Dave Butler writes:
http://www.faa.gov/airports_airtraff.../media/aim.pdf Excellent! Thanks. I had the book, but I didn't know it had detailed information on routing. -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Jim Macklin" writes:
As filed, flight plans are not flown. VFR might well be just as simple as telling FSS VFR, Washington DC , Indianapolis, St. Louis, Destination Kansas City [the phrase close enough for government work comes to mind.] My actual plan would have many points for visual and radio navigation. You're saying that you only put a few simple indications on the form but you fly a more detailed plan? I try to figure out lots of waypoints for VFR flights ... mainly because there are so many restricted areas and Class-whatever airspaces that I have to go through or avoid. If these didn't exist, I could just look out the window in many cases; but since the chart lines aren't marked on the real terrain, I try to have enough waypoints figured out in advance so that I can be sure I'll be in the right place at the right point from a regulatory standpoint. An IFR plan is more detailed, but might only have a departure airport, a SID and airway and a STAR and might only have the airway, the feds will assign the SID and STAR anyway. Do you normally get arrival and departure procedures when you request the IFR clearance, or does the arrival procedure not come up until you are approaching your destination? I've had a lot of trouble programming a FMS with procedures on the fly, which is why I ask. I also have to try to dig up charts on the spur of the moment, which is awkward. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: "Jim Macklin" writes: As filed, flight plans are not flown. VFR might well be just as simple as telling FSS VFR, Washington DC , Indianapolis, St. Louis, Destination Kansas City [the phrase close enough for government work comes to mind.] My actual plan would have many points for visual and radio navigation. You're saying that you only put a few simple indications on the form but you fly a more detailed plan? I try to figure out lots of waypoints for VFR flights ... mainly because there are so many restricted areas and Class-whatever airspaces that I have to go through or avoid. If these didn't exist, I could just look out the window in many cases; but since the chart lines aren't marked on the real terrain, I try to have enough waypoints figured out in advance so that I can be sure I'll be in the right place at the right point from a regulatory standpoint. An IFR plan is more detailed, but might only have a departure airport, a SID and airway and a STAR and might only have the airway, the feds will assign the SID and STAR anyway. Do you normally get arrival and departure procedures when you request the IFR clearance, or does the arrival procedure not come up until you are approaching your destination? I've had a lot of trouble programming a FMS with procedures on the fly, which is why I ask. I also have to try to dig up charts on the spur of the moment, which is awkward. Not one word in this post saying he is playing a game called MSFS and not flying a real plane Replier be forewarned.... Especially the IFR newsgroup. Better yet, ignore him, he is a troll. Allen |
"A Lieberma" wrote Not one word in this post saying he is playing a game called MSFS and not flying a real plane Replier be forewarned.... Especially the IFR newsgroup. Better yet, ignore him, he is a troll. At least three new ones for my new file. I'm surprised, but not surprised, that people still can't resist responding. It is starting to get quiet, though. My blood pressure is staying down, too. g -- Jim in NC |
"Morgans" wrote in
: At least three new ones for my new file. I'm surprised, but not surprised, that people still can't resist responding. It is starting to get quiet, though. My blood pressure is staying down, too. g It was a 24 hour respite here..... What made it worse was my only safe haven (rec.aviation.ifr) now has been smitten by this troll..... But I am doing good.... Still have not made a direct reply :-) Allen |
A Lieberma wrote: Mxsmanic wrote in : "Jim Macklin" writes: As filed, flight plans are not flown. VFR might well be just as simple as telling FSS VFR, Washington DC , Indianapolis, St. Louis, Destination Kansas City [the phrase close enough for government work comes to mind.] My actual plan would have many points for visual and radio navigation. You're saying that you only put a few simple indications on the form but you fly a more detailed plan? I try to figure out lots of waypoints for VFR flights ... mainly because there are so many restricted areas and Class-whatever airspaces that I have to go through or avoid. If these didn't exist, I could just look out the window in many cases; but since the chart lines aren't marked on the real terrain, I try to have enough waypoints figured out in advance so that I can be sure I'll be in the right place at the right point from a regulatory standpoint. An IFR plan is more detailed, but might only have a departure airport, a SID and airway and a STAR and might only have the airway, the feds will assign the SID and STAR anyway. Do you normally get arrival and departure procedures when you request the IFR clearance, or does the arrival procedure not come up until you are approaching your destination? I've had a lot of trouble programming a FMS with procedures on the fly, which is why I ask. I also have to try to dig up charts on the spur of the moment, which is awkward. Not one word in this post saying he is playing a game called MSFS and not flying a real plane So what? It's a reasonable question. What difference does it make what his motivation is for asking it? rg |
Mxsmanic wrote: Do you normally get arrival and departure procedures when you request the IFR clearance, or does the arrival procedure not come up until you are approaching your destination? The latter. (Obviously you get the departure clearance up front.) ATC will often change your routing en-route also. I've had a lot of trouble programming a FMS with procedures on the fly, which is why I ask. I also have to try to dig up charts on the spur of the moment, which is awkward. Indeed. Real flying is not trivial. rg |
Ron Garret writes:
The latter. (Obviously you get the departure clearance up front.) ATC will often change your routing en-route also. I can see why flying with a copilot makes IFR easier. -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Ron Garret" wrote in message
... So what? It's a reasonable question. What difference does it make what his motivation is for asking it? Trolling is not a acceptable motivation. Get a clue! |
"Matt Barrow" wrote: "Ron Garret" wrote in message ... So what? It's a reasonable question. What difference does it make what his motivation is for asking it? Trolling is not a acceptable motivation. I'm sorry, but I do not believe he is trolling. He has some annoyin habits to be sure, but if that were sufficient reason to kick someone off a newsgroup there would be no one here. rg |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| FLIGHT SIMULATOR X DELUXE 2006-2007 (SIMULATION) 1DVD,Microsoft Flight Simulator 2004, and Addons, FLITESTAR V8.51 - JEPPESEN, MapInfo StreetPro U.S.A. [11 CDs], Rand McNally StreetFinder & TripMaker Deluxe 2004 [3 CDs], other | T.E.L. | Simulators | 0 | October 14th 06 10:08 PM |
| us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 05:24 AM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
