#121
"Wade Hasbrouck" wrote in message
... [...] Ire or not, if your strobes are the installed anticollision lights, then they must be on while you are operating the aircraft. Are there any planes that have only strobes? Yes. I know of two owned by people in these newsgroups (my own airplane, and Ron and Margy Natalie's airplane) for sure, and it's not exactly an uncommon situation. Pete |
#122
"A Lieberma" wrote Thanks Jim, ((a different jim than Jim in NC)) I think I had tried that and on the second message, the URL got truncated in a different position. Instead of using the backspace, I was deleting the last charactor of the line, and re-inserted the deleted charactor. No biggie, not normal that I post such long URL's anyway, just hate nuicance things since I am suppose to be smarter then the computer. :-) Did you try the before and after the link trick? -- Jim in NC |
#123
In rec.aviation.student Wade Hasbrouck wrote:
For the record, I turn on the rotating beacon, when I get to the item in the check list that says "Master Switch on.", and turn it off during the "Securing the airplane" checklist. In the plane I use (school plane), the switch for the beacon and the strobes is a split switch. We just leave the beacon on all the time. That way, if the master switch is on, the beacon starts. It's a heads-up for people on the ramp that there's a risk that somebody might start the engine. It's also a handy reminder that you've left the master switch on when securing the airplane. .... Alan -- Alan Gerber gerber AT panix DOT com |
#124
Mxsmanic wrote:
Neil Gould writes: In contrast, our flight school just posted a bulletin opposing the use of landing lights at any time other than taxiing. We were trained to land without them, and I now find it much easier to do so than to use them. One reason is that our airport is frequented by deer, who just stop dead on the runway when they see the lights, and there was a deer strike just a couple of weeks ago because the pilot was using landing lights. Isn't the field fenced? I was flying today with my instructor and as we approached, the tower warned us of a coyote on the the active runway. Huge, fenced airport. |
#125
Jim Stewart wrote:
Mxsmanic wrote: Isn't the field fenced? I was flying today with my instructor and as we approached, the tower warned us of a coyote on the the active runway. Huge, fenced airport. Back when I was instructing, a Citation got stuck on a taxiway for almost an hour while they tried to find someone to go run the coyote off. I'd think they would be afraid of something that loud, but I taxied by on the runway and saw it lying on the taxiway, right in front of the jet. This was a large suburban airport, too. I guess it just wanted to take a nap. |
#126
"Alan Gerber" wrote in message
... In rec.aviation.student Wade Hasbrouck wrote: For the record, I turn on the rotating beacon, when I get to the item in the check list that says "Master Switch on.", and turn it off during the "Securing the airplane" checklist. In the plane I use (school plane), the switch for the beacon and the strobes is a split switch. We just leave the beacon on all the time. That way, if the master switch is on, the beacon starts. It's a heads-up for people on the ramp that there's a risk that somebody might start the engine. It's also a handy reminder that you've left the master switch on when securing the airplane. ... Alan -- Alan Gerber gerber AT panix DOT com Aren't the beacon and strobes typically on separate switches? At least they are in the 172s I have been in, don't know about other aircraft. |
#127
"Morgans" wrote in
: Did you try the before and after the link trick? http://flightaware.com/live/flight/N...935Z/KEKY/KMBO http://flightaware.com/live/flight/N...935Z/KEKY/KMBO /tracklog Lets see if this works. My latest flight :-) Allen |
#128
A Lieberma wrote in
. 18: http://flightaware.com/live/flight/N...15/1935Z/KEKY/ KMBO /tracklog Lets see if this works. My latest flight :-) Allen Guess not :-( Lets try the eliminating the wrap feature now. http://flightaware.com/live/flight/N1943L/history/20061015/1935Z/KEKY/KMBO Allen |
#129
Aren't the beacon and strobes typically on separate switches? At least they are in the 172s I have been in, don't know about other aircraft. In the Warrior I'm flying now, it's two thin switches that fit into the space of a full-sized switch -- like the master switch. So you can turn on either or both, as needed, in one motion. I don't remember if the school's older Warrior (now gone) had the same setup. .... Alan -- Alan Gerber gerber AT panix DOT com |
#130
"Wade Hasbrouck" wrote in message ... "Peter Duniho" wrote in message ... [...] Can you say "run-on sentence"? Sure, I knew you could! ![]() I never claimed to be a great writer... :-) I was computer science major, not an english major... :-) Sorry, could resist a posting a reply. Anyway, your assumption is poorly placed. I didn't say I practiced my assumption... :-) I guess it was more of a hypothesis vs. an assumption. I don't know why if someone, if they had a beacon on the tail, wouldn't turn it on once the engine it is started... It almost seems like there are some people in this thread that are like "Well, I have a beacon, but I am not turning it on, because I don't think I have to." Commonsense says that it is a much safer world if you turn it on just before turning the key, and leaving it on until you shut the engine down, because after all, you won't get in trouble for turning that thing on. For the record, I turn on the rotating beacon, when I get to the item in the check list that says "Master Switch on.", and turn it off during the "Securing the airplane" checklist. As has been beaten to death in this thread already, the FARs require that anticollision lights be on while the aircraft is being operated. Anticollision lights may take the form of a rotating beacon, strobes, or other types of light meeting the requirements for an anticollision light Agree this has been beaten to death. Ire or not, if your strobes are the installed anticollision lights, then they must be on while you are operating the aircraft. Are there any planes that have only strobes? Not trying to make an arguement, I am just curious, as almost every plane I have seen as the beacon on the tail, haven't seen one that has just strobes. I admit that it would sort of suck for other pilots if that is all you have, and FARs are FAR, and if that is all you got, that is what you gotta use. Mine only has strobes and that is not uncommon. |
| [VERY LONG} MD airplanes, complete and projects, engines, gliders, many other items. | [email protected] | Aviation Marketplace | 0 | June 10th 06 11:51 PM |
| Landing lights | Robert Barker | Owning | 20 | May 11th 06 03:33 AM |
| Jet sailplane update | Bob C | Soaring | 0 | April 13th 06 09:06 AM |
| Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 05:03 AM |
| 36HP VW Engine | Claton Cadmus | Home Built | 12 | October 24th 03 06:18 AM |
