New Garden Airshow (Chester County PA) Photos:
Old June 14th 06, 08:35 PM posted to rec.aviation.homebuilt
Default Warning-Real Homebuilder Item For Sale!!!
Rip wrote:
RST Engineering wrote:
Ya know, I was just going to shine this little thing on until you came
back with the netnanny crap.
Stick around folks, I'll show you how to make one that will handle a
dozen amps at any liveable temperature and failsafe -- Kitplanes
December issue.
By the way, is your failure mode open or closed? I'm not about to put
a $5 part in between my supply line and radio unless the failure will
turn the radios on.
"Rip" wrote in message
. com...
Jim Logajan wrote:
[posted and mailed]
Rip wrote:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4647303457
You should probably confine your posts to rec.aviation.marketplace
or risk suspension of your account with eBay. According to eBay
(http://pages.ebay.com/help/usenet_policy.html) they state:
Thanks, NetNanny. Review "appropriately".
Gee, Jim. I'm breathless with anticipation! A dozen amps! And it will
fit in a 1 x 1/2 inch cylinder? I think you missed the point of my
little item. I see a lot of homebuilders running out of panel space,
or adding switches after the fact for non-critical items like intercoms
and engine analyzers, that could stand a little delay after master
switch power up. I never intended for it to be used on radios, critical
engine instruments, etc.
On the other hand, many items (such as those mentioned above) don't need
to be on the avionics bus. So you splice my timer in the power supply
line after the fuse or circuit breaker. It handles the protection and
power up for you, while you get settled in during engine warm-up, etc.
I think an item like this geared specifically towards homebuilders is
more than appropriate for a group titled "rec.aviation.homebuilt".
If you, or anyone else, disagrees, don't read or respond to the ad!
Otherwise, you're all doomed to using the same old techniques and
technology ad nauseum. In fact, Jim. Isn't that what you do? Attempt to
introduce homnebuilders to a potentially better way of doing things?
Rip
Sorry Rip. It don't work that way here.
All of this is easily and inexpensively handled by an Avionics Power switch.
A Manually Operated switch. That can also be turned off too.
So now, what exactly was this "better way"?
New Garden Airshow (Chester County PA) Photos: Digital_Vocals General Aviation 0 June 12th 06 06:52 PM
====---- Willow Grove NAS Airshow Photos 2005 ---==== SITE BACK UP TopGunHank Naval Aviation 0 June 4th 05 12:12 AM
====---- Willow Grove NAS Airshow Photos 2005 ---==== TopGunHank Naval Aviation 3 June 3rd 05 06:38 PM
Photos from this weekends airshow at Sonoma County KSTS Randy Wentzel Piloting 0 August 25th 04 05:23 AM
US satellite photos - Mifflin County example Jonathan Gere Soaring 0 March 25th 04 12:39 AM
