Hershey bar wing vs composite wing - how much drag?
Old March 29th 07, 07:59 PM posted to rec.aviation.owning
Montblack
Default Hershey bar wing vs composite wing - how much drag?
("cavelamb himself" wrote)
And a LOT of the drag is from cooling the engine!
There is an ideal place for big gains.
Ercoupe, Cessna 172, Piper Warrior:
How much drag would be eliminated it the prop was spun from, say, a
(hypothetically capable) electric motor - of the same weight as the engine?
An electric motor that needs little of the cooling air (drag) required by
the gas engines.
WAG, is a LOT ...33%?
Whatever the guesstimated drag number settled on, what then would that
number mean in cruise speeds, or fuel burn? 10% improvement? 20%
improvement? 30%?
Montblack
  #32
Old March 30th 07, 12:20 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Matt Whiting
DR wrote:
Hi,
I don't see why a composite should be heavier:
For carbon composite, the Young's modulus is ~70GPa for a density of 1.3
g/cm3. Al has the same Young's modulus but twice the density (2.7
g/cm3). For glass the strength is about half but again the weight is
halved too -so it's not a gain over Al. I think the composites excel in
their lack of rivets and joining pieces tho...
Last I knew, Young's modulus was a measure of stiffness, not strength.
Matt
  #33
Old March 30th 07, 02:20 AM posted to rec.aviation.owning
Kyle Boatright
"Montblack" wrote in message
engine? An electric motor that needs little of the cooling air (drag)
required by the gas engines.
improvement? 30%?
Montblack
You're on the right track if you can work with a semi-trailer sized battery
or a 500 mile extension cord. ;-)
KB
  #34
Old March 30th 07, 08:47 AM posted to rec.aviation.owning
Montblack
("Kyle Boatright" wrote)
battery...
I'm putting you down for 18%.
Montblack
I’m a little overweight and my log book’s way behind
Nothing bothers me tonight
I can dodge all them scales all right
Six days on the road and now I’m gonna make it home tonight
fixed wing or rotary wing? Craig Campbell Rotorcraft 23 March 27th 07 07:16 AM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 12:10 PM
composite wing, wing spars Dave Schneider Home Built 4 May 21st 04 06:35 AM
Fuel Dip Tube for Hershey-bar Wing Cherokees? Bob Chilcoat Owning 3 May 3rd 04 11:29 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 04:46 PM
