Weather vs. Combat
Old August 29th 03, 02:57 AM
Chris Mark
Four wide angle beams. Two quadrants broadcast A and two broadcast
N--one is dot/dash, the other is dash/dot (don't remember which is A
and which is N.)
When introduced in WW2 the system was called Uncle Dog and used a D (dash dot
dot) and a U (dot dot dash).
Chris Mark
John Halliwell
In article , Mike Marron
writes
In any event, other than NDB's, what type of
instrument approaches were generally available back in WW2?
NDBs (if available) would most likely be switched off over the UK to
prevent them being of use to the LW. The Germans had quite a good radio
system (Lorenz?) for giving the pilot a centreline.
John
Old August 29th 03, 04:13 AM
Joey Bishop
and which is N.)
When the beams overlapped, defining the published course you got a
steady tone. Veer to one side you began to discriminate A, veer off
course the other way and you got N. One course---hummmmmmmmmm.
Trivial Pursuit: N = dah dit A = dit dah
Old August 29th 03, 08:01 AM
s.p.i.
Mike Marron wrote in message . ..
The link below shows just how dangerous flying
into a thunderboomer can be. I understand that more
aircraft were lost in Vietnam due to weather than
enemy fire. How accurate is that statement and
did weather also account for more losses than combat
in previous wars (e.g: WW2, Korea, etc?)
http://home.quicknet.nl/qn/prive/f.braaksma/
-Mike Marron
Weather has been the direct cause and indirect contributor to several
helo and UAV losses in OEF and OIF. Its hard to find direct info on
this but wx could well be the leading causal factor in aircraft losses
in those two conflicts
Old August 29th 03, 02:00 PM
Mike Marron
-Mike Marron
Thanks. Weather continues to be the #1 killer in GA and commercial
aviation.
As an aside, here's a personal story of an F-18 Hornet's
recent recovery by barricade. . at night .. on an aircraft carrier in
the Pacific:
[ Note : a barricade is a huge net . . 20 ft high and stretches across
the carrier's deck to 'catch' airplanes during extreme emergencies.]
Oyster, here. This note is to share with you the exciting night I had
the other month. It has nothing to do with me wanting to talk about
me. But it has everything to do with sharing what will no doubt
become a better story as the years go by. So....
There I was .. ' manned up' a hot seat for the 2030 night launch about
500 miles north of Hawaii. I was taxied off toward the carrier's
island where I did a 180 degree turn to get spotted to be the first
one off Catapult # 1. They lowered my launch bar and started the
launch cycle. All systems were ' go' on the runup. And after waiting
the requisite 5 seconds to make sure my flight controls are good to
go, I turned on my lights. As is my habit I shifted my eyes to the
catwalk and watched the deck edge dude and as he started his
routine of looking left, then right. I put my head back against the
head rest.
The Hornet cat shot is pretty impressive. As the cat fires, I stage
the afterburners and am along for the ride. Just prior to the end of
the stroke .. there's a huge flash . . and a simultaneous . .
B-O-O-M ! And my night world is in turmoil.
My little pink body is doing 145 knots or so and is 100 feet above the
black Pacific. And there it stays -- except for the airspeed, which
decreases to 140 knots. Some where in here I raised my gear. And
the throttles aren't going any farther forward despite my
Schwarzze-negerian efforts to make them do so.
From out of the ether I hear a voice say one word: "JETTISON ! "
Rogered that ! And a nano second later my two drops and single
MER, about 4,500 pounds in all, are Black Pacific bound. The airplane
leapt up a bit but not enough. I'm now about a mile in front of the
boat at 160 feet and fluctuating from 135 to 140 knots. The next
comment that comes out of the ether is another one-worder: " EJECT ! "
I'm still flying . . so I respond . . " Not yet . . I've still got
it."
Finally, at 4 miles ahead of the boat, I take a peek at my engine
instruments and notice my left engine . . doesn't match the right. (
Funny, how quick glimpses at instruments get burned into your brain.)
The left rpm is at 48% even though I'm still doing the Ah-Nold thing.
I bring it back out of afterburner to military power. About now I get
another " EJECT ! " call. "Nope . . it's still flying."
