Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Rotorcraft
I know almost nothing on helicopters...
Old January 20th 07, 04:43 AM posted to rec.aviation.rotorcraft
Externet
Default I know almost nothing on helicopters...
Hi. First post here.
Always got it in my head, decided to ask today...
What if the body of a helicopter was built shaped with some tilt, as a
"sail" or with a vertical controllable aileron by its bottom, or both;
in such way that the downstream air flow from the main rotor caused the
same anti-torque as a tail rotor?
Trying other words... If the tail of a helicopter was vertical thin
wing shaped, with a controllable aileron to counteract the main rotor
torque by deflecting some downflow sideways in the right amount, to
eliminate the tail rotor... would it work?
Would it be too shaky because of the main blades spacing ? Pardon if
my wording is not proper.
Miguel
Old January 20th 07, 08:09 AM posted to rec.aviation.rotorcraft
General Dog
Miguel
Tailbooms have been made with the wing shape you mention, and a
controllable aileron isn't necessary. The idea works but isn't enough, by
itself, to completely eliminate the tail rotor.
Old March 17th 07, 01:15 PM posted to rec.aviation.rotorcraft
Linc
You probably would encounter different issues. One would be the
downward pressure on the fin would require a different rigging of the
main rotor that would limit forward tilt and airspeed. Another
consideration would be that it would become less effective or
ineffective in forward flight as less of the downwash would be
available for redirection to counter the torque effect. Above ETL most
light helicopter tail rotors are considered to be out of the rotor
downwash. And I think that simply using an airfoil or deflector alone
would not give you the amount of control that any of the current
antitorque methods provide.
The closest you can get is the NOTAR system developed by Hughes Tool
Co. Aircraft Division and currently produced by MD Helicopters (http://
www.mdhelicopters.com). Which uses the Coanda effect but requires
additional measures to ensure the boundary layer exists to get the
lift effect.
Linc
Miguel
Boeing CH-47 Chinook Wins Deal To Build Helicopters, Beating Lockheed HH-60 Pave Hawks Mike Naval Aviation 2 November 11th 06 05:32 AM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
FA: The Helicopters Are Coming The Ink Company Aviation Marketplace 0 August 10th 03 06:53 PM
