Can you dry sump a type1 VW engine?
Old January 24th 07, 04:03 AM posted to rec.aviation.homebuilt
Fonz
Default Can you dry sump a type1 VW engine?
God Morning all.
Brief question. Is is possible (has it been done), to dry sump a type1 VW
engine, such as the one marketed by great planes? The use, inverted flight,
and mild -ve Gs.
Thanks in advance for any replies.
Rob.
Melbourne Australia.
Old January 24th 07, 08:46 AM posted to rec.aviation.homebuilt
Anthony W
Fonz wrote:
God Morning all.
and mild -ve Gs.
Rob.
I don't know about inverted but VW hot rodders have been dry sumpping
aircooled VW engines for many years. The kits used to be readily
available but I haven't looked for one in many years...
Tony
Old January 24th 07, 04:34 PM posted to rec.aviation.homebuilt
Jarhead
"Fonz" wrote in message
| God Morning all.
type1 VW
flight,
| and mild -ve Gs.
| Rob.
A quick search provided this link:
http://users.lmi.net/~ryoung/Sonerai...VW_aeroen.html
EAA has a link too, but I am no longer a member and couldn't access it.
There is a Australian VW group called VeeDub that may be of help to you.
Jarhead
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= East/West-Coast Server Farms - Total Privacy via Encryption =---
Old January 24th 07, 07:57 PM posted to rec.aviation.homebuilt
Yes. In fact, it's a standard procedure for high-output engines based
on after-market VW components installed in dragsters.
and mild -ve Gs.
Entirely different subject, if you mean sustained flight whilst
inverted or knife-edged. Not that it can't be done but that weight &
cost of doing so is generally impractical for such a small engine.
-R.S.Hoover
Old January 25th 07, 12:09 AM posted to rec.aviation.homebuilt
flybynightkarmarepair
On Jan 24, 7:34 am, "Jarhead" wrote:
"Fonz" wrote in ...
type1 VW
flight,
| and mild -ve Gs.
| Rob.
A quick search provided this link:http://users.lmi.net/~ryoung/Sonerai...VW_aeroen.html
Everything I wrote about the subject in the referenced link still
applies, but I didn't mention you'll need to figure out a way to get
oil out of the top of the engine case, and possibly also the valve
covers, and run it to the shuttle valve. Not For Beginners.
Old January 25th 07, 06:29 PM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On 24 Jan 2007 15:09:24 -0800, "flybynightkarmarepair"
"Fonz" wrote in ...
type1 VW
flight,
| and mild -ve Gs.
| Rob.
Without adding a proper seal to the pulley end of the shaft you can't
implement the "rotax dry sump" solution. It works good on Soobs and
'Zooks etc.
Posted via a free Usenet account from http://www.teranews.com
Old January 27th 07, 08:28 AM posted to rec.aviation.homebuilt
Fonz
Thanks for all replies and links
Rob
ps.com...
and mild -ve Gs.
-R.S.Hoover
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
M20 Air/Oil separator Jay Honeck Owning 70 September 3rd 04 07:34 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Motorgliders and gliders in US contests Brian Case Soaring 22 September 24th 03 01:42 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
