#11
I have several questions..
1. It was a night landing and the lights are or appear to be on the gear legs, are no light landings normal ? The only landing lights are on the nose gear, no light landings are not normal IN A TRAINING - PEACE TIME ENVIRONMENT. By the time they might have realized the light was not shining on the runway... it may have been to late. It is also possible that they were directed to do lights out langings for operational security. Otherwise the tower might have mentioned that they had no lights. Deigo Garcia is a staging base for operations into Iraq. 2. With the gear up and normal power settings, wouldn't the speed be much higher? Not that much higher.. the gear does not cause much drag.. considering the size of the aircraft. I'm surprised the gear horn was not blaring.. the gear/flap/slat horn goes off at 240knts. Target approach speed and configuration will achieve proper AOA, then follow the AOA indicators, they are up front when looking out the window and in the field of view, not down on the panel. No HUD like a fighter. 3 Doesn't the crew both check gear down lights? Has the USAF stopped using tower controllers procedures, "Check gear down, cleared to land?" It may not have been an AF tower crew, it could have been a contract tower. A lot of services use that field for staging into IRAQ. They still used the standard phrase when I was flying.. even with fixed runner helicopters. Only the stick shaking pilots can see the gear lights, the aft station crews cannot, but they should have had a verbal from the pilots. 4. What is the chance they were doing a high speed low pass and just got too low? If it was a high speed low pass.. they would have slid a lot farther and the flaps/slats would (may) not have been deployed. Minimum approach speed for a no flap/no slat is about 210knts. Normal speed with flaps and slats is around 150knots, actual approach speed varies depending on landing weight. Normal speed for a low pass varies from 350knts to 550knts. I would doubt they would be doing that after an 11 hr ferry mission. Obviously there was a breakdown in CRM after a long overwater flight from Guam, and possibly staged from Dyess the previous day with a likely hood of minimum crew rest on the layover in Guam. An 11hr mission is not too long for us older types used to long missions, but on top of the flight from Dyess it adds up. It does not mention when they left the States and how long their layover was in Guam. My longest B-52 training mission was about 16hours, my longest B-1 training mission, about 10 hrs. BT |
Thanks.
"BT" wrote in message ... | I have several questions.. | 1. It was a night landing and the lights are or appear to be on the gear | legs, are no light landings normal ? | | The only landing lights are on the nose gear, no light landings are not | normal IN A TRAINING - PEACE TIME ENVIRONMENT. By the time they might have | realized the light was not shining on the runway... it may have been to | late. It is also possible that they were directed to do lights out langings | for operational security. Otherwise the tower might have mentioned that they | had no lights. Deigo Garcia is a staging base for operations into Iraq. | | 2. With the gear up and normal power settings, wouldn't the speed be | much higher? | | Not that much higher.. the gear does not cause much drag.. considering the | size of the aircraft. | I'm surprised the gear horn was not blaring.. the gear/flap/slat horn goes | off at 240knts. Target approach speed and configuration will achieve proper | AOA, then follow the AOA indicators, they are up front when looking out the | window and in the field of view, not down on the panel. No HUD like a | fighter. | | 3 Doesn't the crew both check gear down lights? Has the USAF stopped | using tower controllers procedures, "Check gear down, cleared to land?" | | It may not have been an AF tower crew, it could have been a contract tower. | A lot of services use that field for staging into IRAQ. | They still used the standard phrase when I was flying.. even with fixed | runner helicopters. | Only the stick shaking pilots can see the gear lights, the aft station crews | cannot, but they should have had a verbal from the pilots. | | 4. What is the chance they were doing a high speed low pass and just | got too low? | | If it was a high speed low pass.. they would have slid a lot farther and the | flaps/slats would (may) not have been deployed. | Minimum approach speed for a no flap/no slat is about 210knts. Normal speed | with flaps and slats is around 150knots, actual approach speed varies | depending on landing weight. Normal speed for a low pass varies from 350knts | to 550knts. I would doubt they would be doing that after an 11 hr ferry | mission. | | | | Obviously there was a breakdown in CRM after a long overwater flight from | Guam, and possibly staged from Dyess the previous day with a likely hood of | minimum crew rest on the layover in Guam. An 11hr mission is not too long | for us older types used to long missions, but on top of the flight from | Dyess it adds up. It does not mention when they left the States and how long | their layover was in Guam. My longest B-52 training mission was about | 16hours, my longest B-1 training mission, about 10 hrs. | | BT | | |
I saw the photos from this story shortly after the accident happened,
so I printed one out and I have it sitting on my desk with "GUMP" underneath. Still cracks me up when I look at it, and I make sure my students see it too. gatt wrote: A friend on another forum posted this in response to an e-mail received about a bf110 recovery in Europe: http://www.zianet.com/tedmorris/dg/bombers4.html |
"BT" wrote in message ... well... it might have been nice to see the link about the bf.. as it is written.. it implies that this link is about the bf.. Sorry, BT. They didn't provide a link or I'd have posted it in its own thread (I'd really love to see a bf110.) Haven't heard any other word. I hoped that indicated "B1" in the subject would indicate I wasn't talking about the 110 directly, but it could still be confusing I suppose. I forwarded the link to the chief flight instructor who quipped "there are those who have landed wheels-up and those who will..." (not seriously), so I asked him if he minded if I just got it out of the way now while the hardware was less expensive. -c |
Jim Macklin wrote: They did, factory test pilots just after Oshkosh last year. The Beechjet 400 also has a reinforced belly. They were just testing the gear up ability. Since its an option, youhave to wonder what the downside is? 10 knot loss of cruise maybe? -Robert |
100 pounds loss of payload.
"Robert M. Gary" wrote in message ups.com... | | Jim Macklin wrote: | They did, factory test pilots just after Oshkosh last year. | | | The Beechjet 400 also has a reinforced belly. | | They were just testing the gear up ability. Since its an option, you | have to wonder what the downside is? 10 knot loss of cruise maybe? | | -Robert | |
| Thread Tools | |
| Display Modes | |
| Plastic planes are fast but landing speed too high | P S | Owning | 30 | June 20th 06 11:30 PM |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Landing strip off of Port O Connor, TX? | Ricky Summersett | Piloting | 2 | January 24th 06 05:35 PM |
| Azusalite wheels | Fred the Red Shirt | Home Built | 7 | July 13th 04 12:15 AM |
| Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 05:35 PM |
