FAA: Runways come up short
Old November 5th 06, 09:47 PM posted to rec.aviation.piloting
Andrew Sarangan[_1_]
Default FAA: Runways come up short
The FAA says runways without a 1000-ft overrun area are unsafe. The
solution? Extend the overrun by shortening the runway. That sounds
fishy to me. What am I missing here?
Reference:
http://www.miami.com/mld/miamiherald...l/15925782.htm
Old November 5th 06, 09:53 PM posted to rec.aviation.piloting
Gary Drescher
Default Runways come up short
"Andrew Sarangan" wrote in message
Reference:
If the official length of the runway establishes whether a given airliner
can land there, then shortening the official length (and correspondingly
extending the designated runoff area) can indeed extend the worst-case
safety margin.
--Gary
Old November 5th 06, 09:58 PM posted to rec.aviation.piloting
Roy Smith
In article .com,
Reference:
They are not going to physically shorten the pavement. The article says,
"shortening the length of usable runway". This (presumably) means
declaring some of the runway "unusable" by repainting runway markings,
changing lighting and signage, etc.
So, right now you've got (say) 9000 feet of pavement and performance is
calculated based on all 9000 feet. If you declare the last 500 feet to be
"unusable", everybody now has to do their performance calculations based on
the runway being 8500 feet long. Which means aircraft that require between
8500 and 9000 feet must either go elsewhere or somehow improve their
performance (typically by operating at lower gross weights, which means
fewer people, less freight, and/or less fuel).
Old November 5th 06, 10:30 PM posted to rec.aviation.piloting
Ron Lee
Reference:
What rampant stupidity. If a pilot cannot land/take off on the
useable runway then create a requirement that you must be able to
safely operate off the published runway length minus whatever safety
margin they demand. No painting is required...no signage changes
needed. Not every runway in the USA has to accommodate the largest
aircraft on the worst day. This also means that by default all
runways are within standards.
If we did not have as many idiotic pilots like Lidle and the KLEX
pilots, things would be much better. Or idiotic "rules" people.
Ron Lee
Old November 5th 06, 11:26 PM posted to rec.aviation.piloting
Dudley Henriques
Probably nothing Andy. Sounds about right for the average FAA solution :-)
Dudley Henriques
Old November 6th 06, 12:08 AM posted to rec.aviation.piloting
Jose[_1_]
The
When you (officially) shorten the runway, you (legally) limit the
aircraft that can use it.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old November 6th 06, 12:59 AM posted to rec.aviation.piloting
Bob Noel
In article .com,
don't know.
But Massport did the same stupid thing at Logan many years ago.
(even dumber because the moved the thresholds AFTER building
highspeed taxi turnoffs.)
Bob Noel
Looking for a sig the
lawyers will hate
Old November 6th 06, 01:00 AM posted to rec.aviation.piloting
Bob Noel
Dudley Henriques
to pick a nit, the FAA isn't responsible for determining a runway length. That
"honor" is left to the airport.
Bob Noel
lawyers will hate
Old November 6th 06, 02:07 AM posted to rec.aviation.piloting
Dudley Henriques
"Bob Noel" wrote in message
Dudley Henriques
That
Why do you think I said it sounds about right for the average FAA
solution??? :-)
DH
Old November 6th 06, 02:34 AM posted to rec.aviation.piloting
Ron Lee
Dudley Henriques
That
Isn't the "standard/safety issue" coming from the FAA?
Ron Lee
Apollo short seen on TV karl gruber Piloting 2 May 1st 06 03:23 PM
Different categories of ILS hold short lines at large airports Peter R. Piloting 3 March 6th 06 09:08 PM
Runway ID Lakeview Bill Piloting 55 October 18th 05 01:53 AM
What is a "short field" for a PA28-181 Roy Page Owning 79 November 24th 04 01:11 PM
Short field in a Mooney AJW Piloting 0 September 26th 04 05:47 AM