At 5 1/2 miles I asked tower to please get the helo headed my way as I
truly thought I was going to be ' shelling out '. At some point, I
thought it would probably be a good idea to start dumping some gas.
But as my hand reached down for the dump switch, I actually
remembered that we had a NATOPS operation prohibition against
dumping fuel while in afterburner. But after a second or two
[contemplating the threat of the unnecessarily burden] I turned the
fuel dump switches on. Immediately [ I was told later ] . . SIXTY FOOT
ROMAN CANDLE . . BEGAN TRAILING BEHIND. At 7 miles I started
a ( very slight ) climb to get a little breathing room. CATCC control
chimes in giving me a downwind [ landing pattern] heading . . and I'm
like: "Ooh . . what a good idea" . . and I throw down my tail hook.
Eventually I get headed downwind to the carrier at 900 feet and ask
for a Tech Rep [Manufacturer's Technical Representative]. While
waiting, I shut down the left engine. But In short order, I hear Scott
"Fuzz" McClure's voice. I tell him the following : " OK Fuzz, my
gear's up . . my left motor's off . . and I'm only able to stay level
by using minimum afterburner. And every time I pull it back to
military power, I start down at about a hundred feet per minute."
I just continue trucking downwind . . trying to stay level . . and
keep dumping fuel. I think I must have been in afterburner for about
fifteen minutes. At ten miles or so I'm down to 5000 pounds of gas
and start a turn back toward the ship. I don't intend to land but I
don't want to get too far away. Of course, as soon I as I stuck in
that angle of bank . . I start dropping like a stone. So I end up
doing a [shallow bank] 5 mile [radius] circle around the ship.
Fuzz is reading me the single engine rate of climb numbers from
the ' book' based on temperature, etc. And it doesn't take us long
to figure out that things aren't adding up. One of the things I'd
learned about the Hornet is that it is a perfectly good single engine
aircraft . . flies great on one motor. So why do I now need blower
[afterburner ] to stay level ?
By this time, I'm talking to the Deputy CAG ( turning [duty] on the
flight deck) and CAG who's on the bridge with the Captain. And we
decide that the thing to do is climb to three thousand feet and '
dirty up' [gear and flaps down] to see if I'm going to have the excess
power needed to be able to shoot a night approach for a landing.
I get headed downwind . . go full burner on my remaining motor . . and
eventually make it to 2000 feet before leveling out below a scattered
layer of puffy clouds. And the 'puffies' are silhouetted against a
half a moon which was really, really cool. I start a turn back toward
the ship . . and when I get pointed in the right direction . . I throw
the gear down and pull the throttle out of after-burner.
Remember that flash/boom! . . that started this little tale ?
[ Repeat it here ] . . Boom ! I jam it back into afterburner, and
after three or four huge compressor stalls [and accompanying
deceleration] the right motor ' comes back'. I'm thinking my blood
pressure was probably ' up there' about now . . and for the first
time, I notice that my mouth has dried up.
This next part is great. You know those stories about guys who
deadstick crippled airplanes away from the orphanages and
puppy stores and stuff and get all this great media attention?
Well, at this point I'm looking at the picket ship in front of me, at
about two miles, and I transmit to no one in particular,
"You need to have the picket ship hang a left right now. I think I'm
gonna be outta here in a second." I said it very calmly but with
meaning. The picket immediately pitched out of the fight. Ha!
I scored major points with the heavies afterwards for this. Anyway,
it's funny how your mind works in these situations.
OK, so I'm dirty and I get it back level and pass a couple miles up
the starboard side of the ship. I'm still in minimum blower and my
fuel state is now about 2500 pounds. Hmmm. I hadn't really thought
about running out of gas. I muster up the gonads to pull it out of
blower again and sure enough...flash, BOOM! I'm thinking that I'm
gonna end up punching out and tell Fuzz at this point " Dude, I really
don't want to try that again." Don't think everyone else got
it . . but he chuckled.
Eventually I discover that even the tiniest throttle movements cause
the ' flash/boom thing ' to happen so I'm trying to be as smooth as I
can. I'm downwind a couple miles when CAG comes up and says,
" Oyster, we're going to rig the barricade."
