Cold Weather PreHeating
Old February 9th 07, 01:42 AM posted to rec.aviation.owning
Capt. Geoffrey Thorpe
Default Cold Weather PreHeating
... Even better would be a drilled camshaft that would have small
oil ports in the lobes, or even right next to the lobes, to get the
lifter faces wet.
Dan
http://www.firewallforward.com/firew...b_page_011.htm
Geoff
Old February 9th 07, 02:41 AM posted to rec.aviation.owning
Michelle P
pgbnh wrote:
Now that winter has finally arrived in the Northeast, it is time to enjoy
the benefits of cold, dense air. wow - I wish I could see those climb rates
in August.
But anyway, what's the common wisdom on preheating. Granted, in an ideal
world, preheating is probably a good idea anytime it's below 40, but it IS a
pain for those of us who are forced to tie down outside and have no access
to electricity. At what temperature point are you comfortable starting
WITHOUT a preheat? (If it matters, this is for a Lyc IO360 that will start
easily down to about 10 deg).
Any mechanics care to comment on what they have seen happen to engines which
have routinely been started cold?
I have sump heater that will keep the oil warm. I keeps the rest of the
engine moderately warm. I will plug it in when the temp drops below 50.
Sounds a little high? well If I can keep the oil warm and reduce the
stress on the engine components at startup I will. Easier on the starter
ring gear and the case (IO-540).
Michelle (A&P)
Old February 12th 07, 08:57 PM posted to rec.aviation.owning
On Feb 8, 5:42 pm, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way
lifter faces wet.
Dan
I suppose these guys have a patent on that cam so that Lycoming
can't use the idea in factory-new or O/H engines without paying big
royalties for it. It's about time someone did it, though. Glad to see
it's available. Lycoming should have done it themselves a long time
ago. Surely it's not because they didn't think of it.
Dan
Cold weather starting. Mike Noel Owning 17 December 21st 05 04:24 AM
Warm Weather Pilots, Cold Weather Ops john smith Piloting 3 December 2nd 04 05:00 PM
Cold Weather Winter Flying Q's NW_PILOT Piloting 20 November 9th 04 04:32 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 01:07 AM
Cold Weather Flying Jose Vivanco Owning 27 October 16th 03 12:27 PM
