fencing repair kit, including lengths of wire (coiled)for joining, heavy cutters/ pliers and a length of rope to help tension it all up again.
Bagmaker |
I think that there are four separate categories of tool sets (not
counting what I have at home) which relate to soaring. Listed are tools only, other items (like in the land out kit) are not included). However, I do include electrical items. Car ------------- Good metric/standard socket set (Craftsman) ball peen hammer tow strap (hooks around tow hitch ball - can come in VERY handy pulling gliders from fields) screwdrivers battery cleaning tools (brush, terminal puller) Jumper cables slip joint wrench ("cresent" wrench) adjustable wrench needle nose fuses, wire splices, ring lugs cable ties (12" and 24" - I only use Thomas & Betts T&B brand) 16 gauge stranded wire aviation safety wire, large diameter (better than bailing wire) voltmeter tow hitch (of course) electrical tape plastic sheeting GOOD flashlight (I carry a large aluminum multi-D cell and a smaller LED) rags (these are tools too) Tire inflater in a can Gaffers tape (better than duct tape) rope Day-to-Day with the Trailer ------- voltmeter cheap metric socket set metric allen wrenches screwdrivers fuses duplicate assembly tools (I need a metric nut driver for the tail) extra wing pins (I stumbled onto a set an acquaintance didn't need) cleaning supplies lubricants (LPS #2) cable ties (6" - I only use Thomas & Betts T&B brand) needle nose spare wheel bearings. electrical tape (doubles as wing tape) trailer wiring supplies spare air lines and fittings plastic sheeting Flashlight rags jacking equipment (spare tire) aviation safety wire, small diameter as needed for glider In the glider (land out kit) ------------- Leatherman like tool. I prefer SOG branded Fuses Cable ties (6" - I only use Thomas & Betts T&B brand) Air valve extension Flashlight On the Road - Beyond what is listed above ------------- Bottle jack or floor jack Air bottle 2x10 board (about 24" long) - used for jacking in the mud My "large" tool bags (one is "electrical" and the other is "mechanical/woodworking") Battery powered drill with charger, bits Inverter (12Vdc to 120Vac) - charges the drill, cell phones, computer, etc. Tow out kit Clamps (Jorgensen large clothes pin type) Stuff to get water in the wings spare main gear tire (the tail wheel and tail dolly wheel are interchangeable) battery charger (for ship) and spare batteries Anything aviation specific that you can't find at the local hardware store I know I am forgetting a bunch of other items but this is pretty close. |
Dang, why not just use a Snap-On Tool truck as your tow vehicle, and be
done with it? 8^) ContestID67 wrote: I think that there are four separate categories of tool sets (not counting what I have at home) which relate to soaring. Listed are tools only, other items (like in the land out kit) are not included). However, I do include electrical items. Car ------------- Good metric/standard socket set (Craftsman) ball peen hammer tow strap (hooks around tow hitch ball - can come in VERY handy pulling gliders from fields) screwdrivers battery cleaning tools (brush, terminal puller) Jumper cables slip joint wrench ("cresent" wrench) adjustable wrench needle nose fuses, wire splices, ring lugs cable ties (12" and 24" - I only use Thomas & Betts T&B brand) 16 gauge stranded wire aviation safety wire, large diameter (better than bailing wire) voltmeter tow hitch (of course) electrical tape plastic sheeting GOOD flashlight (I carry a large aluminum multi-D cell and a smaller LED) rags (these are tools too) Tire inflater in a can Gaffers tape (better than duct tape) rope Day-to-Day with the Trailer ------- voltmeter cheap metric socket set metric allen wrenches screwdrivers fuses duplicate assembly tools (I need a metric nut driver for the tail) extra wing pins (I stumbled onto a set an acquaintance didn't need) cleaning supplies lubricants (LPS #2) cable ties (6" - I only use Thomas & Betts T&B brand) needle nose spare wheel bearings. electrical tape (doubles as wing tape) trailer wiring supplies spare air lines and fittings plastic sheeting Flashlight rags jacking equipment (spare tire) aviation safety wire, small diameter as needed for glider In the glider (land out kit) ------------- Leatherman like tool. I prefer SOG branded Fuses Cable ties (6" - I only use Thomas & Betts T&B brand) Air valve extension Flashlight On the Road - Beyond what is listed above ------------- Bottle jack or floor jack Air bottle 2x10 board (about 24" long) - used for jacking in the mud My "large" tool bags (one is "electrical" and the other is "mechanical/woodworking") Battery powered drill with charger, bits Inverter (12Vdc to 120Vac) - charges the drill, cell phones, computer, etc. Tow out kit Clamps (Jorgensen large clothes pin type) Stuff to get water in the wings spare main gear tire (the tail wheel and tail dolly wheel are interchangeable) battery charger (for ship) and spare batteries Anything aviation specific that you can't find at the local hardware store I know I am forgetting a bunch of other items but this is pretty close. |
| Whats in YOUR toolbox? | Travis Beach | Soaring | 8 | October 25th 06 07:17 PM |
| Mechanics Toolbox | Stache | Piloting | 0 | October 13th 06 05:16 AM |
| FS: Snap-on aviation style toolbox | mike | Home Built | 0 | October 18th 03 08:27 PM |
| FS: Aviation toolbox Snap-on KR-562 | mike | Aviation Marketplace | 0 | October 17th 03 03:45 AM |