Remember, CAG's up on the bridge watching me fly around doing
blower donuts in the sky and he's also thinking I'm gonna run outta
JP-5 fuel. By now I've told everyone who's listening that there a
better than average chance that I'm going to be ejecting. (The
helicopter bubbas . . God bless 'em . . have been
following me around this entire time.)
I continue downwind and again, sounding more calm than I probably
was, call the LSO. " Paddles, you up[listening] ?" "Go ahead" replies
" Max" Stout, one of our LSO's. "Max, I probably know most of it ,but
do you want to shoot me the barricade briefing?" So, in about a minute
... he went from expecting me to ' punch out ' .. to have me asking for
the barricade brief [so he was hyperventilating.] But he was awesome
to hear on the radio though . . just the kind of voice you'd want to
hear in this situation.
He gives me the barricade brief. And at nine miles I say, "If I turn
now will ' it ' be up when I get there? Because I don't want to have
to go around again." "It's going up right now, Oyster. Go ahead and
turn." "Turning in, say the final bearing." "Zero six three," replies
the voice in CATCC. " " OK, I'm on a four degree glide slope and I'm
at 800 feet. I will intercept glide slope at about a mile and three
quarters then reduce power. "
When I reduced power : Flash/boom ! [ Add power out of fear.] Going
high ! Pull power. Flash/boom ! [ Add power out of fear.] Going
higher !
[Flashback to LSO school...." All right class, today's lecture will be
on the single engine barricade approach. Remember, the one place
you really, really don't want to be is high. O.K.? You can go play
golf now."] I start to set up a higher than desired sink rate the LSO
hits the " Eat At Joe's" wave-off night lights." Very timely too. I
stroke the AB and cross the flight deck with my right hand on the
stick and my left thinking about the little yellow and black ejection
handle between my legs.
No worries. I cleared that sucker by at least ten feet. By the way my
fuel state at the ball call was [now low] at 1.1. As I slowly climb
out I punched the radio button saying . . again to no one in
particular : " I can do this." I'm in blower still and CAG says, "Turn
downwind." After I get turned around he says, "Oyster, this is gonna
be your last look [at the boat in the dark below] so you can turn in
again as soon as you're comfortable."
I flew the DAY pattern and I lost about 200 feet in the turn and like
a total dumbs_ I look out of the cockpit as I get on centerline and
that " night thing about feeling that I'm too high " grabbed me . .
and [ in error] I pushed down further to 400 feet.
I got kinda irked at myself then as I realized I would now be
intercepting the four degree glide slope in the middle .. with a
flash/boom every several seconds all the way down. Last look at
my gas was 600-and-some pounds [100 gallons] at a mile and a half.
"Where am I on the glide slope, Max ?" I ask. And I and hear a calm
"Roger Ball." I know I'm low because the ILS is waaay up there.
I can't remember what the response was but by now the ball's
shooting up from the depths. I start flying it but before I get a
chance to spot the deck I hear : " Cut, cut, CUT !" I'm really glad I
was a paddles for so long because my mind said to me " Do what
he says Oyster ! " and I pulled it back to idle. (My hook hit 11 paces
from the ramp. The rest is pretty tame. I hit the deck . . skipped the
one, the two and snagged the three wire and rolled into the
barricade about a foot right of centerline.
Once stopped, my vocal cords involuntarily shouted, " VICTORY ! "
The deck lights came on bright . . and off to my right there must have
been a . . ga-zillion cranials and eyes watching.
You could hear a huge cheer across the flight deck. After I open the
canopy and the first guy I see is our huge Flight Deck Chief named
Richards. And he gives me the coolest personal look . . and then two
thumbs up. I will remember all of that forever.
P.S. You're probably wondering what gave motors problems. When
they taxied that last Hornet over the catapult .. they forgot to
remove a section or two of the rubber cat seal. When the catapult
shuttle came back [to hook me up], it removed the cat rubber seal
which was then inhaled by both motors during my catapult stroke. Left
engine basically quit even though the motor is in pretty good shape.
