Input jack on a Baron
Old November 24th 06, 08:55 PM posted to rec.aviation.piloting
Greg Farris
Default Input jack on a Baron
I am aware that in real planes most commands are made through the
conventional flight controls - however there are some operations that
simply *require* a keyboard. Fuel management, for example.
Let's say I want to fly my Baron from Boisie, Idaho to Khartoum. I have
done in-depth calculations, involving complex algorithms and in my
estimation, even if I start with full fuel, I may run out before I get to
Sudan. In this case, without a keyboard to re-establish a given fuel
level, the flight cannot continue. Looking at pictures of real planes, I
do not see any dedicated button on the panel to accomplish this function,
so I can only assume there must be a keyboard input *somewhere* - but
WHERE? I cannot see it anywhere!
Another example - on a short hop from Los Angeles (LAX) to Chicago
(ORD). Obviously fuel is no problem on this short distance, but there is
a long, boring section, after crossing the Rockies at FL370 - the
terrain levels out, and it seems to take forever to get up to the Midwest
plains and make my approach to O'hare. I would like to just skip this
whole section, but once again I find no function in the real plane
allowing me to do this. So there must be a keyboard input . . .
Please be so kind as to enlighten me. In return I will challenge
everything you say and tell you you are simply not smart enough to grasp
my algorithms. . .
Old November 24th 06, 09:04 PM posted to rec.aviation.piloting
Doug[_1_]
Stuff $100 bills into the CD Drive and fuel comes out the USB port?
Old November 24th 06, 09:06 PM posted to rec.aviation.piloting
Jim Macklin
The new Baron's come with special dilithium crystal fuel
conversion units that use the Earth's static electrical
fields as a power source to synthesize gasoline in the fuel
tanks by converting the coffee as the second step in the
process.
The pilot and passengers all drink a lot of coffee in order
to extend the range. One cup of coffee makes 24 gallons of
gasoline.
"Greg Farris" wrote in message
through the
operations that
Khartoum. I have
and in my
before I get to
given fuel
real planes, I
this function,
*somewhere* - but
to Chicago
FL370 - the
to the Midwest
just skip this
real plane
challenge
enough to grasp
| my algorithms. . .
Old November 24th 06, 09:10 PM posted to rec.aviation.piloting
Jim Burns[_1_]
I believe that our Aztec used to have it's keyboard in a "map tray" located
under the co-pilots panel, but since previous owners removed the map tray, I
can only assume that they discarded the keyboard. Obviously this decreased
the value of our aircraft tremendously. I have noticed remnants of the
previous "map tray/keyboard" install such as the tray rails and the power
connection and I'm hoping to one day find a replacement keyboard and data
cable on ebay. It sure would be nice to have that "auto-fuel" button.
Because our plane has injected low compression engines, we can't get the
auto fuel STC, so my only hope is to find a keyboard with the factory
installed auto fuel function. I don't think our plane came with the "fast
forward" function, I believe that was only available in the turbo models.
If you have a Baron, you might try calling Jet-Prop Conversions, I think
they sell an STC'd Fast Forward package for the Baron.
Old November 24th 06, 10:07 PM posted to rec.aviation.piloting
Thomas Borchert
Steve,
The correct procedure is to use a Sinclair ZX-81
Which is the last safe computer for flying, too. I know since I worked
as cleaning personal in a Sinclair shop before they outsourced my job
to Bangalore.
Thomas Borchert (EDDH)
Old November 24th 06, 10:14 PM posted to rec.aviation.piloting
Jim Macklin
If you look at the panel for the Eclipse 500, you will see
the keyboard mounts
http://www.eclipseaviation.com/eclip...ght_deck.html#
"Steve Foley" wrote in message
| In article
.com,
| says...
the USB port?
| The cemeteries of the US are overflowing with the
corpses of dangerous
| pilots like yourself! The Baron is too old to have a
USB port - they
| certainly had their keyboards connected through RS-232
serial ports. I
| have designed many such aircraft, and I must say I would
feel a lot safer
| if I didn't have to share the skies with people like
you. Your attitude
| shows you have little respect for the truth.
| You are correct. The correct procedure is to use a
Sinclair ZX-81, enter the
| program, and save it to tape. If you'll notice, this uses
the same 1/8" jack
| as the line-in or music-in on your intercom.
| If you don't have a newer intercom, you'll need to enter
the commands four
| bits at a time using the Fuel Pump, Nav lights, landing
light, rotating
| beacon switches. ( see
http://home.att.net/~n6480r/IMG_1340.JPG )
| When you have the correct arrangements of switches,
depress the starter
| button.
Old November 24th 06, 10:22 PM posted to rec.aviation.piloting
Jose[_1_]
The cemeteries of the US are overflowing with the corpses of dangerous
pilots like yourself! The Baron is too old to have a USB port
That's why it's important to get a floppy.
Jose
"There are 3 secrets to the perfect landing. Unfortunately, nobody knows
what they are." - (mike).
Old November 25th 06, 12:52 AM posted to rec.aviation.piloting
Morgans[_2_]
"Steve Foley" wrote
You are correct. The correct procedure is to use a Sinclair ZX-81, enter the
program, and save it to tape. If you'll notice, this uses the same 1/8" jack
If you don't have a newer intercom, you'll need to enter the commands four
bits at a time using the Fuel Pump, Nav lights, landing light, rotating
beacon switches. ( see http://home.att.net/~n6480r/IMG_1340.JPG )
When you have the correct arrangements of switches, depress the starter
button.
NO! Don't do that. That is the back door way to fire the ejection seat!
Jim in NC
Obit: Jack Laister - Soaring Pioneer - November 19th 2006 [email protected] Soaring 0 November 21st 06 03:44 PM
Garmin GMA 340 Music Input O. Sami Saydjari Instrument Flight Rules 16 April 28th 05 01:51 AM
Passing of Richard Miller [email protected] Soaring 5 April 5th 05 02:54 AM
Cobra jack warning Andy Durbin Soaring 8 June 30th 04 03:32 AM
Red Baron vs. Rickenbacker? Gregorso Military Aviation 28 October 13th 03 08:26 PM
