Fuel Pump Clue requested
Old December 15th 06, 03:40 AM posted to rec.aviation.homebuilt
Tim Hickey
Default Fuel Pump Clue requested
I have a Zenith CH-300 with a Lyc 0-320. It has an engine mounted fuel
pump, and an electric aux pump. I also have a fuel pressure gauge, and
a low fuel pressure warning light. Today, for the first time, when I
did my pre-flight run-up, the low fuel pressure light came on. When I
looked at the fuel pressure gauge, I was showing 2 pounds, or maybe
just a touch less. When I turned on the boost pump, the pressure went
right back up to 6 pounds or so.
In flight, with the boost pump off, the pressure shows about 3 or 4
psi. That is with partial throttle, and an rpm of maybe 2300 to 2400.
If I go to full throttle, the pressure will drop to around 2 psi, and
the low fuel pressure light will come on. The engine never gives any
indication of being starved for fuel. But something is changing. The
key question I have here, is how do fuel pumps wear out. Is a
reduction in delivered pressure or volume symptomatic of the pump
nearing the end of it's service life? Or maybe we have a partially
blocked check valve that is leaking a bit? Does the spring inside get
weak with time?
And, one last question, where is a good (reasonable price) source for
a pump? I have looked at Trade-A-Plane, and sticker shock is still in
effect.
Thanks.
Zenith CH-300 Driver.
Old December 15th 06, 06:34 AM posted to rec.aviation.homebuilt
Hope you can solve your problem. If not you may consider another way
out. I use two electric Facet fuel pumps in my bird and no mechanical
pump. 125 hrs so far and no problems with the fuel pumps for the 200HP
Franklin engine. Have dual batteries - one pump on each.
http://www.abri.com/sq2000
Old December 15th 06, 01:50 PM posted to rec.aviation.homebuilt
Denny
My first suspicion is that you have a pin hole in the diaphragm...
Pull the pump apart and inspect... Order parts and repair yourself...
denny
Old December 15th 06, 06:54 PM posted to rec.aviation.homebuilt
DonMorrisey
Hi Tim.
You may want to consider signing up for this email group on lycoming
engines, even temporarily and ask your question:
http://groups.yahoo.com/group/lycoming/
There are some very knowledgeable people on this list. Actually if you
sign up, search the archives, I know your problem has been mentioned in
the past.
Good luck. Don.
Old December 16th 06, 11:35 PM posted to rec.aviation.homebuilt
Tim Hickey
Thanks, Don, Good advice. I will
And Denny,
If I had a pin hole, would I not have a leak somewhere?
And the big question, where can I get replacement parts?
Thanks.
On 15 Dec 2006 09:54:57 -0800, "DonMorrisey"
Hi Tim.
the past.
Good luck. Don.
Old December 18th 06, 05:33 PM posted to rec.aviation.homebuilt
Denny
Not necessarily... The leak can be contained and yet the pressure will
be down...
There are other possibilities: worn eccentric on the cam, worn plunger
rod, bad spring on the regulator, etc... But if it had been fine and
suddenly the pressure turned up low it is likely something sudden such
as a cracked diaphragm...
Parts can be had from a number of repair shops and or vendors.. Look in
Trade-A-Plane... Check on Sacramento Air Ranch, as one source of
parts...
The first thing is to pull the pump and have someone who speaks
homebuilt aircraft help you inspect it... Usually something will be
apparent...
denny
Old December 19th 06, 03:55 AM posted to rec.aviation.homebuilt
Tim Hickey
Thanks Denny, Having built the machine from plans, I do speak
hombuilt.
And I agree with your list of potential problems.
However, I will send you a beer if you can point me to a vendor who
will sell me a new diaphram for the pump. I sure have not been able to
find one. Do you think there might be an automotive diaphragm that
would work?
At this point, my money is on the inlet check valve leaking.
Sometimes. At shut down, the pump seems to hold pressure between
itself and the carb.
I hate to replace the pump not knowing that it is the problem, but I
am running out of ideas.
Thanks
Tim.
be down...
parts...
apparent...
denny
Old December 19th 06, 04:46 AM posted to rec.aviation.homebuilt
Orval Fairbairn
hombuilt.
would work?
Thanks
Tim.
Bad news. IIRC, diaphragm-type fuel pumps are NOT rebuildable!
Apparently, FAA thinks that there is too much opportunity for failure in
rebuilt pumps of this type. Also, automotive diaphragms are thinner than
those in aircraft pumps.
If your check valve is leaking, you just MIGHT be able to substitute a
new automotive valve.
be down...
parts...
apparent...
denny
Old December 19th 06, 04:29 PM posted to rec.aviation.homebuilt
A leaking diaphragm will often allow fuel into the crankcase and
the oil level will rise, smell like fuel and get really thin.
More likely it's a faulty check valve, or if the engine is one
that's flown for short flights, the spring in the pump has corroded and
broken, reducing the output pressure. The spring is on the crankcase
side of the diaphragm and the corrosive moisture and blowby gases can
attack it. If this is the case, the magnetos should be looked at as
well. Their impulse couplngs can corrode and their springs might break,
retarding the timing to around zero BTDC and lowering power to some
useless level. A real danger with the Bendix dual magneto used on some
Lycs. Both mags are driven by the one gear and coupling.
Dan
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 08:04 PM
Fuel pump cooling shroud? Jim Burns Owning 3 September 5th 06 02:06 PM
Exposed Electrical Wires in Boeing 737 Fuel Tanks! Larry Dighera Piloting 0 July 17th 06 07:13 PM
Night flying in the mountians in a cessna 150, NW_PILOT Piloting 149 March 4th 05 07:13 PM
Christen Fuel Pump troubleshooting ShawnD2112 Aerobatics 4 August 17th 03 01:08 PM
