airplane construction
Old January 12th 07, 07:43 PM posted to rec.aviation.piloting
Mike[_11_]
Default airplane construction
Jim Macklin wrote:
Understand that bolts used in aircraft construction are not
"hardware store" items. The steel and the tolerances for
aircraft grade fasteners are better than hardware store
Grade 8 bolts. Beech uses bolts in tension to hold the wing
on the Bonanza, Baron and King Air models. When there is a
crash, the bolts are rarely broken. But if the bolts are
not properly installed and maintained, corrosion can weaken
the bolts causing them to break.
Cessna uses a bolt installed in shear through fittings like
you fingers meshed. This is called "double shear" and as
long as the bolt is a snug fit in the hole the bolt can hold
more load than the airplane is designed to experience.
But a bolt in tension is stronger than a bolt in shear.
"george" wrote in message
| Bill Watson wrote:
| The more you know the more you can do.
| Nothing like assembling a sailplane, loading it full of
water and
| bombing down a ridge at red-line for a few hours.
| Then you just pull the wings and tail back off and
trailer it home.
| the size of those pins/bolts that hold the wings on
should attract the
| attention of any pilot not used to rigging sailpanes :-)
Here's a good illustration/animation on "double shear" connections:
http://www.ijee.dit.ie/OnlinePapers/...ted_double.htm
Mike
  #32
Old January 12th 07, 07:46 PM posted to rec.aviation.piloting
Mike[_11_]
Matt Whiting wrote:
Jose wrote:
I'd have to pull out my AISC manual to be sure, but I believe that a
bolt in double shear has more capacity than in tension. If you are
comparing single shear to tension, then I agree with you.
What is "double shear" and "single shear"?
It refers to the number of planes in shear. Think of the rivet in a
scissors. There is one shear plane where the two halves of the scissors
meet and are held together by the pin/rivet.
Now think of a sandwich of three pieces of metal held together with a
bolt or pin or rivet. There are now two planes that are in shear and
thus you have twice as much shear resistance of the outer two pieces of
metal are pulled one direction and the middle piece is pulled another
direction.
Matt
Here's a good illustration/animation:
Mike
  #33
Old January 12th 07, 08:23 PM posted to rec.aviation.piloting
Jose
Thanks. It's a way to spread the shear load.
Jose
He who laughs, lasts.
  #34
Old January 12th 07, 10:54 PM posted to rec.aviation.piloting
Matt
That's right. The 70% figure refers to single shear.
I made a mistake on the Grade 8 bolt head marking. It has six
radial marks, not five. Five is a Grade 7, not a common bolt. The
grades go clear to Grade 16, IIRC.
Dan
  #35
Old January 12th 07, 10:56 PM posted to rec.aviation.piloting
Last summer, Texas/Louisiana neighborhood, I think. The
details were in the story, not the time and place.
The only Mooney fatal I could find in the SE last summer was this one
http://www.ntsb.gov/ntsb/brief.asp?e...31X01061&key=1
Perhaps that's the one?? The report is only preliminary but doesn't
mention whether the pilot was with the aircraft or not.
-Robert
That's likely it. The report gives no details whatever of the
condition of the wreckage; perhaps that's forthcoming.
Dan
  #36
Old January 13th 07, 07:12 AM posted to rec.aviation.piloting
Jim Macklin
Aircraft grade bolt have many standards, more to do with
heat-treating and plating and tolerances on the thread and
shank fit and finish. Aircraft hardware is a detailed
study all to itself.
like
as
can hold
shear.
believe that a
If you are
you.
| Matt
It has six
bolt. The
| Dan
  #37
Old January 13th 07, 07:05 PM posted to rec.aviation.piloting
karl gruber[_1_]
Jim Macklin wrote:
Understand that bolts used in aircraft construction are not "hardware
store" items. The steel and the tolerances for aircraft grade fasteners
are better than hardware store Grade 8 bolts. Beech uses bolts in
tension to hold the wing on the Bonanza, Baron and King Air models. When
there is a crash, the bolts are rarely broken.
Well, Beech used to use bolt in tension on the King Air. But a bunch of them
had their wings fall off.
Now they use bolts in shear.
Karl
N185KG
  #38
Old January 13th 07, 11:07 PM posted to rec.aviation.piloting
Jim Macklin
I have not looked at a recent King Air, but I think that
they still use the traditional Beech bath-tub fitting and
tension bolts.
"karl gruber" wrote in message
not "hardware
uses bolts in
Air models. When
But a bunch of them
| Karl
| N185KG
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons Curtl33 General Aviation 7 January 10th 04 12:35 AM
