#31
CareBear wrote:
Although I did not get the ticket, I still feel good about the overall outcome. It's interesting in that I felt my weakest area would be the oral but this went well. I did have a couple of slips (no pun intended) during the oral but quickly regrouped and gave the correct response. The oral lasted about 2.5 hours. It sounds like your examiner is pretty thorough. That's a pretty long oral for a private checkride. Slips and soft field landings are probably the toughest things in the private checkride. In fact, before I started working on my CFI ticket, I hadn't done a slip since I got my private certificate, and I had a lot of trouble on the first couple. So, look at it this way: your examiner is going to make sure you are well qualified when he signs your ticket. Be proud of that and good luck! -m -- ## Mark T. Dame ## VP, Product Development ## MFM Software, Inc. (http://www.mfm.com/) 100% - effort level demanded by coaches who majored in math or science 110% - effort level demanded by coaches who majored in physical education -- Coach Jack Reed (http://www.johntreed.com/) |
#32
I haven't slipped an airplane, except during the flare in landing in a crosswind of course, in a decade or more, since needing to slip (IMHO) means poor planning earlier in the approach. Many people prefer to use a forward slip in a crosswind situation instead of a crab since it is easier to land in that configuration (i.e. you don't have to switch from a crab to a forward slip at the last minute). I don't do it that way, but know plenty who do. -m -- ## Mark T. Dame ## VP, Product Development ## MFM Software, Inc. (http://www.mfm.com/) "But I'm quite used to being humiliated. I can even go and stick my head in a bucket of water if you like." -- The Hitchhiker's Guide to the Galaxy, Douglas Adams: Marvin |
#33
"Mark T. Dame" wrote in message ... wrote: I haven't slipped an airplane, except during the flare in landing in a crosswind of course, in a decade or more, since needing to slip (IMHO) means poor planning earlier in the approach. Many people prefer to use a forward slip in a crosswind situation instead of a crab since it is easier to land in that configuration (i.e. you don't have to switch from a crab to a forward slip at the last minute). I don't do it that way, but know plenty who do. Well....no. A side slip is used to compensate for crosswind drift, the aircraft longitudinal axis is parallel to the runway centerline. A forward slip is used to increase the descent rate, the aircraft nose will be at an angle to the runway. |
#34
aircraft longitudinal axis is parallel to the runway centerline. A forward slip is used to increase the descent rate, the aircraft nose will be at an angle to the runway. It's the same maneuver. The airplane can't tell the difference. However, the word usage (as above) indicates the purpose of the maneuver. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#35
On Thu, 05 Apr 2007 21:23:16 +0000, Allen wrote:
A side slip is used to compensate for crosswind drift, the aircraft longitudinal axis is parallel to the runway centerline. And, though I've heard about the "crab and kick" method, I'm a little surprised that it works. As soon as one "kicks", one is drifting. Isn't the side-loading at touch-down a problem? Or is that too small to matter? - Andrew |
#36
"Andrew Gideon" wrote in message news ![]() On Thu, 05 Apr 2007 21:23:16 +0000, Allen wrote: A side slip is used to compensate for crosswind drift, the aircraft longitudinal axis is parallel to the runway centerline. And, though I've heard about the "crab and kick" method, I'm a little surprised that it works. As soon as one "kicks", one is drifting. Isn't the side-loading at touch-down a problem? Or is that too small to matter? - Andrew As you "kick," you lower the upwind wing and keep runway alignment with rudder. No drift. Jay B |
#37
... I second that. The only way to improve the signal to noise ratio is to have more valuable posts, since the noise isn't going to go away. What noise? View-Current View-Show All Messages OH! That noise!!! View-Current View-Hide Ignored Message ahhhhhh... That's better...... |
#38
On Thu, 05 Apr 2007 15:23:02 -0700, Jay Beckman wrote:
As you "kick," you lower the upwind wing and keep runway alignment with rudder. No drift. Well, it's been a long time since that method has been described to me. But I've long assumed that the "crab and kick" method didn't involve a transition into a slip. If I'm wrong, then I've been doing "crab and kick" for a while. - Andrew |
#39
On Apr 6, 9:44 am, Andrew Gideon wrote:
On Thu, 05 Apr 2007 21:23:16 +0000, Allen wrote: A side slip is used to compensate for crosswind drift, the aircraft longitudinal axis is parallel to the runway centerline. And, though I've heard about the "crab and kick" method, I'm a little surprised that it works. As soon as one "kicks", one is drifting. Isn't the side-loading at touch-down a problem? Or is that too small to matter? If you lower the into wind wing too much or not enough you run the risk of sideloading the gear so it requires a steady hand and constant adjustments to get it right. Its not rocket science though. |
| WTB: 135 Ticket | AML | General Aviation | 2 | May 30th 06 04:10 PM |
| WTB: 135 Ticket | AML | Piloting | 28 | May 26th 06 05:10 PM |
| WTB:135 Ticket | AML | Owning | 1 | May 24th 06 09:41 PM |
| WTB: 135 Ticket | AML | Aviation Marketplace | 1 | May 24th 06 04:32 PM |
| Got my ticket... now what? | Cub Driver | Piloting | 3 | July 10th 03 08:14 AM |