But it was producing no thrust and during the wave-off one of the
LSO's saw "about thirty feet" of black rubber hanging off the left
side of the airplane.
The right motor .. the one that kept running .. had 340 major hits to
all engine stages. The compressor section is trashed . . and best of
all . . it had two pieces of the cat seal [one 2 feet and the other
about 4 feet long] sticking out of the first stage and into the air
intake. God Bless General Electric ! By the way, maintenance data
showed that I was fat on fuel -- I had 380 pounds ( 61 gallons) of gas
when I shut down.
Again, remember this particular number as in ten years [ of story
telling] when it will surely be . . " FUMES MAN . . FUMES . . I TELL
YOU ! "
Oyster, out.
[abridged]
Old August 29th 03, 08:40 PM
Gooneybird
"Mike Marron" wrote in message
Radio ranges. Pilots flew along a beam listening to dots and dashes. The
tone
changed if you drifted off the beam. Some of the old timers here can explain
this a lot better than me since I didn't start flying until the late 1970's.
Since I qualify as one of the old timers, this is how it worked as best as this
over the hill WWII airplane driver can remember it:
Try to visualize two intersecting lines creating the form of a cross, which is
the radio range with
its station at the intersection. Each of the opposing quadrants broadcasts
either an "a" or an "n"
in Morse code, i.e.- ".-" or "-." Where the adjacent quadrants come together,
the signals merge
and become a solid tone, which becomes one of the legs of the range. The merger
was never abrupt as
I recall, so if you were flying at right angles to a leg, you heard a clear "n"
as you approached a
leg, and then slowly started to hear a solid tone in the background. The closer
you got to the leg,
the less you were able to hear the "n" until it completely disappeared as you
flew over the leg.
When you started to pick up the "a" over the solid tone of the leg, you were
outbound from the leg.
Let down procedures were published, just as they are now. So, whatever your
heading happened to be,
the first thing you did was to ID the station, which broadcast its unique
identifier in Morse every
minute or so (I don't recall how often). Then, you'd identify the quadrant you
were in, as well as
which leg of the range you were approaching (by the solid tone becoming louder
or lower), each of
which had its own published let down headings and altitudes. Work this out on a
piece of scratch
paper, and I think it'll make more sense to you than just trying to visualize it
from words.
Reverse turns were almost always initially done by flying outbound on a leg,
then a 45 degree turn
(all turns single needle width) either left or right and fly for a minute on
that heading, then a
180 in either direction until the leg was again intercepted, followed by a 45
degree turn to the
inbound heading.
Somewhere along the line, somebody discovered that if you did a 90 degree turn
to the left of the
outbound leg heading and then a 270 to the right as soon as you hit the 90
heading, you'd end up at
the same place inbound on the leg and didn't have to time your outbound leg
after the 45 turn, which
was useful when your clock was inop or at night when your cockpit lighting
wasn't what it should
have been.
When RDBs became available, they simplified the process because you had a visual
pointer to help you
identify the station location, instead of having to rely on the clarity of audio
radio reception
which, when you were far enough from the station and in bad wx or over poor
radio reception terrain,
could be a challenge.
At any rate, after a while, stations were lined up so that their legs were in
what were the
forerunners of airways, so that you could navigate over distances simply by
flying from the legs of
one station on to those of another ahead of you. I once ferried a gooneybird
from the east coast to
someplace near Riverside, Cal. for a major overhaul by flying radio ranges all
the way.
I hope that helped explain how the system worked. I hope I didn't have too much
screwed up, but
it's the best I can do with the memory available to me of details I used 60
years ago or so.
Please feel free with the questions if I've left something muddy or otherwise
unclear. I may or may
not be able to clarify it, but I will try.
George Z.
Old August 29th 03, 11:57 PM
PosterBoy
"Chris Mark" wrote in message
Here's an anecdote from Capt Frank Dailey that gives a little bit of the
flavor of weather on flight operations in the ww2 era:
"Dick Korn was a PPC in squadron VP-H/L-7 who became the beneficiary of a
good
APS-15 radar operator in his crew. The circumstance began as a simple
transit
flight from NAS Kodiak to NAS Adak, with some off-airways patrolling along
way. Aleutian weather reared its head and as its first challenge provided
headwinds much higher than those forecast.
