps wrote: Or just buy a more efficient plane. I sold my 182 and got a Bonanza. I'm burning a lot less gas, approx 40%, than when I had my 182. Amen. Would you mind talking some sense into my partner? We have a perfect opportunity to buy a F33 from a friend in the next hangar over. Pristine aircraft, casual sale (so no tax liability here in NJ), just needs some avionics work. It does 178KTAS on ~15GPH, while we burn 11GPH in the 172/180HP doing 115KTAS on a good day. Ugh. My kingdom for a little common sense. -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
#28
Jon Kraus wrote:
: Have higher fuel prices forced you to adjust your operations? I'm sure : that over the years when fuel prices have peaked, folks have made : changes, but since I am a new owner (working on our second year) it is : my first experience at spiking prices. So what say you? Sold my airplane. -- Aaron C. |
#29
Jon Kraus wrote:
snip Have higher fuel prices forced you to adjust your operations? I'm sure that over the years when fuel prices have peaked, folks have made changes, but since I am a new owner (working on our second year) it is my first experience at spiking prices. So what say you? I alter my weekly commute to include a fuel stop at an airport where fuel is about $1.60 (US) cheaper per gallon than either my home airport or my destination airport. Once there, I fill the Bonanza's mains and tip tanks to capacity. I also reduced my Angel Flights by about 25%. -- Peter |
#30
I have concidered GAMI's but since I get my engine to run smooth and
cool LOP I didn't think the cost would be worth it. On the Mooney owners list we have some very knowledgable folks from GAMI that participate in the lists and have told me that 20-30 LOP at 70% will be no detonation issue at all... Matt Barrow wrote: "Jon Kraus" wrote in message .. . Yes a TCM 200 hp IO-360-A3B6D with no GAMI's. I usually cruise 5-6k 24 squared and 20-30 LOP. In calculating off the top of my head, you're running about 70% (your's is 200 HP?); see the chart below. Have you considered GAMI's? Try this: 12.5K, 185kts, 14.5gph (30.5"/2350 RPM); smooth as silk, even at idle. Matt Barrow wrote: "Jon Kraus" wrote in message m... Third I am now learning and practicing everything I can about Lean of Peak (LOP) operations in order to save money on fuel. http://www.advancedpilot.com/index.html - expensive ($1000), but worth every penny Save gas, but more importantly, your engine. (see below) I have found that in cruise I can save many gallons-per-hour by twisting the red knob until the EGT's peak and then get to 10-20 degrees on the other side of peak temperatures. I know that this will not work for everyone but for my IO-360 it gives me a cool, smooth running engine that is only drinking 9.5 GPH. At what MP? Throttle setting? Altitude? http://www.avweb.com/news/columns/182045-1.html Yes, cool and smooth...but possibly with excessive internal pressure. Red Box = No Fly Zone At and below about 60% power, there is no red box. At about 65% power, 100ºF ROP to Peak. At about 70%, 125ºF ROP to 25ºF LOP. At about 75%, 180ºF ROP to 40ºF LOP. At about 80%, 200ºF ROP to 60ºF LOP http://www.avweb.com/news/columns/182084-1.html Have higher fuel prices forced you to adjust your operations? Fuel here is $4.15, up from $3.45 so it translates to about $11 more an hour. Considering our hourly DOC & Reserve is around $135 an hour, $11 is minor. We did cancel a optional trip to the "Big City" for shopping. I'm sure that over the years when fuel prices have peaked, folks have made changes, but since I am a new owner (working on our second year) it is my first experience at spiking prices. So what say you? LOP is your best bet. IIRC, the Mooney is running a TCM? If so, GAMIjectors. |
| Thread Tools | |
| Display Modes | |
