LS3a or Mini Nimbus
Old November 7th 06, 04:41 PM posted to rec.aviation.soaring
Default LS3a or Mini Nimbus
Dear All,
Which glider would you choose: LS3a or Mini Nimbus and WHY ? Assuming
similar age and condition, comparable instruments, trailer.
Old November 7th 06, 10:08 PM
Vic7 Vic7 is offline
Member
First recorded activity by AviationBanter: Jun 2005
Quote:
Originally Posted by
Dear All,
I have flown my Mini-Nimbus for the last six years. A good friend in my club has an LS-3. We often fly XC together and neither plane has a clear advantage in the air. Both ships fly marvelously for their price, but a very significant difference I have found is in assembly/disassembly. While my wings are not light compared to current designs, the LS-3 wings are downright cruel and inhuman to handle. Not only are they heavier than any glass ship I've helped rig, but also they resist going together, which lengthens the amount of time you are half bent over holding the beasts.
I have thoroughly enjoyed my Mini and think it delivers great performance for the price. The only time I'll trade it in is when I can afford one of those shiny, new, thin wings that go upwind better than I can.
You will probably have a blast with either plane. Let us know which you chose and how it turns out after you've flown it.
V7
Old November 7th 06, 11:21 PM posted to rec.aviation.soaring
Marc Ramsey
LS3 wings are considerably heavier than LS3A wings, due to lead mass
balance weights in the flaperons which were eliminated in the A and 17
models...
Marc
Old November 8th 06, 02:39 AM posted to rec.aviation.soaring
Stewart Kissel
handle.
I consider the LS-3 one of the very best values in
used sailplanes, I fly a Ventus B and below 80 knots
they do quite well on the run, and climb very well.
Both the LS3 owners I fly with self-rig using home-made
versions of Udo's tool...so they don't deal with the
weight of the wing. I think self-riggers are way under-rated
for usefullnes IMVHO.
Old November 8th 06, 03:09 AM posted to rec.aviation.soaring
Roger[_5_]
Just wondering, given the history of LS gliders why the LS-3 was not at
the top of score sheets like the LS1,2,4,6,and 8? When was it a
current design and which glider was the "it" glider durning the LS 3
production run. I had heard that the LS-6 airfoil was based off the LS
3 airfoil.
Roger
On Nov 7, 1:08 pm, Vic7 wrote:
Wrote:
Dear All,
similar age and condition, comparable instruments, trailer.I have flown my Mini-Nimbus for the last six years. A good friend in
than I can.
V7
Vic7
Old November 8th 06, 03:45 AM posted to rec.aviation.soaring
KM
3 airfoil.
Roger
Roger,
The biggest problem the LS3 and the Mini had was the ASW20.
K Urban
Old November 8th 06, 04:24 AM posted to rec.aviation.soaring
3 airfoil.
The LS-6 airfoil is significantly different than the LS-3, much
thinner.
Old November 8th 06, 04:59 AM posted to rec.aviation.soaring
Ira Blieden
I believe that each LS3-a wing is 24 lbs lighter than the LS3 wing (48
lbs total).
Ira
models...
Marc
Old November 8th 06, 05:01 AM posted to rec.aviation.soaring
Ira Blieden
The LS-3a is an absolute joy to fly. I owned one for 17 years.
lbs total).
Ira
models...
Marc
Mini Nimbus for sale - N. California [email protected] Soaring 0 August 1st 06 05:14 AM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 10:36 PM
