Welding Regulator Leakage
Old October 31st 06, 04:57 AM posted to rec.aviation.homebuilt
J.Kahn
Default Welding Regulator Leakage
I hooked up an oxygen regulator to a tank and opening the tank valve
slowly it registered about 2200 psi. To check for the seal at the
regulator connection I then turned off the tank valve with the regulator
closed so that the gage was reading only the pressure of the few cc's of
gas trapped between the regulator and the closed tank valve. The
pressure would drop about 25-50 psi per minute. It should be zero no?
John
Old October 31st 06, 05:58 AM posted to rec.aviation.homebuilt
Dave S
John
Yes. Should be zero loss and hold pressure for hours. Check for any
dents on the nipple of the CGA fitting.. any debris on the inside of the
valve stem.. and ensure the regulator itself is "closed" when you say
its closed... maybe put a balloon over the end of the outlet and see if
the balloon inflates.. spray soapy water on the CGA fitting when the reg
is attached to the bottle and charged,.. look for bubbles to indicate
the leak.
And remember do not use anything with grease/oil when doing this
troubleshooting (sorry if im stating the obvious)..
Dave
Old November 1st 06, 12:57 AM posted to rec.aviation.homebuilt
J.Kahn
regulator closed so that the gage was reading only the pressure of the
few cc's of gas trapped between the regulator and the closed tank
valve. The pressure would drop about 25-50 psi per minute. It
should be zero no?
John
the leak.
Dave
Got it to seal after removing to clean up and reinstalling. Thanks.
John
Old November 1st 06, 02:21 AM posted to rec.aviation.homebuilt
Rich S.[_1_]
"J.Kahn" wrote in message
John
Don't forget to open the Oxygen valve (on the tank) all the way when using
the torch. It has a double seat; so when it is open fully, there is no gas
pressure on the stem packing.
Rich S.
Old November 4th 06, 04:28 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Tue, 31 Oct 2006 17:21:07 -0800, "Rich S."
John
Oxygen all the way to the stop.
Acetylene no more than necessary.
Rich S.
www.rogerhalstead.com
Aluminum welding Ernest Christley Home Built 5 April 24th 06 12:47 PM
Welding question Michael Horowitz Home Built 1 October 13th 05 10:53 PM
Practical welding? mhorowit Home Built 21 August 23rd 05 05:33 AM
AC 43.13, welding and a hip-check Michael Horowitz Owning 2 June 27th 04 08:09 PM
TIG welding video? Russell Duffy Home Built 3 October 6th 03 06:55 AM
