The nail in the coffin: TIS and Mode-S
Old March 28th 07, 02:29 AM posted to rec.aviation.ifr
Mxsmanic
Default The nail in the coffin: TIS and Mode-S
Paul Tomblin writes:
Wanna bet?
http://gps.faa.gov/FAQ/index.htm
"These correction messages are then broadcast through communication
satellites to receivers onboard aircraft using the same frequency as GPS."
The communication satellites mentioned are not GPS satellites.
But that's just the FAA, what do they know. Obviously you got better
information from your flight simulator manual.
No, I got my information from the original GPS specifications, years ago,
along with some later reading to try to keep up on trends. That's one reason
why I'm able to distinguish between communication satellites and navigation
satellites when I read about them, which helps prevent me from saying foolish
things in open discussions.
Old March 28th 07, 02:31 AM posted to rec.aviation.ifr
Mxsmanic
Roger writes:
The only thing I found was slightly different. "These corrections
messages are then broadcast to receivers onboard the aircraft using
the frequency as the GPS". It said nothing about being broadcast
through communications satellites, or I missed it.
As I recall, the WAAS correction data are broadcast over large areas by
relaying them through communication satellites. However, these communication
satellites are not part of the GPS system, and they are not GPS satellites.
IF correction messages can be sent from local areas back to satellites
that would make they very vulnerable to tampering with the data.
Yes. But the satellites in question are not part of GPS, fortunately.
It _is_ a bit unfortunate that WAAS is using the same frequencies to create
pseudosatellites, which is essentially spoofing GPS, and it's not a good idea
to have spoofing technology in such widespread use, no matter what the
justification.
Old March 28th 07, 03:33 AM posted to rec.aviation.ifr
Paul Tomblin
Wanna bet?
Your statement, I quote was "They do contribute to WAAS, but there are no
satellites in that." There *are* satellites in that, so you are wrong.
100% wrong. Admit it and stop weaseling.
Paul Tomblin http://blog.xcski.com/
Today is a good day. Not because anything wonderful is happening, so
much, but because my definition of a 'bad day' has been revised.
-- Chris Klein
Old March 28th 07, 03:41 AM posted to rec.aviation.ifr
Paul Tomblin
In a previous article, Roger said:
On Tue, 27 Mar 2007 18:43:48 +0000 (UTC),
If you were using WAAS, you should get to know the WAAS satellite coverage
areas. I think they fixed the problem, but for a while there the coverage
was **** poor is in New Hampshire and Maine.
At one time the FAA was talking about using ground based broadcast
stations, called LAAS (Local Area Augmentation System). (Which, by the
way, used different frequencies than the GPS constellation.) As far as I
know, none have been deployed yet or they dropped the idea.
"Of the many tragedies of Vietnam, this raw class discrimination strikes
me as the most damaging to the ideal that all Americans are created equal
and owe equal allegiance to their country." - Colin Powell (pre-sell out)
Old March 28th 07, 04:02 AM posted to rec.aviation.ifr
John R. Copeland
"Paul Tomblin" wrote in message ...
That reminds me -- I miss hearing from John "WAAS-is-dead" Tarver.
He was almost as amusing as the manic simmers.
Maybe we ignored John too much and he went away.
Our loss, I guess. :-/
Old March 28th 07, 06:23 PM posted to rec.aviation.ifr
andrew m. boardman
I don't know if I'd call it "**** poor", but much of Maine and
ocasionally the rest of New England lose LPV coverage often.
Southern California often loses out, too. Here's a real-time
coverage map:
http://www.nstb.tc.faa.gov/vpl.html
Old March 28th 07, 06:45 PM posted to rec.aviation.ifr
Jon
Wanna bet?
Not to mention "contribute to WAAS" being off the mark.
It's worth pointing out that the GEOs also being used to provide a
separate ranging source (bent pipe) in addition to the information
being supplied (corrections, integrity, etc.) in the WAAS messages.
-- Chris Klein
Regards,
Jon
Old March 28th 07, 06:59 PM posted to rec.aviation.ifr
scott moore
John R. Copeland wrote:
"C J Campbell" wrote in message news:2007032711300622503-christophercampbell@hotmailcom...
On 2007-03-26 23:13:16 -0700, scott moore said:
Let's say, just say, that the FAA disappeared. WAAS would die, right?
Are you sure that the FAA funds GPS satellites?
He said WAAS.
Excellent. Someone who reads.
Scott
Old March 29th 07, 01:44 AM posted to rec.aviation.ifr
john smith[_2_]
I think there were two deployed. The manufacturer was a Canadian company
that was bought out by Honeywell.
Old March 29th 07, 03:36 AM posted to rec.aviation.ifr
Barry
Default LAAS
http://gps.faa.gov/programs/laas/currentnews-text.htm
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 08:40 AM
Mode S to become requirement? Bob Chilcoat Owning 6 July 15th 04 12:25 AM
Zinni: The nail in the neocon coffin Garamondextended Military Aviation 1 May 25th 04 08:47 AM
Got a nail biter you want to share? pdxflyer Piloting 0 January 8th 04 08:28 AM
VNE and the "coffin corner"? Jim Soaring 13 December 17th 03 07:07 AM
