Cabin Class?
Old May 7th 06, 05:51 AM posted to rec.aviation.piloting
Default Cabin Class?
The one that makes the most sense to me, is the one about everyone entering
though the same door, and going forward between the seats, to get to the
pilot's seats.
So a 747 is not cabin class?
-Robert
Old May 7th 06, 06:16 AM posted to rec.aviation.piloting
OK, I'll bite. How does one get to the pilot seats in a 747?
Jim in NC
Old May 7th 06, 06:58 AM posted to rec.aviation.piloting
Pressurized, Baron 58P, Beech Duke, Mooney Mustang, Cessna
P210, not cabin class, Duke comes close except it is small.
Cabin class [?] that are not pressurized, DC 3, B25
conversion, Lockheed LoadStar, Cessna Caravan, Beech 18.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Morgans" wrote in message
| "Frank Ch. Eigler" wrote
| Perhaps the main operational difference is whether or
not the cabin is
| pressurized.
everyone entering
to get to the
| pilot's seats.
| Jim in NC
Old May 7th 06, 06:59 AM posted to rec.aviation.piloting
And probably an enclosed potty...
ps.com...
| Cabin class means you can get up and walk around in
flight.
| -Robert
Old May 7th 06, 07:00 AM posted to rec.aviation.piloting
Years and years of training and experience.
747?
| Jim in NC
Old May 7th 06, 07:03 AM posted to rec.aviation.piloting
"Jim Macklin" wrote in message
seated, same for a 421C, same for a lot of airplanes that
are called "cabin class" by a sales department that is
trying to sell a charter.
The 400 series Cessna and several other similar craft have been defined as
cabin-class for years not only by sales departments, but by operators and
feds, too, each of which carries as much or more legitimacy than your cited
article, which is naught more than someone else's sales pitch. Nice try.
Stand-up headroom would be a valid standard to start with, except that you'd
be about 50 years late in applying it.
Old May 7th 06, 07:04 AM posted to rec.aviation.piloting
"Frank Ch. Eigler" wrote in message
Perhaps the main operational difference is whether or not the cabin is
pressurized.
Then the venerable and mighty DC-3 would not be cabin-class.
  #28
Old May 7th 06, 07:09 AM posted to rec.aviation.piloting
Starting from the ground, you climb two flights of access steps to reach the
main deck door. Once inside the craft, you climb a third flight to reach
the upper deck, turn right (usually), pass the galley, heads, emergency
egress door, and enter the flight deck. Variations on the theme if you're
flying the freighter version, but the structure's about the same. I think
it probably qualifies as cabin-class.
  #29
Old May 7th 06, 07:16 AM posted to rec.aviation.piloting
Through a choice of several doors. Everyone does not enter the same
door unless the airport is very, very old and unable to handle multiple
doors.
  #30
Old May 7th 06, 07:50 AM posted to rec.aviation.piloting
the main deck door. Once inside the craft, you climb a third flight to
reach the upper deck, turn right (usually), pass the galley, heads,
emergency egress door, and enter the flight deck. Variations on the theme
if you're flying the freighter version, but the structure's about the
same. I think it probably qualifies as cabin-class.
If you enter like the passengers, from the jetway, how do you get there?
Even this aside, a little common sense says that a 747 is cabin class,
without having to look at other definitions? g
Jim in NC
Class E or Class G - another one of those that makes you go 'hmmmmm' JT Piloting 10 February 27th 06 07:41 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 01:29 AM