By the time the Korn-piloted PB4Y-2 got to the vicinity of Adak, it had
exceeded its planned fuel consumption. Adak had closed in. I happened to
be at
Adak as a fill-in copilot for our Operations Officer, Lcdr. Wagoner. It
was now
snowing heavily at NAS Adak .The airfield was now below even GCA minimums.
Dick
Korn elected to try a GCA approach at Adak as he began to doubt that he
had
fuel enough to reach his alternate at Shemya. Wagoner went down to Adak's
Operations room, right next to the tower. I stayed in our assigned Quonset
hut
on top of a hill just south of the runway. My next experience was to hear
a
plane with its engines in full roar making a pullup to the south and
passing so
close overhead that the Quonset huts all rattled. Then I went down to
Operations and found Wagoner in communication with Dick Korn. Wagoner
asked
Korn to get a fuel report from his plane captain. It took longer than it
should
have and when Wagoner finally got it, he made some quick calculations and
barked out instructions to Dick Korn. "Set your course direct for Shemya,
using
your radar operator to track you out there. Do not fly via the standard
airways
route. You do not have enough fuel. Do not try to land here. This field is
almost zero-zero." Korn's crew grasped these instructions quickly and
their
plane gradually disappeared from the NAS Adak radarscope. Wagoner got into
voice communication with Shemya Control and told them the story. He asked
that
Korn be given a straight-in approach and that the Bartow lights on the
runway
be set at Strength Five. It was raining slightly at Shemya but they had
two
miles visibility under a low overcast. The PB4Y-2 radar worked to
perfection.
Dick Korn and crew made a straight in approach and landed at Shemya.
Number one
engine quit on final approach and the # 2, 3, and 4 engine tanks when
dipped,
had twenty, twenty and thirty gallons left, respectively. (The wing tanks
held
about 2400 gallons when topped off.) The radar and the radar operator had
scored again. Wagoner set another high mark for intelligent and timely
decision
making. And Dick Korn was smart enough to follow instructions."
Chris Mark
Chris...and others interested in the above anecdote...
You would be interested in "The Thousand-Mile War" (World War Two in
Alaska and the Aleutians") by Brian Garfield.
There are a number of these 'weather' stories. In fact, the weather in the
area impacted on most of the true tales in this remarkable book. IMHBUAO.
Cheers.
Old August 30th 03, 03:04 AM
PosterBoy
"Peter Bjoern" wrote in message
I have an original AAF Technical Order 30-100 "Instrument Flying
Basic and Advanced" published on 15 January 1944.
Btw. it looks like a kind of predecessor to the later AFM 51-37.
/\/\/\/\/\/\/\ LOTSA GOODSTUF SNIPPED \/\/\/\/\/\/\/
The third part (T.O. 30-100F-1) covers the Army Air Forces Instrument
Approach System. Dated 10 November 1943.
This is nothing less than an ILS system, complete with localizer,
glide path and marker beacons. The frequencies used are even the same
as used today, though there were only six frequencies available for
the localizer, named channels U,V,W,X,Y and Z in the area 108.3 to
110.3 MHz or megacycles as they used then. The glide path was using
frequencies around 335 mc and the marker beacons 75 mc just as today.
The airborne equipment is a receiver control box to tune the desired
channel and the well known crossed-needle instrument with the blue/yellow
zones.
I don't know how widely available this system was, but at least it
was known and developed as early as November 1943 and considered
important enough to place in the instrument flying manual.
Not very widely available, but others have commented as you did about the
longevity of the system developed way back then. One of them is Roger Mola
of Aviation International News who, incidentally, won the Northrop Grumman
Award for the Best Breaking News Submission ( for 'Shutdown of National
Airspace system was 'organized mayhem' ).
