Atmospheric conditions affecting VOR reception range
Old October 4th 06, 06:54 AM posted to rec.aviation.owning
Mike Noel
Default Atmospheric conditions affecting VOR reception range
Has anyone ever noticed a drop in VOR reception range when flying in smoky
conditions? Last Saturday in southern AZ we had significantly reduced
visibility from the big fire north of LA. I saw a lot of flagging on and
off of the CDI along with back and forth needle drift until within about 30
miles of the VOR station. We usually get much better reception.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
Old October 4th 06, 12:27 PM posted to rec.aviation.owning
kontiki
Smoke will not affect VOR reception.
Old October 4th 06, 01:16 PM posted to rec.aviation.owning
Denny
Suspended particles in the air can absorb VHF energy, will affect UHF
signals, and will absolutely swallow gigahertz and light wave energy
(which is why you can't see through haze) - now whether ash
particulates from a forest fire will bother VHF is something I'm not
ready to take a position on... But, if there are boron molecules in
that haze from the firefighting chemicals that raises the probability
that it is affecting VHF, and up in frequency...
If the erratic VOR signals that day were due to the forest fire, what
is also likely is that the rising heat from the fires is causing
temperature layering and air turbulence which definitely bends VHF
signals, the same as it distorts light waves when looking down a
highway on a hot day, or looking through a bonfire...
denny
Old October 4th 06, 11:38 PM posted to rec.aviation.owning
kontiki
The ionized contaminants in the smoke would have to be significant
before it would significantly affect VOR reception... not likely.
The poster did not state the altitude he was at not the class of
VOR in question.
VHR radio signals can be affected by certain tropospheric contitions
such as temperature inversions. As you stated, it is possible that
the heat of the fire could have cause a sort of temperature inversion
layer that affected the signal strength resulting in some CDI fluctuation.
Old October 5th 06, 02:29 AM posted to rec.aviation.owning
Mike Noel
I was also wondering if the large amounts of carbon particulates in the
Arizona dry air could cause a static charge to build up on the airframe and
affect the signal.
Best Regards,
Mike
"kontiki" wrote in message
smoky conditions? Last Saturday in southern AZ we had significantly
reduced visibility from the big fire north of LA. I saw a lot of
flagging on and off of the CDI along with back and forth needle drift
until within about 30 miles of the VOR station. We usually get much
better reception.
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. Scott Ferrin Military Aviation 29 August 31st 04 05:20 AM
