FAA MAY TAKE AWAY PANEL-MOUNT OPTION FOR PORTABLE GPS
Old February 3rd 07, 05:57 AM posted to rec.aviation.piloting
Jay Honeck
Default FAA MAY TAKE AWAY PANEL-MOUNT OPTION FOR PORTABLE GPS
How did you route the power and antenna wires? Did you wire the power
to a circuit breaker or leave the cigar lighter plug on? Are you sure
the wiring won't catch in the sprockets and chains of the aileron
controls?
Everything was professionally installed by McCandless Aviation in
Waterloo, IA (KALO). I've looked under the panel myself, and
everything is very professionally zip-tied up and out of the way.
It's a fantastic improvement over the octopus of wires that comes with
a yoke mount.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 3rd 07, 12:11 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 2 Feb 2007 20:43:25 -0500, "John T"
wrote in
"Larry Dighera" wrote in message
They don't make 'laws', so how can they make something 'illegal'.
The OP meant to say, a violation of regulations, not illegal, I think.
You've mentioned this distinction at least a couple times recently, but I'm
thinking it's a lot less black & white than I'd like it to be.
When you have such a thing as an "administrative law judge" and Congress
forfeiting (gladly?) to the Executive branch broad regulatory power,
regulations begin to carry the weight of "law" and "violation of
regulations" becomes essentially the same thing as "illegal."
We disagree.
The only significant distinction is jail time or the lack thereof.
Of course, you are free to believe what you like. However, because
there is no presumption of innocence, nor judicial due process, nor
arraignment, nor trial by jury, etc., there are significant
differences between a court case and an administrative action. If you
are unable to discern the distinctions between them, you fail to
appreciate the true disadvantage of a pilot facing the FAA.
However, if the penalty is severe enough, losing one's estate is not
much better than simple jail time.
To my knowledge, the FAA has only limited power to impose civil fines,
and personally, I consider the lack of threat of incarceration a very
significant difference. And You'll have to cite a precedent before
I'll believe a pilot facing an FAA administrative action is subject to
losing his "estate," what ever that means.
It is my understanding, that the FAA's power to impose penalties on
airmen is limited to a $1,000.00 civil fine and certificate
suspension, or revocation, but I have no first hand knowledge,
thankfully.
So just how "black and white" would you like it to be?
Old February 3rd 07, 02:13 PM posted to rec.aviation.piloting
LWG
This is absolutely right. And administrative regulations can be integrated
with fines and imprisonment. Look at EPA and OSHA, for example.
Here we are talking about a federal forum, but the unchecked growth of
administrative agencies at all levels, including the state, has allowed our
government to run amuck.
regulations" becomes essentially the same thing as "illegal." The only
significant distinction is jail time or the lack thereof. However, if the
penalty is severe enough, losing one's estate is not much better than
simple jail time.
John T
Old February 3rd 07, 02:46 PM posted to rec.aviation.piloting
Paul Tomblin
thankfully.
They can also declare that your plane with this installation is no longer
airworthy, which would mean you've just lost most if not all of the value
of your airplane. That seems like a pretty strong disincentive.
Paul Tomblin http://blog.xcski.com/
There's going to be no serious problem after this. --Ken Thompson
Old February 3rd 07, 07:18 PM posted to rec.aviation.piloting
Vaughn Simon
"Paul Tomblin" wrote in message
I think you are overstating your case just a bit, since it would presumably
only require removal of the offending bit to make the plane airworthy again.
It's not as if you have to scrap the airframe.
Vaughn
Old February 3rd 07, 07:22 PM posted to rec.aviation.piloting
John T
We disagree.
Perhaps, but I don't think by much.
Actually, I do appreciate and agree that facing regulatory violations is
quite an imposing situation where the accused still needs an attorney and
may appeal rulings very similarly to criminal cases.
I was broadening the position to more than just the FAA, but even talking
specifically about the FAA, think about the term "administrative law judge"
(as one might presumably face in appealing FAA administrative actions). This
title alone implies regulations carry the weight of law.
I *think,* based on the flavor of your comments, you and I agree regulatory
agencies have more power than they should.
John T
http://sage1solutions.com/blogs/TknoFlyer
Reduce spam. Use Sender Policy Framework: http://openspf.org
____________________
Old February 3rd 07, 07:28 PM posted to rec.aviation.piloting
Newps
A bit? It's a gross misstatement.
Softcomm panel mount intercom? Junk? [email protected] Owning 10 November 26th 05 07:46 AM
Panel mount for handheld Garmin GPSMap X96 series Brock Boss Owning 2 September 25th 05 02:26 AM
manual for garmin 100 panel mount. Ray Toews Home Built 1 September 11th 05 11:28 PM
Need panel mount for Delcom Radio Mark Lenox Soaring 3 June 24th 05 04:31 AM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 04:33 PM
