barrel roll in 172
Old August 1st 06, 08:00 AM posted to rec.aviation.piloting
JerryGirrafe
Default barrel roll in 172
Andrey Serbinenko wrote:
If kept within the normal category load limits, is 172 certified to do
barrel rolls?
Andrey
No, but you can do a slip-short split-S if you so desire. I've only
done one in a low wing, but keeping positive 1g throughout is
necessary. They don't have the roll rate of an edge 540 so I don't know
why you would even want to do anything like a barrel roll in a training
aircraft. I like your live on the edge spirit though!!
  #122
Old August 1st 06, 10:47 AM posted to rec.aviation.piloting
Jim Macklin
(5) Model 172L (1972 model)
"This airplane must be operated in compliance with the
operating limitations
as stated in the form of placards, markings, and manuals:
MAXIMUMS
Normal Category Utility Category
Maneuvering speed (CAS) 122 mph (106 knots) 122 mph (106
knots)
Gross weight 2300 lbs. 2000 lbs.
Flight load factor
Flaps up +3.8 -1.52 +4.4 -1.76
Flaps down +3.5 +3.5
Normal category - No acrobatic maneuvers including spins
approved
Utility category - Baggage compartment and rear seat must
not be occupied.
No acrobatic maneuvers approved except those listed below.
Maneuver Max. Entry speed
Chandelles 122 mph (106 knots)
Lazy eights 122 mph (106 knots)
Steep turns 122 mph (106 knots)
Spins Slow deceleration
Stalls (except whip stalls) Slow deceleration"
Spin recovery: opposite rudder - forward elevator -
neutralize controls.
Intentional spins with flaps extended are prohibited. Known
icing conditions to
be avoided. This airplane is certified for the following
flight operations as of date
of original airworthiness certificate:
(DAY NIGHT VFR IFR)" (as applicable)
Download the entire TCDS here
http://www.airweb.faa.gov/Regulatory...4?OpenDocument
"JerryGirrafe" wrote in
message
certified to do
| barrel rolls?
| Andrey
I've only
is
I don't know
in a training
  #123
Old August 1st 06, 01:57 PM posted to rec.aviation.piloting
Bob Moore
operating limitations as stated in the form of placards,
Yeah Jim, and we all MUST comply with all highway speed limits,
even when they were 55 mph. Hell...my speedometer even had a
big red mark at 55 mph.
A lot of those placards, markings, and manual limits are just
because the manufacturer did not want to spend the time and
money in order to seek certification for a particular item.
Such is the case of the "no slips with flaps" contained in the
manual for a lot of the C-172s.
Bob Moore
  #124
Old August 1st 06, 05:27 PM posted to rec.aviation.piloting
Larry Dighera
On Tue, 01 Aug 2006 11:57:10 GMT, Bob Moore
wrote in ::
Newsgroups: rec.aviation.piloting
Subject: Cessna 172 slips with flaps
Date: 5 Jul 1994 15:06:35 -0400
Message-ID:
NNTP-Posting-Host: 141.114.130.70
I know this has been beaten to death, but I just received an article
from AOPA about the C172 and there is a reference to this problem.
Article: "Anatomy of a Success" (The makings of a winner) by Thomas A.
Horne, AOPA Pilot in May, 1992. In describing the phenomenal success
and popularity of this plane when introduced in 1955, the author says
this:
"There was -- and still is -- one handling quirk: In a forward slip
with flaps extended, a 172 could pitch nose down, violently enough to
push a pilot against his seat belt. This is caused by an upturned
aileron's reducing the normally strong downwash of air over the
horizontal tail. Though puzzling in its infrequency, Cessna saw the
potential for trouble. Consequently, a placard is installed near the
flap control: Avoid slips with flaps extended."
Message-ID:
An added note in this article...I am still reading it....in 1972 the
'dorsal fin was extended all the way forward to the rear window. This
helped virtually eliminate the nose-down pitch problem in sideslips
and made the airplane much more spin resistant....Cessna received
complaints from some flight instructors because of this
characteristic. Demonstrations of fully developed (three-turn) spins
were difficult to perform; result was usually a spiral"
  #125
Old August 1st 06, 05:45 PM posted to rec.aviation.piloting
Jose[_1_]
Cessna received
Interesting. Cessna creates a safer airplane, and people complain.
