First IFR flight after checkride
Old August 26th 04, 06:24 PM
john smith
Dave Butler wrote:
john smith wrote:
As I understand it, you have already obtained your IFR clearance, you
are just being held for release until the other inbound/outbound
traffic is assured to be clear of the airspace. You have your IFR
clearance, you depart VFR to provide the
separation/obstruction/terrain clearance.
Similar to a VFR ON TOP clearance. You are IFR, but you are at a VFR
altitude and assume separation/obstruction/terrain clearance until
such time as you elect to operate at an IFR altitude or encounter IFR
conditions.
That's not what the snippet you posted says. Have you read it?
How about this from
http://www.faa.gov/atpubs/ATC/Chp4/atc0403.html
4-3-9. VFR RELEASE OF IFR DEPARTURE
When an aircraft which has filed an IFR flight plan requests a VFR
departure through a terminal facility, FSS, or air/ground communications
station:
a. After obtaining, if necessary, approval from the facility/sector
responsible for issuing the IFR clearance, you may authorize an IFR
flight planned aircraft to depart VFR. Inform the pilot of the proper
frequency and, if appropriate, where or when to contact the facility
responsible for issuing the clearance.
PHRASEOLOGY-
VFR DEPARTURE AUTHORIZED. CONTACT (facility) ON (frequency) AT
(location or time if required) FOR CLEARANCE.
b. If the facility/sector responsible for issuing the clearance is
unable to issue a clearance, inform the pilot, and suggest that the
delay be taken on the ground. If the pilot insists upon taking off VFR
and obtaining an IFR clearance in the air, inform the facility/sector
holding the flight plan of the pilot's intentions and, if possible, the
VFR departure time.
  #33
Old August 26th 04, 08:24 PM
Dave Butler
john smith wrote:
How about this from
OK.
  #34
Old August 28th 04, 01:29 AM
Andrew Sarangan
john smith wrote in news:59IWc.33911$cT6.15495
@fe2.columbus.rr.com:
Dave Butler wrote:
I've heard of VFR climbs and VFR descents while on an instrument flight
plan, but VFR departure is a new one on me. Is that published
nomenclature, or something you made up?
I typed the text from the new Instrument Procedures Handbook
FAA-H-8261-1), page 2-32, last night and posted it. It doesn't seem to
have come through. I will retype it later today and try posting it again.
Unless you are flying a DP, most departures are done under VFR - you see
and avoid obstacles instead of relying on a published procedures.
I have received IFR clearances with a DP, but sometimes I have declined the
DP because I had not reviewed it ahead of time. In such cases I get a VFR
depature. But I am technically under IFR except for the departure.
  #35
Old August 28th 04, 01:32 AM
Andrew Sarangan
Dave Butler wrote in
Going home, it was pretty much the same song, played backwards. But
instead
of picking up our clearance in the air, we made the small mistake of
waiting
for it on the ground. We waited almost 10 minutes at the hold line
with the
Hobbs turning like a dervish, and were just about to call and say
we'd be departing VFR and pick up the clearance later, when they
called us. Lesson
learned. But all in all, one of the most fun flights I've had in a
long time
and a big confidence builder.
Why not just accept the clearance and request a VFR departure?
You are on an IFR flight plan, you are just accepting responsibility
for separation on the takeoff and departure. After the conflicting
traffic is clear, the flight becomes normal IFR.
flight plan, but VFR departure is a new one on me. Is that published
If another airplane is flying an approach into the airport, you cannot
depart IFR. In those cases ATC may assign a VFR departure. You see an avoid
the other airplane until you reach your cruising altitude.
  #36
Old August 30th 04, 03:00 PM
Dave Butler
Oh, my.
It's not up to me to decide whether I can depart IFR because "another airplane
is flying an approach into the airport". I either get a clearance, or I don't.
AFAIK ATC can't "assign a VFR departure". Please show me where it says they can
do that.
*I* can decide to depart VFR rather than wait for a clearance. That is not an
IFR operation. In that case I am VFR, until I obtain a clearance, whether that's
at my cruising altitude or some other altitude.
*I* can request a VFR climb while on an instrument clearance. "VFR climb" is
defined terminology. "VFR departure" is not.
Others say a VFR climb can be requested right from the airport surface, with the
issuance of an instrument clearance for departure. I've never seen/heard this
done, but I don't see any regulatory reason why it should not be possible, and I
defer to those who say they have done it.
Dave
  #37
Old August 30th 04, 03:03 PM
Dave Butler
Most of my departures for flights that will conductred under IFR are done under
IFR, whether I am flying a DP or not.
How do you get a VFR departure? What is the specific request and clearance
terminology?
Do you just mean you depart VFR and then get a clearance after you're airborne?
In that case, you're not "under IFR" until the clearance is issued, technically
or otherwise.
  #38
Old August 30th 04, 03:37 PM
Newps
they can do that.
Right, the pilot has to ask for it.
with the issuance of an instrument clearance for departure. I've never
seen/heard this done, but I don't see any regulatory reason why it
should not be possible, and I defer to those who say they have done it.
A VFR climb comes in handy in the mountains. Busy places like Salt Lake
see a lot of VFR climbs by the airlines so they don't have to get
vectored to hell and gone for their climb.
  #39
Old August 30th 04, 06:18 PM
john smith
avoid the other airplane until you reach your cruising altitude.
Oh, my
airplane is flying an approach into the airport". I either get a
You already have an IFR CLEARANCE, you just do not have an IFR RELEASE.
They are not the same thing.
Hence you can request a VFR DEPARTURE with an IFR CLEARANCE.
This is a spacing issue.
The controller is obigated to hold you on the ground or at a fix until
they have assurance that other IFR traffic in the vicinity (usually
around an uncontrolled airport) is clear or the requisite spacing is
attained.
  #40
Old August 30th 04, 07:22 PM
Dave Butler
john smith wrote:
cannot depart IFR. In those cases ATC may assign a VFR departure. You
see an avoid the other airplane until you reach your cruising altitude.
Oh, my
attained.
OK, this will be my last missive on this subject. I don't think you're getting
it, and I guess you don't think I'm getting it. This is not leading anywhere.
When you request a VFR DEPARTURE (emphasis yours), you are not requesting an IFR
procedure. You're just departing VFR. When the controller grants your request,
he/she's not bestowing any priveleges on you that you didn't have already. You
can always choose to depart VFR. When you depart VFR you're not IFR.
Now, if you request a VFR CLIMB (emphasis mine) that's different. A VFR climb is
an IFR procedure.
Rebut if you like. I'm finished with this conversation.
Good day.
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 08:16 PM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 08:44 PM
Sim time loggable? [email protected] Instrument Flight Rules 12 December 6th 03 08:47 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 10:03 PM
