Gauge of tubing???
Old June 4th 06, 08:10 PM posted to rec.aviation.homebuilt
Default Gauge of tubing???
I"m familiar with the use of 'gauge' when describing sheetmetal.
I'm looking at 43.13 where it discusses welded patch repair. It says
make the patch out of material one gauge greater than that of the base
metal.
So I measure the base metal tubing (.035), go to the Inet and look up
a gauge chart and find that .035 lies between two gauge measurements.
And of course tubing suppliers talk in decimals, not gauge.
Faced with this difference in units of measurement, what approach do
you take? - Mike
Old June 4th 06, 09:15 PM posted to rec.aviation.homebuilt
metal.
you take? - Mike
I can't answer your question for certain (I'm not qualified). But-
I want to point out sheet metal gauge depends on the material (steel,
aluminum, etc). In other words, there are different charts for
different kinds of sheet metal (which is entirely different from wire
gauge sizes). I figure you know this, not everyone does. The Aircraft
Spruce catalog has this material referenced at the front of the metal
section. AC43.13 doesn't seem to have this info.
Anyway, I know what I'd do- to be conservative I'd pick the larger
measurement and go up one size higher than that. Of course that would
add even more weight
Old June 4th 06, 10:13 PM posted to rec.aviation.homebuilt
you take? - Mike
You fall back on the 'accepted practices' rule.
'Gauge' as applied to SEAMLESS TUBING was usually defined as follows:
11ga = .125" wall thickness
13ga = .093"
16ga = .063"
18ga = .047"
20ga = .035"
22ga = .028"
As applied to your situation, you would select tubing having a wall
thickness of .047" for the repair.
The table offered above does NOT agree with various gauge-vs-thickness
charts in several particulars; some list 12ga as equal to .093 and
18ga is often shown as .050. Unfortunetely, many historic definitions
of seamless tubing pre-date the availability of SAE 4130 and cite
diameter & wall for MILD STEEL tubing that is no longer available, such
as half-inch x .0375" wall (ie, '20 ga' according to a seamless tubing
manufacturer of that era).
-R.S.Hoover
Old June 5th 06, 03:05 PM posted to rec.aviation.homebuilt
On Sun, 04 Jun 2006 22:52:50 GMT, cavelamb
you take? - Mike
13ga = .093"
16ga = .063"
18ga = .047"
20ga = .035"
22ga = .028"
-R.S.Hoover
Just what I needed - Thanks - Mike
Just for the record, that's Thanks, VeeDubber...
no it is thanks - mike
mike was the guy saying thanks.
perfectly plain to me. ....and no doubt veedubber and mike.
if you do a search and replace to put a newline in place of the
hyphen I'm sure the penny will drop for you as well.
Stealth Pilot :-)
Old June 5th 06, 05:46 PM posted to rec.aviation.homebuilt
you take? - Mike
13ga = .093"
16ga = .063"
18ga = .047"
20ga = .035"
22ga = .028"
-R.S.Hoover
Stealth Pilot :-)
Oh **** off.
Old June 6th 06, 01:32 PM posted to rec.aviation.homebuilt
you take? - Mike
13ga = .093"
16ga = .063"
18ga = .047"
20ga = .035"
22ga = .028"
-R.S.Hoover
There are a number of different gauge systems and they have
differing ideas as to thickness vs. gauge number. Six of them he
http://www.constructionwork.com/reso...17bc2a4aac71b0
Aluminum gauges: http://www.engineersedge.com/gauge.htm
Dan
Oil Pressure Gauge Troubleshooting Kyle Boatright Home Built 10 October 19th 05 04:04 AM
Cherokee Fuel Gauge Mike Spera Owning 6 July 15th 05 05:30 AM
Any sources of thin walled 4130 tubing in northern CA? mike Home Built 3 February 6th 05 03:20 PM
Carb Temperature Gauge fly_the_skies Home Built 6 January 14th 04 03:32 PM
Regarding Oil Temp Gauge and Line Repairable rkane33 Owning 0 September 14th 03 09:54 PM
