Approach Questions
Old November 7th 04, 03:03 AM
Andrew Sarangan
Default Approach Questions
A few questions came up in ground school that had me stumped. Any insight
is appreciated.
Why do some approaches say Radar required when all the fixes can be
identified using other equipment required for the approach? For example,
VOR-DME-A at 3G3.
When a holding pattern is published in lieu of a PT, my understanding of
the AIM (5-4-9 (4)) is that you only have to perform the entry, and are not
required to do any laps around the pattern. What if the hold requires a
direct entry? In that case it seems that you can effectively skip the
holdind pattern, which does not make sense to me because a PT (or hold in
lieu of PT) is a required maneuver. Take a look at SDF10 @ DWU.
Why does the hold in lieu of a PT always say "1 min". Isn't a hold always 1
min? Why is this mentioned only for this type of hold, and not mentioned
for all other holds?
What exactly is a Fan Marker? See SDF10 @ DWU. How is this different from
an OM? The fan marker seems to have its own identifier code.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old November 7th 04, 03:48 AM
Roy Smith
is appreciated.
VOR-DME-A at 3G3.
According to airnav.com, DUNDY, the only IAF, isn't charted on any
en-route charts, so there's no tie-in to the en-route airway system,
making radar vectors the only way to get to the IAF. At least that's my
guess.
That's correct.
The rule says that unless you are flying a published NoPT route or are
on radar vectors to the final approach course, you must fly the PT. It
doesn't always make sense, but that's the rule.
Holds don't have to be 1-minute legs. If you have DME or GPS, it's
common to specify the leg length in terms of distance, not time. A good
example would be the GPS-9 t KIJD.
FM's are pretty rare these days. I believe they were originally used as
distance fixes along the old A-N airways. A FM has a wider radiation
pattern than a standard OM. My guess is that an OM isn't wide enough to
reach to the edges of the SDF course, so they use the wider FM instead.
My recollection is that they have the same carrier frequency and audio
keying frequency as the OM, so they light up the OM light on your panel.
Old November 7th 04, 12:16 PM
A fan marker lights the white light. An OM lights the blue light.
is appreciated.
VOR-DME-A at 3G3.
Old November 7th 04, 02:50 PM
Bob Moore
from an OM? The fan marker seems to have its own identifier code.
Ah yes...the SDF RW10 at DWU...my home field for 7 years.
Probably did the SDF approach at least one hundred times.
Positioning wise, the fan marker does not fit the usual
requirement for outer/middle/inner markers. At DWU, it
marks a step-down fix after that last radio tower where,
if received, one may descend to the lower FM minimums.
Andrew, you probably don't remember "bone" markers either?
Bob Moore
Old November 7th 04, 02:58 PM
DUNDY is incorrectly charted. It is an IF, not an IAF. The FAA has made this
mistake on a lot of these abbreviated radar required IAPs.
is appreciated.
VOR-DME-A at 3G3.
guess.
That's correct.
Old November 7th 04, 04:31 PM
Andrew Sarangan
So, you are saying that the FM activate the same light as the Inside
Marker. Is this written down anywhere? I could not find anything in the
AIM. Before I explain this to my ground school I want to be certain I
have the correct answer.
wrote in :
insight is appreciated.
example, VOR-DME-A at 3G3.
of the AIM (5-4-9 (4)) is that you only have to perform the entry,
and are not required to do any laps around the pattern. What if the
hold requires a direct entry? In that case it seems that you can
effectively skip the holdind pattern, which does not make sense to me
because a PT (or hold in lieu of PT) is a required maneuver. Take a
always 1 min? Why is this mentioned only for this type of hold, and
not mentioned for all other holds?
Old November 7th 04, 06:01 PM
Bob Gardner
AIM 1-1-9(f). All marker beacons, including fan markers, transmit on 75 Mhz.
The only difference is the audio modulation frequency which in turn
determines which light illuminates on the panel. Because of the relatively
high frequency, they are short range...thus the need for "locator (outer,
inner, middle) markers"...they enable the ADF equipped aircraft to locate
the marker beacon. It is easy to fly within reception range of an NDB and
miss the marker beacon entirely if you are not paying attention.
Some of the new whiz-bang ground traffic management systems involve voice
transmission on 75MHz because most planes have a marker beacon panel.
Sometime in the future, as you are taxiing in poor visibility, your marker
beacon receiver might say something like "On taxiway bravo, approaching
intersection bravo two."
Bob Gardner
"Andrew Sarangan" wrote in message
. 145...
is appreciated.
VOR-DME-A at 3G3.
not
1
Old November 7th 04, 09:24 PM
Inside marker? I think you mean the inner marker. If you want an
authoritative source try the new FAA instrument flying handbook.
wrote in :
More dumb CNX-80 questions -- unloading an approach? Roy Smith Instrument Flight Rules 2 September 17th 04 12:30 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 04:27 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 12:13 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 10:03 PM
