The nail in the coffin: TIS and Mode-S
Old March 26th 07, 06:33 PM posted to rec.aviation.ifr
scott moore
Default The nail in the coffin: TIS and Mode-S
Mode-S/TIS transponders cost more, turns out, they cost
substantially more to certify for IFR as well. I'm beginning to come
around to the viewpoint of those here who say that any modernization
that comes from the FAA will usually be a costly waste of time. The
FAA is abandoning TIS slowly, and would have done it fast if we and
the AOPA hadn't complained about it.
Now I fully well expect ADS-B to be held hostage to the FAA's funding
scam:
FAA: Funding Tied To Modernization
The FAA must implement changes to the way it is funded before it can
afford to embrace the myriad technologies that are envisioned for the
Next Generation Air Transportation System, according to senior FAA
staffers. Appearing before the Senate aviation subcommittee, Charles
Leader, director of the Joint Planning and Development Office, told
committee members that the controversial system of user fees and tax
increases now under consideration by Congress for FAA reauthorization is
a key element of FAA modernization. "Modernization and moving to NextGen
is inextricably linked to changes in the FAA’s financing system," Leader
said.
I guess we can expect the FAA to axe or radically slow down ADS-B in
retaliation for not getting what they want. It would not work in any
case. The attempt to shift costs to GA would yield less than the present
system on day one, and rapidly decline as GA users bailed out of
aviation or cut back on operations.
Scott Moore
Old March 26th 07, 06:52 PM posted to rec.aviation.ifr
Robert M. Gary
scam:
is inextricably linked to changes in the FAA's financing system," Leader
said.
Scott Moore
Our 182T has TIS. Its a very nice system but it doesn't seem very
necessary in the face of ADS-B.
-Robert
Old March 26th 07, 08:05 PM posted to rec.aviation.ifr
Matt Barrow[_4_]
"scott moore" wrote in message
scam:
afford to embrace the myriad technologies that are envisioned for the Next
Generation Air Transportation System, according to senior FAA staffers.
Appearing before the Senate aviation subcommittee, Charles Leader,
director of the Joint Planning and Development Office, told committee
members that the controversial system of user fees and tax increases now
under consideration by Congress for FAA reauthorization is a key element
of FAA modernization. "Modernization and moving to NextGen is inextricably
linked to changes in the FAA’s financing system," Leader said.
Get ahold of Robert Poole's article in the November issues of "Professional
Pilot" if you can(or leave me a note and I'll send you it in PDF form). He
goes into some detail about the issue from the standpoint of User Fee's in
just that manner.
Matt B.
Old March 27th 07, 08:13 AM posted to rec.aviation.ifr
scott moore
scam:
said.
Scott Moore
-Robert
Let's go over this right quick. The FAA issued the TIS system, a bunch
of manufacturers (ok, damm few manufacturers) bit the bait and built
such a unit. Then the FAA cancellated it.
Now the FAA is a' saying that in orders to get ADS-B out there, they
needs to get deep, deep into your pockets.
Now tell me exactly why you think the FAA is going to hold ADS-B
sacred.
Now whilst you are thinking about that, think about this. Why would it
matter, to the ADS-B "cause" per sey, if the FAA should suddenly fall
into an economic sink hole and die?
Let's say, just say, that the FAA disappeared. WAAS would die, right?
Why? Well, that there satellite needs operation and maintenence. VORs,
ILSes and the rest would go for the same reason.
What would ADS-B do? Die? Why? Think hard before you answer.
What ADS-B does is give two black boxes, approaching each other,
the ability to see each other. They do this the most direct way
possible, by talking to each other via line of sight. In fact, its
the perfect application for two such boxes, because airplanes that
cannot see each other (have a direct line between them without
intervening obstacle) generally don't collide. In addition, these
boxes get more accurate relative to each other the closer they get,
again, just what you want in a collision avoidance system [1].
Now imagine that while your two airplanes are (or are not) colliding,
the FAA runs out of money. What occurs?
Nothing, right?
Well, that's the basic nature of the system. However, the FAA is not
real big on basic natures of things, so they rigged the system so that
they are between those two black boxes. Now this is a fairly interesting
trick. How could the FAA manage to be between two colliding airplanes?
