Antares 18S Maiden Flight
Old May 31st 06, 01:39 PM posted to rec.aviation.soaring
Default Antares 18S Maiden Flight
Hi All - I just received the following press release from Lange
Fleugzeugbau:
Maiden flight ANTARES 18S
The first ANTARES 18S made its successful maiden flight Sunday May
28th, 2006. The youngest member of the ANTARES-family of sailplanes
then was put to the acid test during several test flights at the home
airport of Lange Flugzeugbau in Zweibrücken (Germany). In its first
few flights, the sailplane clearly exceeded the development team's
expectations of gentle and nimble handling, and the test pilots decided
to start flutter and spin testing the same day.
The first flights of the ANTARES 18S have also shown that the
aerodynamic design, aiming for outstanding glide performance especially
at middle and high speeds, has yielded the expected results without
compromising on pilots comfort. The remaining flight testing will be
performed rapidly in the next months.
Unlike her larger sister, the self launching electrical glider ANTARES
20E, the ANTARES 18S has been designed as a pure glider for the
18m-class and can be retrofitted or ordered as a self sustainer, the
ANTARES 18T.
This glider is on its way to Sweden to fly in WGC, where everyone hopes
it will stop raining some day...
Best Regards, Dave
Old June 1st 06, 03:03 AM posted to rec.aviation.soaring
The 18T sustainer would be the sinky kind.
For clean quite smooth electric go for the 20E !
See ya, Dave
ANTARES 18T.
Would that be one of those stinky old technology internal combustion
sustainers, or a clean quiet smooth electric sustainer?
Old June 1st 06, 04:51 AM posted to rec.aviation.soaring
They're all kinda sinky after you extend them.
Note to Self: Buy lotto ticket.
Shawn
Old June 1st 06, 08:51 AM posted to rec.aviation.soaring
And the reason for that is given he
http://www.lange-flugzeugbau.de/engl...u/menu-akt.htm
The engine could be smaller but the battery pack almost the same size
as for the 20E would make it a *very* heavy 18m glider.
Regards
Marcel Duenner
Old June 1st 06, 06:46 PM posted to rec.aviation.soaring
From the Antares site:
"Building a self-sustainer utilizing electrical propulsion is currently
not possible, because in order to achieve the range required for a
self-sustaining glider, the size of the battery-pack would have to be
comparable to the pack installed in the Antares 20E. This is contrary to
the basic idea behind a self sustaining glider, which is to provide a
very economical way of staying aloft."
I think it is odd they accepted the range limitations of an electric
system for the 20E, which has about 1/3 the powered range my ASH 26 E,
but weren't willing to accept a similar range limitation for a
sustainer. I suggest a sustainer that could climb 3000' on it's battery
would be enough for a majority of pilots, and this would allow a
significantly smaller battery to be used.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old June 1st 06, 10:18 PM posted to rec.aviation.soaring
Hi Eric,
Good point. I agree. I think they are missing the boat by going to a gas
engine. It is so contrary to the clean, quiet, simple to operate, reliable
system in the Antares 20E.
I wish I could afford one!
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
the basic idea behind a self sustaining glider, which is to provide a very
system for the 20E, which has about 1/3 the powered range my ASH 26 E, but
weren't willing to accept a similar range limitation for a sustainer. I
suggest a sustainer that could climb 3000' on it's battery would be enough
for a majority of pilots, and this would allow a significantly smaller
battery to be used.
Operation"
Old June 1st 06, 10:29 PM posted to rec.aviation.soaring
See? They probably decided that they need to sell a couple of them to
survive. BTW, the Antares flies sweetly as glider, as I hear from a
friend who can afford one. And isn't *that* the main criteria for a glider?
Stefan
Old June 1st 06, 10:51 PM posted to rec.aviation.soaring
A glider that flies sweetly is a joy, but that criteria is pretty much
irrelevant if you can't afford to fly it...
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 07:31 PM
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 05:24 AM
