#31
Andrew Gideon wrote: I know. But now that they own both, they should be free to steal the UI from one for the other. Turf battles, corporate politics. |
#32
"Jonathan Goodish" wrote in message ... ... Though I'm not Windows fan, I believe that Avidyne and others use Windows as the foundation for their avionics systems. However, they strip out all of the junk that normally accumulates on a PC and are left with a fairly stable (and hardened) system. I suspect that you could approach that level of reliability if you did the same--stripped the system of everything but the FlightPrep, WxWorx, etc. But then, that would remove most of the non-aviation utility from the system. As I understand it, Avidyne uses Embedded Windows NT (a Microsoft product) in their EX5000 MFD. I suspect they also use it in their EX500 MFD. This was one reason why it took a long time for them to introduce USB flash memory compatibility for data upload/download. The original version only supported USB Zip drives, since that was the only USB drivers available for Embedded Win NT. Starting with Version 6.x on the Cirrus (EX5000C) MFDs, they now support Zip drives and USB "keychain" drives. You are correct that Embedded Win NT is "stripped down". That's one reason why it is much more reliable than the desktop versions. As to the Entegra PFD, it's an entirely different (although externally similar-looking) product. It does not use any Windows operating system. I believe they do use an RTOS (real-time operating system), but they would not tell me if they used an off-the-shelf RTOS or wrote their own. -Mike |
| Zero-Zero Landings In The Works (For Military Flyers) | Otis Willie | Naval Aviation | 0 | December 6th 05 03:01 AM |
| crazy but it works, espcially good if you need money | happyone | Piloting | 0 | July 24th 05 05:14 PM |
| New GPS from Honeywell/Bendix-King in the works | Jim Burns | Owning | 8 | June 21st 05 11:18 PM |
| Handheld GPS Works Fine, Except in One Particular Aircraft | jls | Home Built | 3 | July 5th 04 03:35 AM |