Well, it works if FAA ground equipment is required to "translate"
between two completely different types of ADS-B. So lets say, just
say, that if you were stupid, greedy or both, you would design the
system so that one group got ADS-B system type "A", and the other
got ADS-B system type "B". Well, then you would have, as the French
say a "voila". There would be no way the system could work unless
you translate system A to system B, and B to A, etc. And you would
need ground stations to do that. Then you would be needed and
loved because you owned them nice ground stations without fer which
them A and B airplane types would be a collidin' all overs the place.
Now that leaves a big what if. If you are a genius A-B system designer
dude, you need to have at least one of them thar A or B folks agree
not to fly out of the range of a ground station, or even the line
of sight thereof. Otherwise, you would get one of those A folks,
and one of them B folks, out of the line of sight, behind a
mountain where they would collide and start blaming the FAA.
And so the pieces to the puzzle all fit together. The FAA designs
ADS-B not to work without them. ADS-B boxes, expensive or cheap are
the pilot's/airplane owners problem to purchase, and the FAA's part in
it was pretty much done after the design of the thing was worked out
(hint: the FAA didn't have much to do with that, either). But those
"required" ground based systems prevent all them ADS-B boxes from
all talking to each other, and cutting the FAA out of the "action".
Of course, isn't the idea ridiculous on it's face? Who would agree
to always fly in line of sight to a FAA ground station? If such a
group exists, why (oh why) would they agree to a system that keeps
the FAA in control, even if it is not only not necessary, but actually
harms the function of ADS-B (by preventing two ADS-B boxes from
contacting each other by direct line of sight)?
Who might this mysterious ADS-B "system A" group be?
I'll leave you with a big hint: They don't have any problem at all
with the proposed FAA funding scheme.
Scott.
Old March 27th 07, 08:17 AM posted to rec.aviation.ifr
scott moore
scam:
said.
Scott Moore
-Robert
sacred.
Nothing, right?
Scott.
[1] Because ADS-B provides the other box with the information it
used to arrive at a solution (which satellites). This allows the
other box to run its calculation the same way, and the result is
a "difference" calculation that is very accurate, because it essentially
ignores localized GPS reception errors.
Old March 27th 07, 08:30 PM posted to rec.aviation.ifr
C J Campbell[_1_]
The FAA is not going to disappear, whether we want it to or not.
Are you sure that the FAA funds GPS satellites?
VORs are on the hit list anyway. Eventually, they will all be shut
down, just like Omega, VAR, and NDB. :-)
Waddling Eagle
World Famous Flight Instructor
Old March 27th 07, 08:38 PM posted to rec.aviation.ifr
Mxsmanic
C J Campbell writes:
I don't believe the FAA contributes anything to GPS satellites. They do
contribute to WAAS, but there are no satellites in that.
And then the terrorists can have a field day with just one little box in a
field near busy airspace.
Old March 27th 07, 08:41 PM posted to rec.aviation.ifr
John R. Copeland
"C J Campbell" wrote in message news:2007032711300622503-christophercampbell@hotmailcom...
He said WAAS.
Old March 27th 07, 08:43 PM posted to rec.aviation.ifr
Paul Tomblin
Wanna bet?
http://gps.faa.gov/FAQ/index.htm
"These correction messages are then broadcast through communication
satellites to receivers onboard aircraft using the same frequency as GPS."
But that's just the FAA, what do they know. Obviously you got better
information from your flight simulator manual.
Paul Tomblin http://blog.xcski.com/
And the Prime Directive would be a valid excuse to do absolutely nothing
all day. "I can't fix $LUSER's problem, because to do so would interfere
with their development/evolution. Sorry." -- James Turinsky
Old March 28th 07, 02:10 AM posted to rec.aviation.ifr
Roger[_4_]
On Tue, 27 Mar 2007 18:43:48 +0000 (UTC),
Wanna bet?
The only thing I found was slightly different. "These corrections
messages are then broadcast to receivers onboard the aircraft using
the frequency as the GPS". It said nothing about being broadcast
through communications satellites, or I missed it.
IF correction messages can be sent from local areas back to satellites
that would make they very vulnerable to tampering with the data.
www.rogerhalstead.com
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 08:40 AM
Mode S to become requirement? Bob Chilcoat Owning 6 July 15th 04 12:25 AM
Zinni: The nail in the neocon coffin Garamondextended Military Aviation 1 May 25th 04 08:47 AM
Got a nail biter you want to share? pdxflyer Piloting 0 January 8th 04 08:28 AM
VNE and the "coffin corner"? Jim Soaring 13 December 17th 03 07:07 AM
