Calls on the radio
Old July 10th 06, 11:08 PM posted to rec.aviation.piloting
Pascal
Default Calls on the radio
Hello,
This might have been brought up in the newsgroup before but I couldn't
find anything about it.
When going to a new airport, the AD would have sometimes something like :
Monroe County Airport, Bloomington, IN
What call should I do ?
Monroe County tower, Cessna XXXX ...
or
Bloomington tower, Cessna XXXX ...
Usually if I listen to what's being said on the frequency before I talk
I could figure it out, but sometimes some airports don't have that much
traffic and it's a little harder to know what is the proper thing to say.
Thanks
Old July 10th 06, 11:34 PM posted to rec.aviation.piloting
Roy Smith
Pascal wrote:
Hello,
I would just call them Monroe Tower. Leave out the "County" part; it
doesn't add anything.
Consider the case of multiple airports in the same city; wouldn't it
be confusing if people called both Kennedy Tower and LaGuardia Tower,
"New York Tower"?
Another trick is to just call them "Tower", and wait to see how they
respond :-)
Bob Noel
or
They'll probably answer to either. I'm pretty sure people call KBED
"Hanscom" and "Bedford"... I'm quite certain I've used both - sometimes
in the same flight.
Bob Noel
Looking for a sig the
lawyers will hate
Old July 10th 06, 11:44 PM posted to rec.aviation.piloting
Emily[_1_]
Pascal wrote:
Hello,
AD?
I think it really depends. With something like BMG (or is it BMI?), you
should be able to tell from the ATIS. The only airport that I really
embarrassed myself at like that was HUF.
Old July 10th 06, 11:48 PM posted to rec.aviation.piloting
Jose[_1_]
AD?
AF/D
Jose
Old July 11th 06, 12:21 AM posted to rec.aviation.piloting
Larry Dighera
On Mon, 10 Jul 2006 17:08:41 -0400, Pascal wrote
in ::
or
If you look he http://www.airnav.com/airport/KBMG
for Monroe County Airport, Bloomington, IN, you find it being called
Bloomington Tower.
Take a look at KSNA: http://www.airnav.com/airport/KSNA
While it indicates that the correct radio call is John Wayne Tower, I
prefer to call them Orange County or Santa Ana. I've never had any
difficulty.
Old July 11th 06, 01:43 AM posted to rec.aviation.piloting
Gene Seibel
How about, "Hey you guys....."
Gene Seibel
Tales of Flight - http://pad39a.com/gene/tales.html
Because I fly, I envy no one.
Pascal wrote:
Hello,
or
Thanks
Old July 11th 06, 02:09 AM posted to rec.aviation.piloting
Dale
In article , Pascal
Hello,
or
Thanks
You should figure this out during your preflight prep. The A/FD would
be a good place to start.
Old July 11th 06, 02:17 AM posted to rec.aviation.piloting
soxinbox[_1_]
How about just "tower"?
"Pascal" wrote in message
Hello,
or
Usually if I listen to what's being said on the frequency before I talk I
Thanks
Old July 11th 06, 02:28 AM posted to rec.aviation.piloting
John[_4_]
or
in the same flight.
When I'm talking about Hanscom (BED) to a TRACON, particularly if far away, I
usually say Bedford - Hanscom. I notice that even Boston TRACON says "enroute
to Bedford" and the like, although they refer to "Hanscom Tower." I figure the
extra syllables to say Hanscom are worth it when I'm far away, especially since
Bedford isn't uncommon and the "New Bedford airport" is also in eastern
Massachusetts. ("Take me home to BED works too.")
Of course if you really wanted to be a clown, you could say, "Laurence G.
Hanscom airport", which could easily be confused with Lawrence Muni, which is
nearby. Or the "(Major) General Ed Lawrence Logan airport," usually referred by
ATC as "Boston."
Some towers (and CTAFs for that matter) seem to use the locality name as their
callsign, and others sometimes use the airport name, (if there is a
difference). No rhyme or reason, just have to listen to what others are saying,
and take a guess if you don't know.
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 06:39 PM
VOR/DME approach radio calls Derek Fage Instrument Flight Rules 12 December 9th 04 12:36 AM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 11:57 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 04:30 AM
