#101
wrote in message ... "Tarver Engineering" wrote: I don't mind if you can learn Mike, but so far, you are just another dip****. Coming from you (of all people!) that's incontrovertible proof that I'm in good company. You caught the attention of ram's peanut gallery, but insulted the professionals. Fluff you are, then. |
#102
wrote in message ... "Tarver Engineering" wrote: Fluff you are, then. Speaking of "fluff," you need some fresh bait. I'm trying to fend you off from the boat with an oar already, lune. |
#103
In article , "Paul J. Adam"
wrote: In message , Harry Andreas writes In article , "Paul J. Adam" wrote: Of course, if the GPS co-ordinates are wrongly calculated, wrongly entered, or the GPS battery fails midflight, that's a very lost formation... with no navigators to rescue them. Military aircraft GPS use aircraft power with transient backup, not batteries. Assuming a fully integrated GPS, rather than a civilian handheld attached to the glareshield as an Urgent Operational Requirement solution pending the procurement of the fully integrated navigation upgrade. Life is rarely as perfect as you'd like. Yet airborne GPS systems have been around for a long time. check out the MAGR system http://gps.losangeles.af.mil/user/products/magr2000/ and here is a photo of all the platofrms it's used on http://gps.losangeles.af.mil/user/pr...0/m-images.htm the virtual gamut of all first line US aircraft, with the exception of the F-15C/D/E. (I wonder why that is?) -- Harry Andreas Engineering raconteur |
#104
"Harry Andreas" wrote in message ... In article , "Paul J. Adam" wrote: snip Assuming a fully integrated GPS, rather than a civilian handheld attached to the glareshield as an Urgent Operational Requirement solution pending the procurement of the fully integrated navigation upgrade. Life is rarely as perfect as you'd like. Yet airborne GPS systems have been around for a long time. Adam just keeps getting more clueless. Here is a nice picture of a PDI designed to be driven from a civilian FMS/GPS, designed circa 1996. http://www.skylight-avionics.com/panel1s.jpg |
#105
I'm trying to fend you off from the boat with an oar already, lune. Keep trying. You haven't drawn any high-intensity flames yet... -Mike (having a slap fighting contest against a man w/no arms) Marron |
#106
Harry Andreas wrote: the virtual gamut of all first line US aircraft, with the exception of the F-15C/D/E. (I wonder why that is?) Not a single Transport aircraft? Missing every major airlifter, not to mention the minor airlifters as well. Mike Williamson |
#107
as long as the GPS is working. But it's a low-powered signal from orbit and it's easily jammed. How true is this, really? In an aircraft, you are between the ground and the satellite. How does someone on the ground interfere with the signal? all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
#108
Cub Driver wrote: as long as the GPS is working. But it's a low-powered signal from orbit and it's easily jammed. How true is this, really? In an aircraft, you are between the ground and the satellite. How does someone on the ground interfere with the signal? I don't believe that the antenna for the GPS is directional enough that someone off axis couldn't put a signal into your system- after all, a single antenna is used to pick up every satellite above the horizon. Mike Williamson |
#109
Michael Williamson
wrote: Cub Driver wrote: as long as the GPS is working. But it's a low-powered signal from orbit and it's easily jammed. How true is this, really? In an aircraft, you are between the ground and the satellite. How does someone on the ground interfere with the signal? I don't believe that the antenna for the GPS is directional enough that someone off axis couldn't put a signal into your system- after all, a single antenna is used to pick up every satellite above the horizon. Mike Williamson While this is true (the receiver antennas need to be and are omni-directional) the satellites broadcast on ~1.5 gigahertz therefore are very much 'line-of-sight' so any interference must be transmitted within 'line-of-sight' to the 'interferee'. IOW, to block a gps receiver you gotta be relatively close to it when you're on the ground...if you're inflight then....you know... -- -Gord. |
#110
In article , Michael Williamson
wrote: Harry Andreas wrote: the virtual gamut of all first line US aircraft, with the exception of the F-15C/D/E. (I wonder why that is?) Not a single Transport aircraft? Missing every major airlifter, not to mention the minor airlifters as well. I only put in a link for one example system, there are many more. We very recently won a contract to upgrade the entire C-130 fleet. -- Harry Andreas Engineering raconteur |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 11:20 PM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Home Built | 0 | September 22nd 04 08:16 PM |
| FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 08:44 PM |
| Sim time loggable? | [email protected] | Instrument Flight Rules | 12 | December 6th 03 08:47 AM |
