Procedure turn in Strong X-wind
Old November 23rd 04, 05:09 PM
Bob Gardner
Forget the 45-180 and do a 270-90 into the wind.
Bob Gardner
"smackey" wrote in message
m...
OK, I'm flying my local VOR-A which calls for an outbound heading of
252, then I'm suppoosed to turn 45 deg to 207 to begin the PT. But
there is a STRONG x-wind and I am already crabbed to about 215 to hold
the 252 outbound course. I assume I turn to something not quite
approaching 170 (45 deg from 215), just something inbetween in order
to sort of track 45 deg off the outbound course and fly a bit longer
than 1 min so I don't get blown back through the inbound course when I
do the turn back toward the inbound course. It just seems weird to be
flying at almost 90 deg from the outbound course. Any opinions on
this?
Old November 23rd 04, 05:29 PM
Jose
Even better, do a 90-0-270 into the wind, where the 0 (continue straight ahead) lasts for 30 seconds or so (depending on the wind you are countering).
This will make up for the drift during the turns. You'll be turning a total of 360 degrees to make a U turn this way, for a total of two minutes.
With (say) a 30 knot crosswind, you'd drift one mile in that time. At 90 knots, you could recover that in 45 seconds. At 120 it would take half a
minute.
Jose
Freedom. It seemed like a good idea at the time.
Old November 24th 04, 06:58 PM
Gene Whitt
Y'Al.l,
Very much in agreement with Bob Gardner about 90/270 and not the FAA's
80/260. After a pilot has his rating I recommend forgetting all the
formalities of holding patterns and procedure turns and using only the
90/270 to the procedure side.
Regarding strong winds. The LDA into CCR CA is an interesting approach in
that it is right angles to the only ground level wind entry of the entire
California coastline through the Golden Gate.
The initial part of the approach has winds that require 30 to 40 degree wind
corrections but at the FAF the hills block most of the winds at a lower
altitude and often no wind correction is required.
The other day I flew with a retread pilot into Sacramento Executive where we
were tracking the VOR with a 30+ wind correction angle and made our base
entry to 30 with much the same angle. We literally slid sideways down to
the runway.
Gene Whitt
Old November 24th 04, 07:39 PM
Jose
80/260.
What does the extra ten degrees provide you? (or is there something else in the article, which I haven't seen, that I'm missing?
Jose
Old November 24th 04, 09:16 PM
smackey
Thanks for all the feedback. It has been helpful. Yes, we do get
some good xwinds here; todays winds aloft here are projected at 49k at
9000, 35k at 6000.
Old November 25th 04, 06:42 PM
Gene Whitt
Jose,
The 90/270 has a tremendous advantage when making turns and remembering
where to turn.
The system is called the 'sum of the digits'
Take any number of the heading indicator and add all three of
its digits and keep adding until you get a single digit.
Example #1 030 = 3
Example #2 290 = 11 = 2
The sum of the digits every 90-degrees all the way around the dial will
equal 3 or 2 in both cases. It works for every number on both
the 90-degree numbers and 45-degree numbers.
Example #1
030 = 3; 120 = 3; 210= 3; 300 = 3
Example #2
290 = 11 = 2; 020= 2; 110 = 2; 200= 2
Works all the time everytime.
Gene
Old November 25th 04, 07:31 PM
Brad Zeigler
"Gene Whitt" wrote in message
ink.net...
Jose,
where to turn.
Example #1 030 = 3
Example #1
Example #2
I'm not following you, Gene. I know that the sum of the digits trick is a
quick way to determine if something is divisible by three, but how does that
tell you the 90 and 270 degree headings?
Gene
Old November 26th 04, 06:13 AM
Jose
where to turn.
its digits and keep adding until you get a single digit... (math snipped)
Cool piece of math (even more interesting =why= it works, and how it translates into other bases). However, to find my entry, I just look at the DG
and pick the number that's off to the side. I turn there, then turn opposite onto the course. No math needed. The ten degrees one way or another
doesn't make any difference.
Jose
Required hold? Nicholas Kliewer Instrument Flight Rules 22 November 14th 04 02:38 AM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
KCNH departure procedure. Roy Smith Instrument Flight Rules 5 August 24th 04 11:52 PM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 04:27 AM
Instrument Approaches and procedure turns.... Cecil E. Chapman Instrument Flight Rules 58 September 18th 03 11:40 PM
