Using an old RT385A as a base station.
Old June 17th 06, 11:05 PM posted to rec.aviation.homebuilt
Default Using an old RT385A as a base station.
I have an old Arc RT-385A from my Cessan 152 sitting in the closet that I'd
like to turn into a basestation. Mostly so I can listen to airplanes going
by overhead.
Does anyone know of an electronics kit I can buy (or make), that could
provide the 28v power, a headset jack and a PTT switch?
I've already built the vertical dipole antenna and I know what kind of
outside cabling I'd need to make it work. I'm also pretty sure I can get a
base station radio license - before I start yaking away..
Avery Wagg, C152: C-GPOO
Old June 21st 06, 07:27 AM posted to rec.aviation.homebuilt
I do not think anyone sells a KIT for this. You can buy the mating 25
and 50 pin connector, a push button switch, a mic jack and a speaker
and 28vdc power supply from several electronic supply houses. Try
www.digikey.com , www.mouser.com and allied .
On Sat, 17 Jun 2006 17:05:14 -0400, "Avery Wagg"
by overhead.
Old June 22nd 06, 02:08 AM posted to rec.aviation.homebuilt
by overhead.
try
FA: TBS-150 Aviation Base Station 760ch VHF Transceiver OttPrivateSale Aviation Marketplace 0 May 19th 06 02:53 PM
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
FA: VHF 760 COM Base Station: 3 hours left! EOC Aviation Marketplace 0 August 22nd 05 10:08 PM
Base Closure List- 2005 Phineas Pinkham Military Aviation 1 September 10th 03 12:06 AM
FA: VHF Unicom Base Station Radio 25W 760ch VC Aviation Marketplace 0 July 9th 03 05:01 PM
