Denny wrote:
So what is the point of this post? Well not much, except rules can be broken ( NASA just did) if done carefully, but it still feels bad... It will be a long time before I break the 1 hour rule again, significant other not withstanding... I don't have a formal one hour rule. I learned and live this one: "If you're worried about fuel, you don't have enough." I'll fly overgrossed before I'll fly light. -- Mortimer Schnerd, RN VE |
On Wed, 5 Jul 2006 10:57:02 -0700, "Peter Duniho"
wrote in :: When you write "there's no need to lie", you are no longer talking about aviation. You are making a statement about the person's relationship with his SO, one that may or may not be true depending on the actual nature of the relationship. Well, perhaps it's just me, but if I have to lie to my SO to assert my command authority as PIC, I would be looking for another SO pronto. |
I am a fanatic about not ever going into the
last hour of fuel, for any reason... This will usually keep you out of trouble, but I can see where it might get you =into= trouble. If, for example, weather is deteriorating, an unnecessary fuel stop will have you flying in worse weather than if you had simply continued on. Which is to be preferred depends of course on how much worse, and how much further on. There are many variables, and while it's usually safer to just be on the ground, that defeats the purpose of flying in the first place. Using five minutes of a one hour reserve to save half an hour in which ceilings would be lowering from a smooth 3000 to a ragged 1500 with the sun going down is an exchange I would make. Using forty-five minutes of that same reserve to avoid a 3000 foot scattered layer in the middle of the day is not. Setting conservative personal minima may be a good thing, but knowing they are conservative should give you leeway to extending them in some circumstances, and accepting the additional risk in exchange for additional benefit, or for lowering a different additional risk. One must always be careful not to let the creeping "just-a-little-mores" get you, but that is what aeronautical decision making is about. Personal minima not to be exceeded "for any reason" is not really decision making, it is decision avoiding. Sometimes that's a good thing. But not always. I see nothing wrong with your decision. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
I was the same way for many years after I exhausted my fuel. However,
after years of carefully calculating and avoiding getting into that last hour of fuel, I have regained the confidence to use some of it when it works to my advantage. I believe that rules need to be reviewed from time to time. Experiences, confidence/skill levels, and other factors may warrant a change in the rules, in either the more liberal or the more conservative direction. I've changed rules in both directions. One just needs to be sure that changes in the rules are well thought out, and based on the facts, not outside pressures. Yes, my nervous system still is quite aware when I get into that last hour. ![]() -- Gene Seibel Hangar 131 - http://pad39a.com/gene/plane.html Because I fly, I envy no one. Denny wrote: Just a comment... Last weekend I had to move a full load, five seats and baggage, across three states with multiple stops... This required a light fuel load to make the W&B work out... For those who have not seen my postings on fuel before, I am a fanatic about not ever going into the last hour of fuel, for any reason... I have even, in the distant past, landed 20 minutes from home for gas to avoid busting my own one hour minimum rule... Given that the current bird holds six hours of fuel and my bladder range is four hours, it has been many years since I had less than two hours in the tanks... Anyway, this time the significant other was breathing down my neck about completing the flights on a fixed schedule... After beating up on my whiz wheel for 20 minutes it became clear I would have to suspend the fuel rule for the first time in decades, and go 15 minutes into the fuel reserve because there 'aint no' gas station in the middle of Lake Erie... I measure fuel by the clock and use the fuel gauges only as a 'how goes it' indicator, though I know from experience the gauge on the main tank is on the money... So, there we are going across Lake Erie on a gorgeous sunny day as the needle just touches the 1/4 mark which means exactly 60 minutes of fuel left.. The count down timer I normally use for approaches agrees with the gauge... What didn't agree was my pucker factor... Amazing what your nervous system can do when it wants your attention... In spite of my intellectual knowledge that I had 15 minutes until landing with 60 minutes of fuel on board, my parasympathetic nervous system threw a tantrum... I got a hollow in the pit of my stomach.. My palms got sweaty... I had that, 'something bad is going to happen' sensation... OTOH, the engines continued to do the Lycoming four banger, shake, rattle, and roll... They weren't nervous... And the flight ended with the usual squeak of tires on the concrete at Port Clinton... So what is the point of this post? Well not much, except rules can be broken ( NASA just did) if done carefully, but it still feels bad... It will be a long time before I break the 1 hour rule again, significant other not withstanding... denny |
"Peter Duniho" wrote: http://www.wbuf.noaa.gov/laketemps/COLD_LE.htm The water at the Lake Erie beaches must feel like bathwater! (in the summer, I mean) Surfers wear wetsuits in 70 deg. water. It's cold enough to produce hypothermia in 6-12 hours of exposure. -- Dan C172RG at BFM |
"Dan Luke" wrote in message ... "Peter Duniho" wrote: http://www.wbuf.noaa.gov/laketemps/COLD_LE.htm The water at the Lake Erie beaches must feel like bathwater! (in the summer, I mean) Surfers wear wetsuits in 70 deg. water. It's cold enough to produce hypothermia in 6-12 hours of exposure. Something has gotten lost in the translation, I think. The water temp of 70 degrees is at 30 feet of depth. At the surface, it is much warmer. It does indeed get very warm at the surface, at the beaches. -- Jim in NC |
"Larry Dighera" wrote in message
... Well, perhaps it's just me, but if I have to lie to my SO to assert my command authority as PIC, I would be looking for another SO pronto. Me too. But like I said, that's not an aviation issue, and since you don't know the specifics of the relationship in question, you can't make a blanket statement about what "works" for them. |
... On Wed, 5 Jul 2006 13:35:51 -0400, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in :: "Larry Dighera" wrote in message . .. On 5 Jul 2006 07:38:28 -0700, "Denny" wrote in ... What's the water temperature in Lake Erie this time of year? :-( Surface temperature is about 70 degrees F... While they're reporting 73 degrees F at 30 foot depth he http://www.wbuf.noaa.gov/laketemps/laketemps.htm It would appear that the lowest surface temperature is 39 degrees F as reported he http://www.coas****ch.msu.edu/erie/e.html The temperature in the shaded areas (like where you see the 39 F) is not reliable due to clouds. 70ish is prety good for most of the lake. The upper lakes are a lot colder, but Erie runs on the warm side... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote: The temperature in the shaded areas (like where you see the 39 F) is not reliable due to clouds. 70ish is prety good for most of the lake. The upper lakes are a lot colder, but Erie runs on the warm side... Only at the western half, which is shallow. The central and Eastern half are quite deep. When the wind is blowing strong out of the east, it is not unusual for the depth at the west side to increase by several feet. |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 07:13 PM |
| faith in the fuel delivery infrastructure | Chris Hoffmann | Piloting | 12 | April 3rd 04 02:55 AM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Hot weather and autogas? | Rich S. | Home Built | 33 | July 31st 03 12:25 AM |