Jose
  #126
Old August 1st 06, 06:01 PM posted to rec.aviation.piloting
Bob Moore
What makes the AOPA or Thomas Horne an authority on the subject?
I have posted the following on previous occassions before and still
believe it to be true. It is excerpted from the book, "Cessna, Wings
for the World" by William Thompson. Bill Thompson served as Manager of
Flight Test and Aerodynamics for the Cessna Aircraft Company. Seems as
if he should know the 'real' story.
Bob Moore
With the advent of the large slotted flaps in the C-170, C-180, and C-172 we encountered
a nose down pitch in forward slips with the wing flaps deflected. In some cases it was
severe enough to lift the pilot against his seat belt if he was slow in checking the
motion. For this reason a caution note was placed in most of the owner's manuals under
"Landings" reading "Slips should be avoided with flap settings greater than 30° due to a
downward pitch encountered under certain combinations of airspeed, side-slip angle, and
center of gravity loadings". Since wing-low drift correction in cross-wind landings is
normally performed with a minimum flap setting (for better rudder control) this
limitation did not apply to that maneuver. The cause of the pitching motion is the
transition of a strong wing downwash over the tail in straight flight to a lessened
downwash angle over part of the horizontal tail caused by the influence of a relative
"upwash increment" from the upturned aileron in slipping flight. Although not stated in
the owner's manuals, we privately encouraged flight instructors to explore these effects
at high altitude, and to pass on the information to their students. This phenomenon was
elusive and sometimes hard to duplicate, but it was thought that a pilot should be aware
of its existence and know how to counter-act it if it occurs close to the ground.
When the larger dorsal fin was adopted in the 1972 C-172L, this side-slip pitch
phenomenon was eliminated, but the cautionary placard was retained. In the higher-
powered C-172P and C-R172 the placard was applicable to a mild pitch "pumping" motion
resulting from flap outboard-end vortex impingement on the horizontal tail at some
combinations of side-slip angle, power, and airspeed.
  #127
Old August 1st 06, 08:49 PM posted to rec.aviation.piloting
Larry Dighera
On Tue, 01 Aug 2006 16:01:39 GMT, Bob Moore
wrote in : :
It sounds like he just paraphrased the quote you posted.
Bob Moore
  #128
Old August 2nd 06, 04:11 PM posted to rec.aviation.piloting
Jim Macklin
People were beginning to talk about all the different
maneuver that can be done in an airplane [in this case the
172, but this applies to all airplanes]. The OP asked about
"normal category" but even allowing for utility category,
the 172 is approved for very limited aerobatics. The
specific allowed maneuvers are listed.
Certainly, any airplane can perform any aerobatic maneuver,
since all the controls are present for all axis.
But just as any camera can take portraits or porn, any
airplane will only do what the pilot can do. If your name
is Bob Hoover et al, you don't need to ask the question and
you probably can do these maneuvers. But Joe Sixpack is
going to do several things...(a) bend the airplane (b) break
the airplane (c) wish he had a quick jettison door (d) wish
he had a parachute and (e) die.
Simple rule, The Law of Gravity has no exceptions or
appeals.
James H. Macklin
ATP,CFI,A&P
"Bob Moore" wrote in message
. 121...
limits,
had a
just
and
item.
| Bob Moore
  #129
Old August 2nd 06, 06:31 PM posted to rec.aviation.piloting
Jose[_1_]
Certainly not. Not all airplanes have sufficient control authority to
perform all aerobatic maneuvers, and not all cameras can take macros.
Jose
  #130
Old August 2nd 06, 09:10 PM posted to rec.aviation.piloting
Jim Macklin
You have to have "macros" to take porn? "Any acrobatic
maneuver" wasn't intended to mean 720 degree roll per second
rate or tail slides, or but just the basic 3 axis and
combinations.
"Jose" wrote in message
maneuver,
authority to
take macros.
| Jose
music.
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 July 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 09:27 AM
