Air Pressure Switch for Hour Meter
Old January 20th 07, 04:28 AM posted to rec.aviation.homebuilt
NEW-USER
Default Air Pressure Switch for Hour Meter
Hello all, can somebody suggest a good place to get an air pressure
switch to hook into the Pieto line of an aircraft which will then in
turn operate the hourmeter when the aircraft is flying.
I have a friend who has a really long taxi and warmup time and he tells
me he is putting too many hours on these aircraft which are not from
actually flying. He wants to install a switch which will give him more
accurate times.
I have had a quick search of the Internet but unfortunately cannot find
exactly what we need (i think). Any help appreciated, regards Michael
Old January 20th 07, 04:45 AM posted to rec.aviation.homebuilt
jerry wass
See if you can figure out a placement on the landing gear for a simple
microswitch with a spring leaf for overtravel.---Hatz??
or make your own pressure switch , a diaphragm of thin glove leather , a
thin alum plate glued on one side to actuate a small
microswitch--microswitch will probably supply enough spring pressure to
return the diaphragm. They haven't found anything any better for wind
organ actuating mechanisms in a thousand years or so.--- WW-II airspeed
instruments used leather diaphragms in their airspeed indicators.You
should have a water trap in the pitot line anyhow.--wassbiplane
accurate times.
Old January 20th 07, 09:12 AM posted to rec.aviation.homebuilt
Marc J. Zeitlin
I used a switch in the pitot line for exactly this purpose. Go to
"www.digikey.com" and search for "pressure switch". Determine what
speed you want the switch to come on at (I chose 40 mph) and then
determine what pressure will be created at that speed and choose the
appropriate switch. I don't remember which one I used.
Marc J. Zeitlin
http://www.cozybuilders.org/
Copyright (c) 2007
Old January 21st 07, 03:50 PM posted to rec.aviation.homebuilt
Ron
Good idea! As I don't know how to calculated this, to get me in the
ballpark do you know/remember the pressure at 40 mph?
Ron
"Marc J. Zeitlin" wrote in message
switch to hook into the Pieto line of an aircraft which will then in turn
"www.digikey.com" and search for "pressure switch". Determine what speed
you want the switch to come on at (I chose 40 mph) and then determine what
pressure will be created at that speed and choose the appropriate switch.
Marc J. Zeitlin
Copyright (c) 2007
Posted via a free Usenet account from http://www.teranews.com
Old January 22nd 07, 02:20 AM posted to rec.aviation.homebuilt
CW Crane
I saved this from a post here some years ago:
begin save
Document AN 05-10-24 specifies the airspeed that should be indicated
by a given water column. There is an approximation formula that says that
Airspeed (Statute MPH) = sqrt (Water Pressure In Inches * 1980.0)
If you do the formula right, 100 MPH should come out about 5 inches of
water column.
end save
I use 30 feet of water for one atmosphere (approximately 15 psi). None of this
is exact but then again nothing is.
CW
Ron
Marc J. Zeitlin
Copyright (c) 2007
Hmm. REALLY not understanding circulation xerj Piloting 22 September 20th 05 12:32 AM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 10:14 PM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 08:35 PM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 07:58 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 01:35 AM
