Silly controller
Old August 27th 06, 02:37 PM posted to rec.aviation.piloting,rec.aviation.ifr
The Visitor
Default Silly controller
Roy Smith wrote:
There is no clearance limit -- you're not cleared "to" anyplace. The IFR
version of the above would be:
"Cleared to the Foobar airport, cleared ILS 23 approach, maintain 2000
until established".
"Cleared to the Foobar airport, via (insert routing or direct) expect
the ILS 23 approach., or cleared the ils 23 approach at Foobar, maintain
2000 until established".
  #42
Old August 27th 06, 05:46 PM posted to rec.aviation.piloting,rec.aviation.ifr
Ron Rosenfeld
On 26 Aug 2006 06:56:08 -0700, "Doug" wrote:
I was once told, just outside the FAF "the approach is APPROVED, radar
services TERMINATED". And yes kiddies I was in a cloud. (He musta been
a supervisor :-)
Why did you think that was a problem?
  #43
Old August 27th 06, 05:47 PM posted to rec.aviation.piloting,rec.aviation.ifr
Emily[_1_]
Steven P. McNicoll wrote:
"Emily" wrote in message
At my home airport, we had radar service terminated all the time. Radar
didn't reach below 3000 feet or so and they (usually) let us know when
they couldn't pick us up anymore. We were still IFR.
The phraseology for loss of radar contact is "radar contact lost", not
"radar service terminated".
Tell that to Chicago Center.
  #44
Old August 27th 06, 05:55 PM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
Christopher C. Stacy wrote:
The instruction "Cleared for the ILS runway 23 at Foobar maintain 2000 until established"
contains "cleared", a route (which is even a charted IFR procedure), an altitude,
and a clearance limit (landing Foobar airport, or executing the published missed
approach procedure). How is that not an IFR clearance?
It's not.
I think it is, unless the controller adds the words "maintain VFR".
When I want a practice approach and the controller fails to say "VFR",
I add it back in to try and make sure, like:
"Cherokee 97R cleared for the ILS 29 maintain VFR".
Not necessary. If you are doing a whole series of practice approaches
the controller needs to tell you one time to maintain VFR. Not one time
per approach, just one time.
  #45
Old August 27th 06, 05:57 PM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
Jim Macklin wrote:
And if you are not IR rated and current, they just put you
in violation of the FAR.
He misunderstood, that's not what happens.
  #46
Old August 27th 06, 05:58 PM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
I forgot to add to the scenario (and forgot to mention to the controller)
that the pilot was also given a transponder code (which I believe was the
case with the OP, and which is always my experience also). That's another
element that points to it being an IFR clearance. Probably everyone assumed
it anyway, even though of course you could also be assigned a squawk under VFR.
Everybody gets a code to get service from the approach control. It
means nothing.
  #47
Newps
"Jim Macklin" writes:
I didn't mention that to avoid opening that can of worms.
I think the answer is, "probably". Probably also always
gets ignored by the FAA from the enforecement standpoint.
You can't be this uninformed. You just can't be.
  #48
Old August 27th 06, 06:01 PM posted to rec.aviation.piloting,rec.aviation.ifr
Steven P. McNicoll[_1_]
I have.
  #49
Old August 27th 06, 06:13 PM posted to rec.aviation.piloting,rec.aviation.ifr
Jose[_1_]
I have.
What was their response?
Jose
  #50
Old August 27th 06, 06:21 PM posted to rec.aviation.piloting,rec.aviation.ifr
"Jose" wrote in message
"Okay".
Silly controller Robert M. Gary Piloting 119 August 30th 06 02:56 AM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Columns by a Canadian centre controller David Megginson Instrument Flight Rules 1 August 9th 04 11:05 PM
Skyguide traffic controller killed HECTOP Piloting 39 March 3rd 04 02:46 AM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 03:13 PM