And he comments on dates and such of the ILS family development, at the
US Centennial of Flight Commision website:
http://www.centennialofflight.gov/index.cfm (my notes in brackets below):
(SIX LOCATIONS IN 1941)
The instrument landing system (ILS) incorporated the best features of both
approach lighting and radio beacons with higher frequency transmissions. The
ILS painted an electronic picture of the glideslope onto a pilot's cockpit
instruments. Tests of the system began in 1929, and the Civil Aeronautics
Administration (CAA) authorized installation of the system in 1941 at six
locations. The first landing of a scheduled U.S. passenger airliner using
ILS was on January 26, 1938, as a Pennsylvania-Central Airlines Boeing 247-D
flew from Washington, D.C., to Pittsburgh and landed in a snowstorm using
only the ILS system.
(ILS REMAINS UNCHANGED)
More than one type of ILS system was tried. The system eventually adopted
consisted of a course indicator (called a localizer) that showed whether the
plane was to the left or right of the runway centerline, a glide path or
landing beam to show if the plane was above or below the glide slope, and
two marker beacons for showing the progress of approach to the landing
field. Equipment in the airplane allowed the pilot to receive the
information that was sent so he could keep the craft on a perfect flight
path to visual contact with the runway. Approach lighting and other
visibility equipment are part of the ILS and also aid the pilot in landing.
In 2001, the ILS remains basically unchanged.
(NINE LOCATIONS BY 1945, TEN UNDERWAY)
By 1945, nine CAA systems were operating and 10 additional locations were
under construction.
(ARMY INSTALLING 50)
Another 50 were being installed for the army. On January 15, 1945, the U.S.
Army introduced an ILS with a higher frequency transmitter to reduce static
and create straighter courses, called the Army Air Forces Instrument
Approach System Signal Set 51. In 1949, the International Civil Aviation
Organization (ICAO) adopted this army standard for all member countries. In
the 1960s, the first ILS equipment for fully blind landings became possible.
Cheers.
Old August 30th 03, 03:41 AM
Gooneybird
You're quite welcome. I'll have to tell the missus, whatzername, that somebody
complimented me on my memory. (^-^)))
Thanks for the nice words.
George Z.
PosterBoy wrote:
"Gooneybird" wrote in message
this over the hill WWII airplane driver can remember it:
is the radio range with
together, the signals merge
merger was never abrupt as
"n" as you approached a
closer you got to the leg,
flew over the leg.
you were in, as well as
louder or lower), each of
on a piece of scratch
visualize it from words.
degree turn to the
inbound heading.
turn to the left of the
have been.
visual pointer to help you
audio radio reception
what were the
all the way.
much screwed up, but
years ago or so.
George Z.
Well, George....
With a nitpick here or there, I'd say your memory works pretty well !!!
You may be interested to know that as late as the mid-50s, despite USAF's
use of both VOR and ILS, we still had"ADF" and "GCA" stamped on the back of
our Instrument Flight cards (together with VOR 'n ILS) because we gave (and
had to pass, ourselves) the quadrant approach orientation as part of the
annual IFR flight check. It was interesting, espy when you hit the null
cone and wondered if it was station passage or problem with the radio!!.
Thanks for the reminder.
Cheers.
Old August 30th 03, 04:59 AM
PosterBoy
"ArtKramr" wrote in message
Subject: Weather vs. Combat
Date: 8/29/03 6:04 PM Pacific
landing.
under construction.
U.S.
static
In
possible.
Cheers.
Here's the way we did it when flying out of Stansted England before D-Day.
You would taxi out to the head of the runway. If you could see the end of
runway you went. If you couldn't see the end of the runway you went
anyway.
Believe it, Art!!
Same-same K-2 in Korea, 'cept it was mainly haze from the breakfast kimchi
pots in the nearby village of Taegu!
And, I'm sure that the air conditioning system...which could and did blow
frost all around the '86 cockpit...made waiting for the haze to clear a bit
more pleasant than in the Maurader.
Cheers.
Learning more about weather Matt Young Instrument Flight Rules 9 December 23rd 04 02:34 PM
Part 135 Question - Weather Reporting requirement G Farris Instrument Flight Rules 5 October 22nd 04 12:05 AM
Cockpit weather display question Chip Jones Instrument Flight Rules 6 July 21st 04 02:07 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 01:07 AM
